Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Electrical Questions and Answers
User Name
Password
Electrical Questions and Answers This is the place to ask all your question about electrical problems and instalation issues.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 04-29-2013, 12:05 AM   #1
Len57Belair
Member
Member #7838
Lightbulb Fix - Fuel Gauge 30 Ohm with 90 Ohm sender
The fix is to add 33 ohm resistor to the sending unit.
I just wanted to post this fix. After three guages and three sending units I ended up with the wrong sending unit. Long story and you know how it goes. So before I take the tank out again I used this fix.
Fuel Guage 0-30 ohms and a 0-90 ohm sending unit.
The 0-30 ohms is the stock range.
The 0-90 ohms is often used with after market guages.
Both read empty at 0 ohms and full at the high ohm reading.
Add a 33 ohm resister in parallel to the sending unit. Connect a 33 ohm resister between the sending unit stud and ground. You can connect the resister at any point along the wire from the sending unit to any good ground.
With this fix you guage will read a litte low from full to 1/2 and a little high 1/2 to empty.
Here are the calculations
The 30 ohm sending unit measured 36 Ohms when lever is full up positon.
To calculate resistance the formula is R1xR2 devided by R1+R2
R1=33 ohms Fixed resistor
R2= Tank sending unit
Adjusted--------Correct
Ohms ------------Ohms
24.1--------------36.0---- -Full
22.2--------------27.0----Three quarter
19.0--------------18.0----One Half
13.4-------------- 9.0-----One Quarter
0.0----------------0.0-----Empty
Look at the Actual Ohms collum and compare it to the Correct Ohms collum
At full the gauge will read about 7/8 full
the gauge will be seeing 24.1 ohms instead of 36 ohms
At 1/2 the guage read 1/2 because 19.0 ohms instead of 18.0 ohms is very close
At 1/4 tank the guage will read a little high
The guage will see 13.4 instead of 9.0
At empty 0 is 0 and the guage will go to the empty stop set on the guage.
Remember when your guage reads 1/4 you only have 1/8 left so it is time to fill up.
You can use a 20 ohm resister and the guage will read 1/2 when full but be very close below 1/4
If you do not use a resistor your guage will read
full when you have 1/4 tank
1/2 tank at 1/8 about 2 gal
1/4 is about 1 gal in the tank.
The correct sending unit for the guage you have is the best option but adding the resistor my work until you get it changed.
Len57Belair is offline   Reply With Quote
Old 04-29-2013, 06:31 AM   #2
Yerny
Senior Member
Member #24804
Default
Nice work...now we just need to figure out how to inverse the resistance. I have a F150 fuel tank in my Nova - fuel gauge works but reads backwards.
The few options I can think of:
1) place the float 180 off( pointing in the opposite direction), if feasible
2) the electrical part of the sender consists of a resistance strip with a connection at one end, and a sliding contact. If it has provisions to do so, you could move the wire from one end of the strip to the other.
3) try to build a circuit yourself (Op Amp?) - though I did find this supplier, which is what I'm probably going to go with: https://www.spiyda.com/magento/index...izard-mk2.html
Anyone got a better solution or non-UK vendor?
__________________
Bryan
'55 2dr Bel Air Hardtop - project Tux
Yerny is offline   Reply With Quote
Old 04-29-2013, 06:39 AM   #3
angs1957
Super Moderator
angs1957 has made a donation to the forum!
angs1957's Avatar
Member #2237
Default
You sure have gone to alot of trouble to work it all out
angs1957 is offline   Reply With Quote
Reply
Tags
fix , fuel guage , sender
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
