Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Welcome to Trifive > Project Update Section, Post your Project updates here
Project Update Section, Post your Project updates here This section is for Project Updates only, So post any updates of your trifive projects. >Do not post tech questions in this area of the forum = Remember only projects updates should be posted here.
Old 01-10-2017, 12:28 PM   #31
tekctrl
tekctrl has made a donation to the forum!
tekctrl's Avatar
Location: Fairview Heights, IL (12 mi's east of the St. Louis arch)
Member #24553
Originally Posted by Roger Walling View Post
The TH R 700 is a good choice, I installed one in my 56.
I did make a mistake though, I ordered a TV cable that was adjustable without knowing it.
According to the instructions, you tighten the adj. cable after setting the adjustment near the carb.
Mine was in a very tight spot to get a wrench on, and being a plastic cable, I was not able to determine just how tight I had it.
After a few miles the adj slipped and burned out the new reman.
I bought an original GM TV cable to instal when the trans comes back from the rebuilder.
Was kind of on the fence for a while between the 700R4 and a 4L60E. Since I wanted to minimize the electronics, I went with the 700R4 even though I've heard that they're Very Picky about adjusting the TV cable. I'll probably have someone do that who has some experience with them before I take it out on the road. Point taken about your adjuster slipping and Thx for the heads up!
tekctrl is offline   Reply With Quote
Old 01-10-2017, 05:57 PM   #32
tekctrl
tekctrl's Avatar
Member #24553
Default PS update
Spoke with C-I/Miguel & Danny and CPP/Aaron about the pump not working with the recommended pullley. CPP's response; "We see no problem. Take it up with C-I." C-I pulled a pump and pulley and say that they're seeing the same interference problem that I reported. They recommended that I gently shave some meat off of the side of the body where it interferes with the pulley. I Don't like it, but will do that...and crossing my fingers/legs/eyes that it doesn't result in other problems. Per C-I/Danny, they Say they'll take the modified pump back if it still doesn't work right. (rrrright) Should Not have to modify a part to get it to fit!! More to come.
Old 01-10-2017, 06:03 PM   #33
TV cable adjustment is very simple. cable should be tight -1/16"at full throttle. if you pull the throttle full open you should be able to pull the end of the tv cable appx 1/16" more.
Old 01-10-2017, 07:17 PM   #34
TheHotrodHandyman
TheHotrodHandyman's Avatar
Member #8438
Can I ask why you are running (or trying) a double shiv pulley on the P/S? Every trifive I have put P/S on with a short style pump used a single shiv pulley.
-Bruce
Old 01-10-2017, 07:32 PM   #35
Rustaddict
Rustaddict's Avatar
Member #16602
I just now got a chance to check your thread out. Good luck getting your pulleys sorted out. I'd hate to have to go through that again without a donor motor to pull the brackets pulleys, and accessories off of at the same time. I don't think you will be unhappy with the regular Performer manifold and the Vortec heads on a 383 street car. It ought to be torquey.
Jimmy
Rustaddict is offline   Reply With Quote
Old 01-11-2017, 09:40 AM   #36
tekctrl
tekctrl's Avatar
Member #24553
It's what was provided by the vendor. Single or double doesn't matter to me as long as it Works.
Old 01-11-2017, 09:46 AM   #37
tekctrl
tekctrl's Avatar
Member #24553
I wish I had a donor motor, but I don't. Pulley alignment issues and interfering brackets never crossed my mind when I was planning this. The presumption is that "all inclusive kits" include everything and that it all works together properly. I also figured that whatever I needed in the way of brackets & pulleys I could just order up from our local Chevrolet dealership parts department. Wrong, Wrong, and Wrong.
Once I get the PS issue resolved, I still need to shim the alternator out so that it will align with the crank pulley. Off almost 1.5" right now. One issue at a time, though.
Not happy with the way the A/C compressor and the alternator hit the valve covers using the brackets that I got, but as long as they're working not going to do anything about it. Besides, shimming it out enough to align with the crank pulley may fix that problem too.
Old 01-11-2017, 10:04 AM   #38
TheHotrodHandyman
Member #8438
The single should solve your problem.
-Bruce
Old 01-12-2017, 10:10 AM   #39
tekctrl
tekctrl's Avatar
Member #24553
Response from CPP; "The CP38808 is an exact reproduction of the factory GM pulley specs. Fits the pump, never had any interference problems." Therefore, the metallic scraping noise and pulley's failure to fully seat on the pump shaft is all in my imagination. Even though C-I was able to duplicate the problem with stock from their warehouse. What's wrong with this picture??
Lessons learned; 1) "All-in-1" kits aren't. 2) Just because the vendor says parts work together doesn't mean they Do. 3) "We stand behind our products" is advertising, not policy.
I'm thinking that I should've just gone with putting an LS in the car instead of the 383. At least brackets & pulleys would be available over the counter and they'd WORK together. It'd be Boring, but it would work without this tooth-and-nail fight.
Almost got the Ididit column & 500 box install completed. Now have to figure out how to sync the 500 box to the column so that we have the same turning radius in both directions, and modify the steering wheel so that it's at 12 o'clock when the wheels are straight ahead while making sure that the turn signals still cancel properly. Of course, the Ididit column came with no instructions and there are no installation videos or instructions for this (column shifter, non-tilt) on their website. (sigh)
Old 01-13-2017, 10:58 AM   #40
ididitinc
Official Trifive Sponsor
Member #7804
If you (or anybody that reads this) need any help in setting up the column, please feel free to call us here at ididit. We will always do our best to answer your questions. There should have been an instruction booklet in with the column. I can easily get you one if you'd like. While it doesn't go over every aspect of installing a column, I do feel it's pretty complete including how to properly clock the cancelling cam so your turn signals cancel properly.
ididitinc is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
dalendora
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
