Please visit and Support Our Sponsors
Go Back   Welcome to TriFive.com 1955 - 1956 - 1957 Chevy's Bel Air Tri5 210 150 Nomad Forum, Photo Gallery and Classifieds. Here you can Buy, Sell, or Trade. Get or Give Advice, or Just Talk Classic Cars. > Welcome to Trifive > Project Update Section, Post your Project updates here
User Name
Password
Register FAQ Top Posters Members Search Today's Posts Mark Forums Read
Trifive Store 2010 Newsletter 2010 Calendar 1955-1956-1957 Chevy Parts and Services = Trifive Official Sponsors
Photo Gallery Garage Photos Trifive Classifieds Calendar Arcade Oldies vBRadio
Project Update Section, Post your Project updates here This section is for Project Updates only, So post any updates of your trifive projects. Remember only projects updates should be posted here.
Reply
Thread Tools Display Modes
Old 02-10-2008, 02:45 PM   #1
Chevynut
Trifive Leaders Club
Chevynut's Avatar
Member #1769
Default Chevynut Nomad project update
Thought I'd post a couple of pics showing what I've been up to lately. I've gotten to the "detail" part of the build where things get tedious. I plan to build EVERYTHING for the car before it's painted, so all I have to do later is assemble it. At least that's the plan.
I'm about halfway done with my throttle linkage on the engine, but I need to machine a few pieces to finish it.
First is a picture of my electric power brake booster. The plumbing is coming together, and I just have to connect the MC to the frame and build a fluid reservoir. The frame is completely plumbed with the exception of brake hoses to the calipers. I mounted the pump to the booster bolts with a bracket I built that isolates it from the body. I didn't want to use hoses and clamps, so I welded AN bungs to the remote reservoir block and I'm using teflon SS braided hose instead to minimize the risk of leaks. I have to machine a couple of adapter fittings to do that. This will all be totally hidden under the inner fender.
Next I built a coil bracket to locate the red MSD Blaster coil under the intake manifold. The stock Ramjet 502 ECU sits in this location, but since it's gone (I'll be using a Holley Commander 950 ECU) I figured it would be a great place to hide a coil so I made a mounting plate out of aluminum. I will be putting a large 150 or 175A alternator fuse on the plate beside the coil, and all my electrical wires will be routed through there as well. My fuel hoses to the central fuel rail are also done.
I've also been collecting all of my sensors, connectors, wiring, and other electrical stuff so I can start on that soon. I am currently building seat brackets and will post pics of that later.
Lots of things left to do.
__________________
'56 Chevy Nomad, Ramjet 502, Viper T56, C4 Corvette F&R suspension w/coilovers.
See My Nomad Build HERE
Chevynut is online now   Reply With Quote
Old 02-10-2008, 02:55 PM   #2
Sweden
Sweden's Avatar
Member #1166
Default
Hi Lazlo.
Your build is a true piece of art, everything is pushing the limit of what can be done to a TriFive.
__________________
Owe
My Website!
My Pictures.
Sweden is offline   Reply With Quote
Old 02-10-2008, 03:02 PM   #3
rigi
Senior Member 1 Silver Star
rigi's Avatar
Member #960
Default
Before I wanted paint on my car as soon as possible, but now I find more things to fit and brackets to weld to the body all the time. Sometimes it is your "fault" ---actually I have to thank you for many things I almost forgot..
Now I don't want to paint my car, can you imagine if I would forget any bracket??!
Anyway! Nice work as always Laszlo.
__________________
Richard
57 BelAir coupe/LS-1/4L60E/C4 IFS,IFR/Air-ride
www.57chevy.se
rigi is offline   Reply With Quote
Old 02-10-2008, 04:13 PM   #4
dseale4888
Senior Member 4 Gold Stars
dseale4888's Avatar
Member #228
Send a message via MSN to dseale4888
Default
Looking exquisit!!! It always takes time to do it right. I've got to search in my garage to find some 283 pulleys for my engine now.
Dave
__________________
Dave http://www.trifive.com/webs/dseale4888/
Keep smilin', it makes people wonder what you've been up to.
dseale4888 is offline   Reply With Quote
Old 02-10-2008, 06:50 PM   #5
BLACKHORSE
Senior Member 1 Gold Star
BLACKHORSE's Avatar
Member #4248
Default
MARK
__________________
MARK
"When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others."
BLACKHORSE is offline   Reply With Quote
Old 02-10-2008, 07:56 PM   #6
vander55
Senior Member
vander55's Avatar
Member #2040
Default
Looks great ,always look foward to update pics . thanks
Ken
__________________
see my 55 www.picturetrail.com/vander55
vander55 is online now   Reply With Quote
Old 02-10-2008, 08:39 PM   #7
57 Bel Air LS7
Senior Member 1 Blue Star
Member #2265
Default
Lookin' good. I envy your craftsmanship.
__________________
Frank
1957 Bel Air 2dr ht, AME chassis, LS7, T-56
1957 Bel Air convert, ZZ4, TH350
1955 210 2dr post, 350, 4 spd, 10"
1967 VW bug, ZZ4, 700R4, 9" F**d
57 Bel Air LS7 is online now   Reply With Quote
Old 02-10-2008, 08:43 PM   #8
Russ T Nut
Member
Member #4723
Default
Congrats on your progress. As you know I'm working on my nomad and I find great inspiration following your build. I've mounted my C4 IRS following your lead and hope it works out as well as yours.
Good luck.
Russ
Russ T Nut is offline   Reply With Quote
Old 02-10-2008, 10:46 PM   #9
mickeywestsr
mickeywestsr's Avatar
Member #1970
Default
Looks like you are doing it right.....cool color combo!!!
__________________
GO VOLS
If Its Not Good Enough For Washington
Then Its Not Good Enough For My Family
mickeywestsr is offline   Reply With Quote
Old 02-10-2008, 11:07 PM   #10
grandmas55
Member #4101
Default
Wow, Chevynut, what beautiful craftsmanship. You are so far out of my league I can only admire. Thanks for sharing. Mark
grandmas55 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
www.keithreiter.com www.56belair.com  www.tri-5.com www.tri-fives.com www.trifive.com
www.1956chevys.com www.1957chevy.org www.55chevy.org www.56belairs.com
www.chevy-belairs.com
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
