Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
User Name
Password
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Parts on Ebay
Reply
Thread Tools Display Modes
Old 11-10-2013, 06:22 AM   #31
stoveboltgeek
Senior Member 1 Gold Star
stoveboltgeek's Avatar
Member #16357
Default
I can see his point about teflon bushings. I've seen graphite impregnated brass ones as well for sale. But, I don't repair carburetors for a living, so I'm not going to argue with him.
I'm still trying to figure out what you mean by "CO2 readings were 8 for both". If you mean he connected your carburetor to a carburetor airflow testing machine, and measured the air/fuel ratio on primary and secondary is 8 to 1, then yes - you have a huge problem.
Since the "ideal" air/fuel ratio is 14.7 to 1, an 8 to 1 ratio would explain your horrible fuel mileage. 8 to 1 is more like what you'd use with the choke full on to start the engine. Incorrect or drilled-out jets are likely culprits, as are incorrect metering rods or metering rod springs.
At this point, I'm going to step back. PM me if you need additional specs on the original components.
stoveboltgeek is offline   Reply With Quote
Old 11-10-2013, 07:03 AM   #32
johnonetrillion
Senior Member 2 Gold Stars
johnonetrillion has made a donation to the forum!
johnonetrillion's Avatar
Member #10655
Default
The carb guy hooked up some sort of portable tester – a hose to one of the exhaust pipes and then the box gave readings. It read what I understood to be CO (carbon monoxide) as an indication of richness. It was reading 8% off both primary and secondaries, where it should have been 1.5% off the secondaries and something closer to 3% off the idle. So that is where the scope to improve on the economy lies.
Like I said, he's going to fix the throttle shaft first and then work on the jetting. He said he would start with the standard sizes first and then tweak (not twerk) from there.
Btw, had been invited to display my car at one of the annual vintage and historic track race meets today. Was heaps of fun and was in a great vantage point for the races.
__________________
1957 RHD Belair Sport Coupe Restoration completed October 2013
Instagram: @johnonetrillion www.instagram.com/johnonetrillion
Johnny Goes To Bollywood
http://petrolicious.com/this-1957-ch...the-other-side
http://youtu.be/OZxm2z-ThsA
http://youtu.be/Epl-odnpijA
http://youtu.be/JdXgc2NBBg0
http://youtu.be/qix83i4w3a4
http://www.flickr.com/photos/johnone...57637254419714
Melbourne, Australia
johnonetrillion is online now   Reply With Quote
Old 11-10-2013, 09:30 AM   #33
stoveboltgeek
Member #16357
Default
Okay - that is correct.
The tester used probably tests for CO and HC. CO is carbon monoxide - fuel that couldn't burn completely because there wasn't enough air. HC is hydrocarbons - fuel that didn't even attempt to burn, usually because of faulty ignition or burned exhaust valve.
No question it's running very rich.
Old 11-10-2013, 12:46 PM   #34
55copper
Senior Member 1 Silver Star
55copper's Avatar
Member #7217
Default
Sorry to jump in but what are the metering rod numbers and jets for a stock 55 V8 car and thanks
__________________
55copper@oro.net
55copper is offline   Reply With Quote
Old 11-10-2013, 02:36 PM   #35
stoveboltgeek
Member #16357
Default
Quote:
120-155 primary jet,
120-187 secondary jet,
75-1161 metering rod,
11-263S low speed jet.
Old 11-10-2013, 02:49 PM   #36
55copper
55copper's Avatar
Member #7217
Default
__________________
55copper@oro.net
Old 11-10-2013, 10:31 PM   #37
f.i.57chevynut
f.i.57chevynut's Avatar
Member #22244
Default
I would inspect the shaft for wear. It seems to be the real wear part of the carb, not the base casting. Most of the WCFBs i've taken apart have worn through the chrome plating on the shaft. I know Chuck Smith has shafts for the 2x4 carbs but I don't know if he has them for the single quad. The angle of the secondary butterflies may be different since the single uses a 166 and the 2x4 uses a 193.
__________________
Tom Ordway tom@57chevys.com
If you can't drive it, why have it?
http://www.americantorque.com/page/0/139/
f.i.57chevynut is offline   Reply With Quote
Old 11-18-2013, 02:47 AM   #38
johnonetrillion
Member #10655
Default
Ok, the car (and carb) spent a few hours with the man in Thornbury today. Here's what he found:
The throttle shaft, previously thought to be loose, was ok. It was the linkage from it that was loose, so that was re-peened.
The main problem was coming from one of the metering rids, which had become dislodged.
Jets were fine, as it turned out.
Fuel pressure was good at 5.2 psi.
Idles were re-set and CO read at 1.6%. Better than the 8% previously.
But he did find that the engine was running 1.7% richer with the air filter fitted. So it looks like my configuration of a 3" paper filter within the original 4-barrel cleaner is actually restricting air flow. Maybe a 2" filter is ok, and the additional flow over the top of the thing (unfiltered) will be ok?
Anyway, I'll fill the tank in the morning and take another reading of fuel (un)economy in a week's time and see if it improves from 8.9 miles/gallon.
Thanks everyone for the comments and assistance.
__________________
Old 11-18-2013, 09:59 AM   #39
F.I. 57 Belair
Member #15199
Default
John, that is good to hear that you found the reason for your carb problems. What is interesting is the 3 inch filter causing air flow issues. Could you post some pictures of your modified air filter? I would think that the shorter filter would cause more restriction. Let us know what you find when changing to the shorter filter.
Tom
F.I. 57 Belair is offline   Reply With Quote
Old 11-18-2013, 03:29 PM   #40
johnonetrillion
Member #10655
Default
What I mean is, I have the original 4-barrel air cleaner, removed the oil bath filter and replaced it with a new 3" high paper filter. Being this high, pretty much a of the air flow is coming through the snout and through the paper, and not over the top. I figured this would provide the cleanest air. But it turns out it is also causing restriction. If I put in a 2" filter it will increase air flow over the top, but it won't be as well filtered.
Will take a pic this morning and post.
I thought it was a pretty good conversion, but obviously I need to work on it some more. Possibly another filter, or perforate existing a little.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
