Please visit and Support Our Sponsors
You are currently viewing our boards as a guest which gives you limited access.
Click here to join our free community and you will recieve full access to everything.
If you are a member please sign in.
Go Back   Welcome to TriFive.com 1955 - 1956 - 1957 Chevy's Bel Air Tri5 210 150 Nomad Forum, Photo Gallery and Classifieds. Here you can Buy, Sell, or Trade. Get or Give Advice, or Just Talk Classic Cars. > 55-56-57 Chevy Forum > Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Register FAQ Top Posters Members Search Today's Posts Mark Forums Read
HomePage Todays Post Mark Forums Read upcoming Events Chat Room Open 24 hours Member Map
Trifive Store 2010 Newsletter 2010 Calendar 1955-1956-1957 Chevy Parts and Services = Trifive Official Sponsors
Photo Gallery Garage Photos Trifive Classifieds Calendar Arcade Oldies vBRadio
Old 11-06-2009, 12:08 PM   #1
CJS57
CJS57's Avatar
Member #289
Default Best tool to cut and elongate wheelcover holes?
What would be the best tool bit or grinder or whatever to elongate the valve stem holes about 1/2" longer on the stainless steel wheel cover? I just have home equipment not machine shop. The valve stems come out of the Danchuk repro wheels at the wrong angle. That is why I need to do this.
1957 Belair 2Dr Hdtp, 58,000 original miles, original never rebuilt 283 engine, 245hp, Dual Fours, Tremec TKO 600 5-speed, 3.70 gears, AACA Senior in 1985
previous trifives:
1955 Belair Convt
1956 210 2dr Sdn
CJS57 is offline   Reply With Quote
Old 11-06-2009, 12:21 PM   #2
wraplock
wraplock's Avatar
Member #1500
Dremel tool? I bought one at home depot that came in a plastic tool carry case with every attachment you could think of for $19.99 on sale.
wraplock is online now   Reply With Quote
Old 11-06-2009, 01:26 PM   #3
CJS57
CJS57's Avatar
Member #289
I have 2 of them. Guess I can try it. They seem so under powered to me for anything more than jewelry. Any one else got an idea?
previous trifives:
1955 Belair Convt
1956 210 2dr Sdn
Old 11-06-2009, 01:40 PM   #4
I think I'd consider a chassis punch. Then some hand work to clean it up.
The problem you're going to have with a dremel or other high speed grinder is that if the tool chatters, you'll make a mess of the wheel cover, break the bit, and/or hurt yourself. If you do consider the high speed grinder, use a stone or some other bit that is smooth. Still no guarantee on the chatter, but better.
Been there, done that on the chatter. Just never on a wheel cover.
Old 11-06-2009, 02:07 PM   #5
rwhit57
rwhit57's Avatar
Member #10871
I think Rick is on track. I enclosed a pic of a tool that would work, this one might be a little large, but it's a fine tooth cutting tool, but chattering could be an issue. The higher the speed the less chatter. I recomend trying on an old hubcap first to make sure you've got the hang of it. Whatever you use.
RW in Tulsa
(Randy)
57 Truck Project
Whoever said "Money can't buy happiness" Has obviously never seen a SPEED SHOP!
rwhit57 is online now   Reply With Quote
Old 11-06-2009, 09:01 PM   #6
rwhit57
rwhit57's Avatar
Member #10871
I got to thinking about this and before you cut the caps, check out angle valve stems. They make them in 45 and 90 degree angles, they're cheap and might be alot better than cutting up nice hubcaps.
RW in Tulsa
(Randy)
57 Truck Project
Old 11-06-2009, 10:00 PM   #7
jeffs55
jeffs55's Avatar
Member #2154
If you decide to try the Dremel or die grinder tool, be sure to hold down the cap SECURELY. Have a helper or clamp it some way so it won't move.
Then go slowly. It will grab if you're not very careful (and sometimes if you are). When it does it will whip the cover out of your hand and chew up the hole. I would suggest a right angled die grinder with a 1/8 dia tool.
The closer the diameter of the tool is to the diameter of the hole the more likely it will grab on you.
I don't know if these would get to where you're trying to get to, but you could use something like this hand punch. They come with different size punches and work very well.
If the angled valve stems will get you there, that would be the best thing to do.
Jeff
55 Handyman
66 F100 P/U under construction
32 3-Window coupe under construction
http://www.picturetrail.com/jefs55
jeffs55 is online now   Reply With Quote
Old 11-07-2009, 08:06 AM   #8
CJS57
CJS57's Avatar
Member #289
Thanks! I have already research angled valve stems but they present their own set of problems. If someone is actually using them now, I would be interested in hearing the brand and how that looks and works. ---------------------- I like that blue "hand punch" that is pictured. Maybe a local sheet metal shop could punch a hole next to the original hole, then I could just clean up the edges by hand.---------------Rick, what is a chassis punch? Can I rent one? ------------Maybe EDM, but that may be expensive.
previous trifives:
1955 Belair Convt
1956 210 2dr Sdn
Old 11-07-2009, 08:36 AM   #9
A chassis punch is a simple punch and die, just two round parts that bolt together, one from each side - then you tighten the bolt to punch the hole.
Normally you'd drill a pilot hole for the bolt. Here you'd already have a hole. What I was thinking was that you could get a punch the same size as the original valve stem hole. Then use the chassis punch to elongate the hole by using it on one side of the hole. What you'd then have would be a "figure 8" hole that you'd want to trim into an oval shape.
What I don't know is whether the punch would try to slide off the partial hole being punched as you tried to tighten the bolt.
"Chassis punch" is short for radio chassis punch, a tool used in the old days to punch holes in a radio chassis for the vacuum tubes. They are still widely used in sheet metal fab and by electricians to punch holes in junction boxes, etc.
They are also called Greenlee punches - Greenlee is the long time manufacturer and distributor of them.
Old 11-07-2009, 10:14 AM   #10
Belairmark
Belairmark's Avatar
Member #1498
They sound like Q-max cutters. Like I used to use to cut fender holes for radio aerials, back in the day!!
They do not like side loads.
I used them alot in a research job I had for 13 years and the only real decent hole was from a pilot, for the bolt, to size. Tried to do half a hole on the Chevy and I gave up. I got in with a 4" grinder and loads of patience! Then finished off with a decent file.
If I wasn't meant to drive that fast, the pedal would only go half way!
www.rebel-v8.com, the forum with no decorum
AVO Member #62. www.amvo.org
Belairmark is offline   Reply With Quote
www.keithreiter.com www.56belair.com  www.tri-5.com www.tri-fives.com www.trifive.com
www.1956chevys.com www.1957chevy.org www.55chevy.org www.56belairs.com
www.chevy-belairs.com
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
