Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
User Name
Password
Mark Forums Read
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Reply
Thread Tools Display Modes
Old 07-12-2008, 10:35 PM   #1
rupzip
Member
Member #5829
Default 56 Wagon Gas Tank Removal
Hey folks...just found this board. Virgin Post!
My son and I were trying to remove the $%#&* gas tank from my 56 two door wagon. Got the straps off. Got the long filler neck removed. But can't quite pivot it down enough so it gets below the axle.
What am I missing?
Thanks!
David
rupzip is offline   Reply With Quote
Old 07-13-2008, 01:35 AM   #2
gss1955
Senior Member
gss1955's Avatar
Member #4950
Default
David,
I've never owned a wagon, yet! But I remember an old timer telling me that getting the gas tanks out of them is a pain in the rear. Is the tank hitting the axle when you pivot it to get it out? Are you removing the tank with the car on the ground? If so maybe putting it up on jack stands may give you more clearance. The stands would go under the frame not the axle, this way the axle can drop down a little and hang further.
gss1955 is offline   Reply With Quote
Old 07-13-2008, 08:08 AM   #3
henrys57wagon
Senior Member 1 Gold Star
henrys57wagon's Avatar
Member #2131
Default
Hello and welcome to TriFive. Yes the wagon tanks are a pain which is why some have removed the tire well and used a sedan tank. You can do different things to get the tank out, the best is to unbolt the rear springs shackles and let the diff swing down until the tank comes out(properly support the car on stands and use a jack under the diff, or as I have done unbolt the diff at the spring perches and slide the diff forward but that is not the best if you still have the driveshaft installed. Have fun with your wagon and try and post pictures. You don't say where you live, might be some of us close to you to help you out, good day, Henry.
__________________
57 wagon 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 51/53 HenryJ Corsair's, 07 2500HD with 26.5 Prowler 5th wheel travel trailer, 09 Impala LT, CDN coordinator for ChevyTalk.org,
http://www.picturetrail.com/gallery/...wagon&x=14&y=6
henrys57wagon is offline   Reply With Quote
Old 07-13-2008, 10:03 AM   #4
carls 56
Trifive Leaders Club
carls 56's Avatar
Smile
hi ya and welcome david! sorry don't know anything about wagons i'm not going to say anything about the "virgin " thing :eek: i already get into enough tbl :p
__________________
"DRIVE AND ENJOY THEM WHILE YOU WORK ON THEM, LIFES TO SHORT"
my toys: 56 4dr 210 & 57 4dr belair
ARMY NAM VET (so proud)
carls 56 is offline   Reply With Quote
Old 07-13-2008, 10:12 AM   #5
ajunkman
Member
Member #5785
Default GAS Tank REMOVAL
Not much fun but I had to do my delivery and had to remove the rear axle. A lot of work....so while I had the axle out, I change out the leaf springs and everything else to new so I didn't have to do it later.
ajunkman is offline   Reply With Quote
Old 07-13-2008, 11:06 AM   #6
56-210sedan
Senior Member 4 Gold Stars
56-210sedan's Avatar
Member #2444
Default
Welcome to TriFive
__________________
55 Belair 2dr Sedan 350/350 loving every minute of it.
56-210 2dr Sedan c4 front/rear suspension, and not sure when the ride will roll.
Marty
56-210sedan
saccc567.com
56-210sedan is offline   Reply With Quote
Old 07-14-2008, 11:43 PM   #7
rupzip
Member
Member #5829
Default
Thanks for the advice.
Maybe i should just bolt it back up in there...!
The problem is no fuel -- I replaced the fuel pump, so figured the gas tank was plugged. Now -- I just dont know what to do.
I live in Denver BTW
Old 07-14-2008, 11:50 PM   #8
gss1955
Senior Member
gss1955's Avatar
Member #4950
Default
David,
You'll probably better off dropping the rear and taking the tank out. This you can have it clean or replace it. Inside the tank in the end of the fuel line is the "sock" when a tank start to corrode the dirt and rust can clogged the sock. If you're not getting any fuel and you've replaced the pump a clogged sock is deffinately possible.
Old 07-15-2008, 12:16 AM   #9
Chevynut
member
Chevynut's Avatar
Member #1769
Default
I agree with going ahead and removing the tank to clean or replace it. YOu don't want years of junk in your fuel lines and carb. While you have the axle out you can clean it and paint it too.
Welcome to Trifive...I'm only an hour north of you.
Chevynut is offline   Reply With Quote
Old 08-10-2008, 10:40 PM   #10
oewall
Member
oewall's Avatar
Member #5300
Default pain
Yes they are a pain I just dropped the tank in my 55 wagon today and it looks like it is about ready to fall out until you finally have to kick it out!
any advice about coating the tank, looks like a little light rust coating inside. I was surprised the tank acutally had a drain on it!
Orie
oewall is offline   Reply With Quote
Reply
Tags
gas tank
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
