Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Power Steering - Rack & Pinion - 605
User Name
Password
Mark Forums Read
Trifive Power Steering - Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Reply
Thread Tools Display Modes
Old 08-18-2008, 09:29 PM   #1
JoeB
Member
JoeB's Avatar
Member #712
Default Power Steering - 6 cylinder 55 Belair
Does anyone make a kit for installing power steering on an original 235 - 6 cylinder engine in a 55 Belair? I've seen several kits out there for V8's, but I am looking specifically for the bracket to mount the pump. Also, I'm not interested in having it original,...just something that will bolt up to the 6 cylinder engine.
JoeB is offline   Reply With Quote
Old 08-19-2008, 12:38 AM   #2
557B210
557B210's Avatar
Member #5571
Default
Joe....Years ago I changed my daughters 6 cylinder 69 Camaro over to power steering....so I believe the same brackets should work on your 55
__________________
_______________________________
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Old 08-19-2008, 11:25 AM   #3
Jalapeno
Senior Member 1 Gold Star
Member #4149
Default
David, unless your 69 Camaro's 250 six cylinder was pulled and it was retrofitted with a 55-57 235 six cylinder, the brackets, etc won't work with Joe's 55.
Joe, as you know, the 55-57 Chevys (and 58-59 too) used a generator mounted pump, so there were no special six cylinder brackets for 55-57. For the purposes of this discussion it was the same as the V8 stuff.
That said, I presume you want to put a late model pump on your engine. It can be done, but requires some fabrication and replacing of some OEM engine parts.
First, you can use the 1960-62 235 six cylinder parts to mount a modern pump. The trick is finding all the parts, they are scarce, and usually missing one thing or another. What you would be looking for is the three pump brackets and all the special hardware, including the two head bolts that have the extra studs on top for the main pump bracket; also the pump pulley, double water pump pulleys, and ALL the crank pulleys with balancer, since you will be removing your RIVETED crank pulley and balancer. The pump itself is not hard, you can use one from just about any 60-75 Chevy car or truck, make sure it has a KEYWAY shaft, not a BOLTED shaft.
Another choice is to use the 53-54 PS pump, bracket and pulleys. This is a little harder, in that you would have to modify the bracket to fit the different bolt pattern on the water pump. These parts ere very difficult to find as well, especially the double crank pulley. You could use a 292 six cylinder double crank pulley, but it must be modified to fit a 235.
The parts on the engine are, of course, only half the power steering system. You can use a more modern pump to power the original linkage assist parts (available in reproduction, so you don't have to rely on old parts), or it can power a new steering gear like CPP's 500 series gear. That choice will entail modifying (shortening) your stock column, and cannot be used with a column-shifted manual transmission (column shifted automatic transmissions are OK), or replacing the column with an aftermarket column made specifically for the newer gear.
I know all this sounds very complicated, but it's really not, once you know all the details. Reread this discussion several times and maybe it will gel, or send me a PM and I'll try to help make sense of all this.
__________________
Jalapeno
Jalapeno is offline   Reply With Quote
Old 08-19-2008, 12:19 PM   #4
557B210
557B210's Avatar
Member #5571
Default
Jalapeno...Thanks for pointing that out....Yes it was a 250....However, as you pointed out, it would be possible to do the same with a 235, if you could find or fabricate the brackets for a pump..
__________________
Old 08-19-2008, 06:58 PM   #5
George Bafus
Senior Member
Member #1327
Default
Here's the power steering pump/generator installed on my '58 Biscayne with a 235. It's powering a 605 box. A similar arrangement should be possible for a '55. I'd recommend a CPP 500 box. I'm not positive, but I think the standard generator bracket could be used on a '55, perhaps modified. A different mounting bracket was needed on my '58, because the engine mounts were moved to the side that year. The pump wouldn't clear the side mount. The generator/PS pump sits higher on the engine than the standard generator.
__________________
Previously owned: 1955 Bel-Air 4 door sedan
George Bafus is offline   Reply With Quote
Old 08-19-2008, 07:39 PM   #6
airmentbob
airmentbob's Avatar
Member #3340
Default
my pops has a 64 nova with power steering but the pump sits on top, the alternator mounts off the bottom, with the rest of the gear it is built into the steering linkages near the oil pan.i guess it's a steering assist. I don't really know if you can use the same brackets on a 235, but this motor on the 64 is a 194.
airmentbob is offline   Reply With Quote
Old 08-19-2008, 07:43 PM   #7
TriFiveYoungMan
Member
Member #6225
Default factory power steering
Joe,
Too bad u already said u dont want fctory pwer steering, I have a 56 235 w/ a working factory power steering unit, all bracets that would be needed too.
John
TriFiveYoungMan is offline   Reply With Quote
Old 08-20-2008, 08:44 AM   #8
JoeB
Member
JoeB's Avatar
Member #712
Default
Wow, thanks for all the suggestions and help. John, the only reason I said that I really wasn't interested in a factory unit would be because of finding one. Again, I will send you a PM if that's okay.
By the way everyone, how is the factory PS system compared to a newer bolt on system? Would I be better off with a similar system that George has (using the pump on the back of the generator coupled with a CPP500?) With George's system, I would not have to find brackets for the pump. It would mount to the rear of the original generator?
Jalapeno,...I'm stilling letting it gel. Forgive me, if I've repeated your advice above. I think the pump on the back of the generator with a new 500 box would be the way to go eh?
Joe
Old 08-20-2008, 10:20 AM   #9
Busted_Knuckles
Busted_Knuckles's Avatar
Member #5782
Default
Joe
I also have a factory pwr steering set up if you need one. I have the pump, all the steering linkage with piston & hoses and I think the gen. bracket. I can't attest to weather or not the pump is in working condition as it was in the back of the car with a bunch of other stuff when I bought it.
__________________
That was the 'Ironbox' Twins, Brenda and Shirley Weintraub, coming to you live from the ladies' room at Tubby's Drive-In.
Busted_Knuckles is online now   Reply With Quote
Old 08-20-2008, 10:22 AM   #10
MikeB
MikeB's Avatar
Member #3574
Default
Quote:
Joe
I don't have any direct experience with stock Tri-5 power steering, but I did drive a 66 pickup with OE power steering, which, like the Tri-5s, used a manual box and a hydraulic ram pushing/pulling on the center link (aka relay rod). I have to say I was very impressed, even though it was something like 5-6 turns lock-to-lock. It was very smooth, linear, certainly not too sensitive, and didn't make any noise.
Of course, since it was a 66 pickup, my comments above may be like saying, "I'm not a doctor, but I play one on TV."
__________________
1955 210 sedan,327, Brodix IK-180 heads, Jones cam, Muncie M20, Wilwood 4-piston / 11.75" front brakes.
MikeB is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
