Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Cooling Systems, Radiators, Fans / A/C
Engine Cooling Systems, Radiators, Fans / Shrouds, water pumps, anything cooling related. Air conditioning etc.
Sponsored By: Cold-Case Aluminum Radiators
Old 02-14-2017, 12:16 PM   #21
chevman57
Sr. Administrator
chevman57 has made a donation to the forum!
chevman57's Avatar
Member #264
David, no need for step 2-4 if you use a radiator with the 6cyl upper neck.
http://s1181.photobucket.com/albums/x437/chevman57/
http://www.cardomain.com/id/chevman57
http://www.trifive.com/forums/album.php?albumid=1177
1957 2dr sedan Bel Air, owned since 1978
1972 Chevelle Malibu, awaiting rebuild,owned since 1979
chevman57 is online now   Reply With Quote
Old 02-14-2017, 12:32 PM   #22
Originally Posted by chevman57 View Post
David, no need for step 2-4 if you use a radiator with the 6cyl upper neck.Terry
Understand that and agree...I was amplifying on what Bruce had said about trying to use a 57, V8 radiator in the six cylinder position in case any of the members were wondering what all was involved....Also, the OP said:"Well, I did stay with the radiator. had to do minor modifications."
_______________________________
-I have a vast data base of TriFive restoration & upgrade articles for our members' use....Send me a PM with your requirements and I'll strive to provide what you need...Please include your email address and the topic
Old 02-14-2017, 01:59 PM   #23
TheHotrodHandyman
TheHotrodHandyman's Avatar
Member #8438
Originally Posted by 557B210 View Post
Are you saying you got a V8 radiator to fit in the 6 cylinder position with minor modifications....Have you closed the hood with the hoses hooked up yet?
I'd be interested in seeing how you did it.
I'd be interested to see how or if the hood closes.
-Bruce
Old 02-17-2017, 01:09 PM   #24
SWStrangla
Member #42490
Yes 557 I did get the V8 radiator to fit in 6 cyl. position. I also did not have to cut the cross bar either. The condenser lines from Vintage Air worked perfectly. There is very little hood clearance. You can NOT use any fancy radiator caps, you will need one will the lowest profile as possible.
SWStrangla is offline   Reply With Quote
Old 02-17-2017, 01:49 PM   #25
chevman57
Sr. Administrator
chevman57's Avatar
Member #264
I had no problem with the radiator cap:
[IMG][/IMG]
Old 02-17-2017, 02:19 PM   #26
Terry, SW is talking about using the stock V-8 radiator with the center top hose sitting on top of the cross bar.
We still don't know how he closes the hood with the stock baffle.
Old 02-17-2017, 05:16 PM   #27
Roscoe7
Roscoe7's Avatar
Member #7496
Seems like an awful lot of work just to fit a large body HEI.
I have the small body HEI, Vintage Air, power steering pump mounted on front engine mount bracket, radiator shroud, and it all fits with engine/radiator in the stock V8 location.
Roscoe7 is offline   Reply With Quote
Old 02-21-2017, 11:24 AM   #28
SWStrangla
Member #42490
Yes, it has been ALOT of work and modifications just to fit the distributor Hindsight I would have just had them change the distributor. Everything just snowballed from there.
I do stand corrected on the V8 radiator in 6 cylinder position. I hadn't completely bolted everything down tight (fenders, baffles, etc.) to completely see if it was all going to fit. Got all that tight and got the hood to close but around the front rounded edge of the hood and fenders the hood sticks up about 1/8th of an inch. So, I will have to modify the cross bar some what. Gotten too far to stop now.
Old 02-21-2017, 11:32 AM   #29
What did you do with the hood baffle?
Originally Posted by henrys57wagon View Post
I had the same problem with the Griffin rad and started by flattening out the top bar of the rad support and lowering the rad to clear the hood. I also added a notch to my hood brace as shown, good day.
Old 02-21-2017, 11:45 AM   #30
Here is a radiator top cross bar that has been notched to clear the top hose on the 57, V8 radiator.
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
