Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Nomads, Sedan Deliveries and Station Wagons
Trifive Nomads, Sedan Deliveries and Station Wagons Trifive Nomads, Sedan Deliveries and Station Wagons Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about Trifive Nomads
Old 12-23-2016, 04:45 PM   #281
55wagoncrazy
Stainless Trim Restoration
55wagoncrazy has made a donation to the forum!
55wagoncrazy's Avatar
Member #22828
I try and work on my project about one hour a day. Sometimes I have to skip or stack an hour or two.
This project is quite different from a lot I have done. It is not a pure restoration. I'm going to paint all the engine compartment sheet metal body color. So in keeping with that theme.....I got a few small parts done.
I had difficulty with these finger nail cups moving around when attempting to paint them years ago, until I screwed them down with an under size screw through one of the mounting holes. Problem solved.
Mikey
37 Years of Professional Restoration of anything on a 55-57 Chevy
55wagoncrazy is online now   Reply With Quote
Old 12-23-2016, 05:11 PM   #282
55wagoncrazy
Member #22828
I have done some preliminary test fitting of the rear inner tail lamp to lift gate panel I got from a wrecked wagon. This panel is screwed onto the body and the reproduction tail pan skin. Any adjustment can be done by removing screws installing them to hold where it will be welded. The full Nomad skin is just clamped in place to get the rear measurement along the belt line from the top of the tail lamp to the edge of the quarter at the back edge of the door. Because both sides are getting new Nomad skins I need to make sure these are BOTH the same.
Mikey
Old 12-23-2016, 10:04 PM   #283
mickeywestsr
mickeywestsr has made a donation to the forum!
mickeywestsr's Avatar
Member #1970
Thumbs up
I've just gone back through your post and can hardly wait for more .....
Cowboy
GO VOLS
COWBOY
mickeywestsr is offline   Reply With Quote
Old 01-02-2017, 01:07 PM   #284
55wagoncrazy
Member #22828
Cowboy
Thanks Mickey! I wonder sometimes if I am just doing this thread for myself.....
Yesterday my wife kicked me out of the house as she took down the seasonal decorations. SO I WORKED on my project frame.
I had previously purchased some 56 one piece frame parts to swap out with my 55 ones. I wanted the wider rear spring mounts. I tacked these in place. I also had some rust issues on the front mounts. They tend to be dirt collectors and then the rust starts. I have had this problem before, so I just removed the mounts and replaced them with better quality ones. I will drill a 3/8 inch hole in each of these so that water can drain out of them in the future, something I think the factory should have done.
I initially just put some tack welds on the corners. I installed my NOS rear shackles and bushing. Using a nice original rear leaf spring to make sure that they were located where needed. When this was done to both sides, I welded them solid.
For now this is all that I will be doing to these. There are some other items to done to the frame, and once all the changes are done it will get sandblasted and epoxy coated.
Mikey
Old 01-02-2017, 01:30 PM   #285
Tropturq
Tropturq's Avatar
Member #33781
Mikey,
Always enjoy your posts, and as usual great workmanship!
Tropturq is online now   Reply With Quote
Old 02-16-2017, 05:55 PM   #286
55wagoncrazy
Member #22828
This morning I removed my Sedan Delivery lift gate to do the install of Madmooks new stainless trim kit.
The first step was to place the cover plate over the latch hole. Line up the holes the factory placed there, and then using the stainless screws Michael provided with the kit, screw it in place.
Next step is to take the longest section of outside trim and place it over the top of the cover plate. In this photo you can see the hole is already there. Center the trim over this hole and install a screw LOOSELY. The outside ends will need to be able to pivot on this screw.
Now take the two outside pieces along with the lower piece and lay them on the lower part of the gate. Make sure to adjust all 4 of the pieces of trim for the very best centering you can get. After I did this I installed some masking tape to hold them in place. Inspect this and make sure this is where you want it.
At this step, with the trim held in place with the tape. Mark each hole with a sharp pencil. This spot will be drilled out for the screws.
Remove all the trim and drill each spot you marked with a 1/8 inch bit.
Re-install the trim and install the screws loosely. Without any support under the trim you can damage it by installing the screw all the way. It will tend to push the trim down towards the center.
This is all that needs to be done at this time.
I re-installed the lift gate to my project to see how it looks. The photo is not the best quality. But it is still nice to see how it will look when all the paint work is done and carpet or material is inside the trim.
Thanks for stopping by and checking out my build
Mikey
Mikey
Old 02-16-2017, 06:12 PM   #287
C57heaven
C57heaven's Avatar
Member #631
Looks good. Thanks for taking the time to post.
"I wanted the wider rear spring mounts."
If I may ask...what does a wider rear upper mount do?
Performance? Increased sway resistance?
Peace;
John
57 convert.
993/1000 1st Place 1957 Custom -
Ecklers State Rep show 2016
55 Belair 2dr sedan owned since 1979
sold '09 to fund vert.
Trifive Nationals 2015 #15
C57heaven is online now   Reply With Quote
Old 02-16-2017, 06:33 PM   #288
55wagoncrazy
Member #22828
Just wanted to because I have seen the shorter bushings ware out. GM went to the wider support in 56 for that reason.
Mikey
Old 02-17-2017, 11:49 PM   #289
Dragsix
Dragsix's Avatar
Member #20785
I look forward to every post! I learn something every time -- every time!
Dragsix is online now   Reply With Quote
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
