Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
User Name
Password
Mark Forums Read
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Reply
Thread Tools Display Modes
Old 03-10-2008, 07:36 PM   #1
AustinBelair
Senior Member 1 Blue Star
Member #2662
Default Another quick question! Lokar Pedals
Sorry guys, I'm coming up with new questions everyday.
I'm still on my ordering spree and ran into a snag. I'm wanting to order all of my Lokar stuff. I'm going to get:
Foot rest
Dimmer pad
Power brake pad
BUT...
I am going to run an LS1 and I have NO idea if I can use the Lokar throttle pedal with that motor
The pedal I am wanting to run is the
Lokar '55-'57 Chevy Midnight Billet Gas Pedal - Rubber Inserts
It is located here:
http://www.rjays.com/Lokar/55-57-Lokar-Pedals.htm
The only cable I see is:
TCP-1000LS1 - LS1/ Ramjet 36" Throttle Cable - Polished
seen here:
http://www.rjays.com/Lokar/Lokar-Throttle-Cables.htm
Will this work? I planned on using a vette LS1 or later model Camaro or TA LS1 with the vette fuel line conversion or something?
If I have the money by then, I would love to go LS2 so that's always an option as well.
What say you?
AustinBelair is offline   Reply With Quote
Old 03-10-2008, 10:40 PM   #2
Tenn210
Tenn210's Avatar
Member #37
Default
Foot rest
Dimmer pad
Power brake pad
BUT...
It is located here:
seen here:
What say you?
The throttle pedal will work for a LS1 with a throttle body that uses a cable like the F-body and probably the GTO (not sure). Some or maybe all of the vette ls1's used a 'drive by wire' throttle body and they do not use a cable so you could not use the pedal unless you replace the throttle body. The guy I purchased my '01 vette motor from had already put the F-body throttle body on it so I was able to use the LOKBAG-6074 pedal. I also used a 36" cable and it was barely long enough.
Hope this helps. You can get a lot of info on the ls1 at ls1tech.com in the conversion forum.
__________________
Tennessee210 Coffee drinkers are better thinkers...I just haven't had enough.
Tenn210 is offline   Reply With Quote
Old 03-10-2008, 11:09 PM   #3
Bowtibrwlr
Member
Bowtibrwlr's Avatar
Member #4609
Send a message via AIM to Bowtibrwlr
Default
LS2's are also drive by wire as well.
__________________
Danny
57 210, 2 dr post. (Sold at Barrett Jackson, Palm Beach 08)
55 Handyman 2 dr wagon.
98 Pontiac Formula WS6 clone.
04 Pontiac Grand Prix GTP Comp G.
05 GMC Crew Cab 4x4 Duramax Dually.
Bowtibrwlr is offline   Reply With Quote
Old 03-10-2008, 11:31 PM   #4
AustinBelair
Member #2662
Default
Good to know guys, good to know.
So I know I can run that pedal setup with an F-Body LS1 but NOT the vette unless it has the NON drive-by-wire throttle body.
Are there any performance losses going to the F-Bod TB?
I'll dig around on LS1 Tech as well.
Thanks guys!
Dan
Old 03-10-2008, 11:39 PM   #5
mickeywestsr
Trifive Leaders Club
mickeywestsr's Avatar
Member #1970
Default
Looks just like the set up on the bench in front of the 55. Something that I did with the brake & clutch pedal.....I put very small washers behind each screw head to give them a little more lip to keep them on the pedals.. They hold fine.
__________________
GO VOLS
COWBOY
mickeywestsr is online now   Reply With Quote
Old 03-11-2008, 09:28 AM   #6
Hafrod
Senior Member 3 Gold Stars
Hafrod's Avatar
Member #1291
Default
Don't worry about too many questions, cause that's what the forum is for!!! When I got ready to start the mock up on my 55, I posted a ton of questions! There are ALOT of knowledgeable tri5 guys on here! There are lots of new parts out there and it's nice to have someone with experience with the particular part you are questionable about! This site is the ONLY tri Chevy site I frequent!
Hafrod is online now   Reply With Quote
Old 03-11-2008, 10:09 AM   #7
Bowtibrwlr
Member
Bowtibrwlr's Avatar
Member #4609
Default
Thanks guys!
Dan
No performance losses at all with changing TBs. There is a guy on LS1tech that goes by "Shaner" he ports and polishes TBs. You'll probably have to send him a core, but it will be well worth it.
I used to get on Tech quite a bit when I had my dyno shop, but not so much any more.
__________________
Danny
Old 03-11-2008, 07:58 PM   #8
deadcarny
Senior Member
deadcarny's Avatar
Member #1037
Default
I have a Shaner throttle body on my 99 LS1 conversion and he does great looking work. The port and polish job looks awesome and i am sure it will perform just as well on the road. He has a great reputation and is a really cool guy to chat with. If you need info, let me know. I will be on the road with my 57 in early june..!!!
Thanx DK
deadcarny is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
