Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
User Name
Password
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 01-28-2014, 01:41 PM   #1
Drumbum675
Member
Member #3829
Default FI or carb - what would u do?
So I'm swapping out the engine on my '55. Going from a 327 to a new 383. My dilemma is should I keep the fuel injection system that I had on the 327 or get a new carb. I currently have a Holley 4D system. Its old and hard to tune, but when you do finally get it set up, it works great. I'm updating the entire engine bay and want a clean look so all the wiring for the FI will have to go under dash. Car gets driven once or twice a month. So would you keep the fuel injection or sell it for the $500 they are currently going for and get a decent carb??? And no, my budget wont allow for a new fuel injection system..
Drumbum675 is offline   Reply With Quote
Old 01-28-2014, 02:53 PM   #2
roger1
Trifive Leaders Club
roger1's Avatar
Member #5484
Default
I don't know anything about that Holley system but I will say that I will not put a carburetor on anything I own again. Port F.I. on everything for me.
That Holley system is a throttle body, correct? I don't know about those but had a friend take one off because it caused problems. If I were in your shoes and couldn't spring for a new MFI system, I'd probably go with a carb. Maybe a 700 cfm double pumper like the Holley 4778.
__________________
'55 Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed September 2012
'57 3200 Pickup - 305 TPI / 700R4, Restomod Completed October 2015 PROJECT THREAD
Photo Albums
Note: Sorry, the site now requires that you must sign up as a member in order to view my albums.
roger1 is offline   Reply With Quote
Old 01-28-2014, 03:16 PM   #3
Drumbum675
Member
Member #3829
Default
yep, it is a throttle body system. Eliminates the carb headaches....but has some headaches of its own. Main thing is Holley won't support it with any kind of customer service. Supposed to be good to 600 hp and I'll be around 450 with this new motor....
Old 01-28-2014, 03:35 PM   #4
rayharris
Senior Member 4 Gold Stars
rayharris has made a donation to the forum!
rayharris's Avatar
Member #16151
Default
Upgrade = FI.
__________________
Ray
"Dreading it, is the worst part of the job."
rayharris is offline   Reply With Quote
Old 01-28-2014, 08:39 PM   #5
Bill_USN-1
Fuel Injection Tech
Bill_USN-1's Avatar
Member #30549
Default
For a driver, a simple TBI system works great. I stick with GM factory based systems for reliabilty and parts availability.
The BBC throttle body is just about 700cfm so it's plenty for most mild builds.
MPFI is another good system but really only increases the wow factor when you pop the hood.
Most believe that it creates more HP and MPGs but in reality it was designed to improve the idle/low speed emissions due to the reduction of puddling in the intake runner at low rpms.
If you pull the same CFM and have the same timing and AFR then the HP really isn't going to change.
The GM TPI system was a good looking system that worked great for a standard daily driver that delivers good performance below 4000rpm. Anything above that and the TPI starts to go flat.
The older TBI actually had better low end torque numbers than the MPFI.
MPFI does give a little better instant throttle response or tip in due to the injector placement but it's not really anything you can quantify.
The year round driveability is drastically improved over the carb. It turns the old pushrod engines into a modern driver just like your wifes car. No more pumping the gas or sticky chokes or waiting for the engine to warm up before sticking it in gear.
Increased MPG is just a side benefit due to the O2 feedback to keep the AFR properly set all the time.
An added benefit is engine longevity due to no more washed or lean cylinders or fuel in the oil.
Bottom line, Carbs work...sometimes and none of them are "in tune" even 5 min after you get it off the dyno.
A good EFI will allow you to drive your classic anytime you want, any where you want and deliver the proper tune.
Bill_USN-1 is offline   Reply With Quote
Old 01-28-2014, 09:32 PM   #6
Rapper57
Senior Member 1 Gold Star
Rapper57's Avatar
Member #26430
Thumbs up
I pulled out the original FI system on my 57 Belair and went with natural aspiration. 650 CFM carb and matching manifold. I like the range of adjustment. Interesting that formula 1 cars are still naturally aspirated. Don't know how they pack it in, guess use turbo chargers.
__________________
"Don't apologize, it's a sign of weakness" John Wayne; She Wore a Yellow Ribbon
Rapper57 is offline   Reply With Quote
Old 01-28-2014, 09:35 PM   #7
roger1
roger1's Avatar
Member #5484
Default
Quote:
Naturally aspirated means only with atmospheric pressure thus no turbo charger or super charger. It has nothing to do with FI or carburetor.
__________________
Photo Albums
Old 01-28-2014, 09:46 PM   #8
Rick_L
Member #2256
Default
I don't know what a Holley 4D system is for sure, but if it's what I think it is and it's only worth $500 used, it's going to leave a lot to be desired.
Thing is, if your budget is really low, then you may be best off with a carb.
Lowest end I'd think would be a TBI system from a late 80s/early 90s truck or Caprice. Next step would be a TPI system from an 88-92 Camaro/Corvette. Both have limited power potential but good characteristics otherwise.
After that would be a FAST EZ system or Holley Terminator.
Rick_L is online now   Reply With Quote
Old 01-28-2014, 09:48 PM   #9
Drumbum675
Member
Member #3829
Default
I think I'll stick with this Holley FI system for now since it works well....for the most part.
Old 01-28-2014, 10:03 PM   #10
fiddlerpin
fiddlerpin's Avatar
Member #11649
Default
Old school for me. No FI
fiddlerpin is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
