Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Power Steering - Rack & Pinion - 605
User Name
Password
Mark Forums Read
Trifive Power Steering - Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Reply
Thread Tools Display Modes
Old 08-05-2008, 09:18 AM   #1
culprit
Member
Member #5930
Thumbs up Confused again
Hey guys Thank you very much for all your help. Now im haveing a problem with the 605 pump leaking fluid out of the top seal. The pump has a small hole to remove the o ring that holds the top cap in place. I have fluid leaking out of this hole and around the cap or seal? It seems to me that the cap is not seating down far enough to block this hole and seal the pump. If there is any thing you can do to help I thank you in advance.
culprit is offline   Reply With Quote
Old 08-05-2008, 09:46 AM   #2
57chevyman
Senior Member 1 Gold Star
57chevyman's Avatar
Member #1420
Send a message via ICQ to 57chevyman Send a message via AIM to 57chevyman
Default
When does this happen? Is the fluid leaking when it is idling or when you apply pressure from turning the wheel?
It sounds like you have too much fluid in the pump reservoir. Check the fluid level when cold and make sure it is in the proper fill range.
If you are turning the wheel without the engine runnning, you will have fluid spit out of the pump through the vent hole.
Pete
__________________
Pete V.
57Chevyman
1957 210 Delray CC
2124 25,644
57chevyman is offline   Reply With Quote
Old 08-05-2008, 10:00 AM   #3
Jalapeno
Member #4149
Default
Quote:
No such thing as a 605 PUMP, do you mean the 605 GEAR? If so, the 605 gear round cap is notorious for leakage in this area, the housing has burrs even when new and the o-ring does not seal the cap properly. The only way to permanently stop the leak is to remove the burrs and install a new o-ring.
The correct method for checking PS fluid is when HOT, at idle, wheels straight.
No fluid should escape the pump when turning the wheels, hot or cold, engine running or not.
__________________
Jalapeno
Jalapeno is online now   Reply With Quote
Old 08-05-2008, 08:37 PM   #4
culprit
Member
Member #5930
Thumbs up 605 Gear box
Thank you for your quick response guys. I am trying to help my father with a restoration. We have had a heck of a time with this conversion. So if I understand you guys correctly, the gear box is vented and will only leak if it is over filled with fluid? I had the understanding the gear box had to be air tight? I thought the pin hole on the top of the gear box was to remove the O ring that holds the cap in place? Not a vent for the air? Thank you for all your help, Culprit
Old 08-05-2008, 08:55 PM   #5
Rick_L
Trifive Leaders Club
Member #2256
Default
We have a terminology problem here.
You apparently called the steering box a "pump", and you called the steel snap ring that holds the top cover on the 605 box an "o-ring". And then the replies took off. Not blaming you or anyone who replied, just trying to sort things out.
The power steering pump is on the front of the engine and it has a vented cap. The steering box is closed and is supposed to be sealed up.
The real confusion comes over the "snap ring" and "o-ring". The steel snap ring that you can see doesn't seal anything, it just holds the cap in the box. The hole in the side of the housing for removing the snap ring is just for that. And nothing else. NO oil should be there, and no air venting either.
When you take the snap ring off and remove the top cover, you will find a rubber o-ring that is supposed to seal the top cover. No oil should make it past this rubber o-ring.
Now, go back and read what Jalapeno said about the rubber o-ring and the cover. Dealing with that as he described should fix your problem.
And yes these do have a tendency to leak.
Rick_L is offline   Reply With Quote
Old 08-05-2008, 09:28 PM   #6
culprit
Member
Member #5930
Default Thank you
Sorry about the confusion, it is the metal o-ring im having problems with so i will remove the cap and check the rubber o ring. Thanks again. We could not have done these things without your help.
Old 08-05-2008, 09:50 PM   #7
57chevyman
57chevyman's Avatar
Member #1420
Default
Sorry for any confusion I may have caused to help out here.......I was thinking pump and not gear.....
__________________
Pete V.
57Chevyman
1957 210 Delray CC
2124 25,644
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
