Please visit and Support Our Sponsors
Go Back   Welcome to TriFive.com 1955 - 1956 - 1957 Chevy's Bel Air Tri5 210 150 Nomad Forum, Photo Gallery and Classifieds. Here you can Buy, Sell, or Trade. Get or Give Advice, or Just Talk Classic Cars. > 55-56-57 Chevy Forum > Transmission and DriveLine Questions
User Name
Password
Register FAQ Top Posters Members Search Today's Posts Mark Forums Read
Trifive Store 2010 Newsletter 2010 Calendar 1955-1956-1957 Chevy Parts and Services = Trifive Official Sponsors
Photo Gallery Garage Photos Trifive Classifieds Calendar Arcade Oldies vBRadio
Transmission and DriveLine Questions Ask all your Transmission and DriveLine Questions. Tranmission, Drives shaft, Rear End, Gears, etc
Reply
Thread Tools Display Modes
Old 02-28-2008, 01:27 PM   #1
gmcferon
Trifive Newsletter Editor
gmcferon's Avatar
Member #3009
Send a message via Skype™ to gmcferon
Default Frame Rail Transmission coolers
I am trying to get rid of some of the clutter under my hood. I presently have a B&M transmission cooler it is 11"X11". It works great but I am contemplating a frame rail cooler. There are a several models Jegs has a "pretty" one, Permacool has a few different models don't know if it would be a good replacement. I want to avoid the small ones with the fans as I don't want any more fan noise than I already have. I also don't want to loose the cooling
Suggestions appreciated.
__________________
Cheers,
Gary,
If I had a dollar for everytime someone told me to pay attention I would have, well...no idea how much by now.
Editor Trifive Newsletter
editor@trifive.com
Newsletter
www.tri-5.com
My Pictures
http://www.trifive.com/forums/album.php?u=3009
gmcferon is offline   Reply With Quote
Old 02-28-2008, 02:05 PM   #2
lonewolf85
Senior Member 1 Gold Star
lonewolf85's Avatar
Member #3120
Default Coolers
Some times aftermarket trans coolers hurt more than they help.The engineers that designed your trans designed for long life reliability and smooth operation at engine coolant temperature. The clearances were designed for a normalized trans. If you install a aftermarket cooler in front of your radiator or some other place where it dosent run at the temperature where all the clutches drums case and other componets were designed to work at what good is that?For most applications the stock in the radaitor cooler will do an decient job. 56 ford PKs and some other vechicles had a small cooler that fit next to the transmission and some piping was run from the heater hoses to cool the fluid. Randall
lonewolf85 is offline   Reply With Quote
Old 02-28-2008, 02:50 PM   #3
Rick_L
Trifive Leaders Club
Member #2256
Default
I think you need a fan if you mount your cooler under the car.
I think that lonewolf's comments are also spot on.
And there are some aftermarket companies saying your transmission temperature shouldn't exceed 175º F. That's hogwash, all OEM installation these days don't do that.
I also think that before, during, and after you change the cooler you need a transmission temp gauge. You may not have a problem. And as said you may cause one, especially with an under car cooler and no fan.
Do you have a gauge and does it indicates high temperature?
Rick_L is online now   Reply With Quote
Old 02-28-2008, 03:13 PM   #4
gmcferon
gmcferon's Avatar
Member #3009
Default No Guage so far no problem
Where do you put the sending unit for a transmission temp guage? Is it inline. I am a little overprotective and think cool is better. probably wrong thinking however I am pushing this TH 400 with over 600HP so I thought it would be good protection.
I will be replacing the radiator on the rebuild so maybe the best thing would be just find the biggest one I can put in with transmission fittings.
My car has never over heated it is a blown 454 and I drove it from Idaho to Orlando in a couple days. The hottest it ever got was 190. On the Montana Baun. I understand I should be running it much hotter.
I don't plan on racing it, well. not often anyway.
I am doing a lot under the hood to keep things cool. High volume thermostat. Header coating, better water pump, CoolFlex hoses.
What operating temp should I be aiming for? I have both Jegs and Summit catalogs open beside me and don't see much for trans temp guages????
Thanks for your input
__________________
Cheers,
Gary,
editor@trifive.com
Newsletter
www.tri-5.com
My Pictures
Old 02-28-2008, 03:44 PM   #5
lonewolf85
lonewolf85's Avatar
Member #3120
Default Cooler
You can mount a burbon tube type guage to the pan if you weld a fitting. Just be sure it will be immersed in the fluid. A water temp guage will work it only knows how hot it is not wether it is in oil or water.The temp should run within 10to 20 degrees of the engine coolant about 190 to 210 degrees for most applications. Lots of semi trucks used electrical temp guages for the trans and rear ends. Also you can get a pyrometer from one for exhaust temp a must if you have a turbo charged engine. Randall
Old 02-28-2008, 07:50 PM   #6
the4x4pig
the4x4pig's Avatar
Member #2059
Default
Autometer sells many trans temp gauges. I have one in my truck.
Here is a page or more of them that Summit sells.
http://store.summitracing.com/egnsea...115+4294905502
There are several opinions about trans temp requirments. I would ask the folks that built yours, they prob know best. Either way a gauge is very impotant so that you know if you even have an issue. It can also warn you of impending doom if on a long trip and the trans temps start acting abnormal.
the4x4pig is offline   Reply With Quote
Old 03-06-2008, 09:42 PM   #7
MCB55-210
Senior Member
Member #4705
Default
Hadn't even crossed my mind to think about a trans temp gauge-since i'm early in the building stage I know I'll be sure to install one. Good info!
MCB55-210 is offline   Reply With Quote
Old 03-07-2008, 10:13 AM   #8
bigbopper
Senior Member 1 Blue Star
bigbopper's Avatar
Member #2079
Default TRANS COOLER ON FRAME
Hello, a good friend of mine came up with this idea, he is running a very strong 454/400 turbo set up and I decided to use it also. We are still using the cooler built in to the radiator. Do not know/remember the name brand but it was less than $25 on eBay.
hope this helps
File Type: jpg off to the muuffler shop 3-5-08 004.JPG (65.8 KB, 25 views)
bigbopper is offline   Reply With Quote
Old 03-07-2008, 11:30 AM   #9
gmcferon
gmcferon's Avatar
Member #3009
Default That loloks great
I will be interested at how hot the passenger side floorpans get.
That is excatly the model and position I was thinking of using. I hav'nt decided on a radiator yet but this looks like a good approach. So the wife gets hot feet.
__________________
Cheers,
Gary,
editor@trifive.com
Newsletter
www.tri-5.com
My Pictures
Old 03-07-2008, 12:01 PM   #10
keith
keith's Avatar
Member #1474
Send a message via Yahoo to keith
Default
Quote:
hope this helps
Bigbopper, I seen your thread about taking the car to the shop so I went in search of the cooler I seen pictured on the frame rail. I kinda like the looks of that one also.
I believe I found it, or one really close to the same design.
http://store.summitracing.com/partde...5&autoview=sku
Moroso makes a frame rail cooler that is filtered. I like that idea also.
__________________
"People with courage and character always seem sinister or crazy to the rest".
keith is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
www.keithreiter.com www.56belair.com  www.tri-5.com www.tri-fives.com www.trifive.com
www.1956chevys.com www.1957chevy.org www.55chevy.org www.56belairs.com
www.chevy-belairs.com
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
