Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
User Name
Password
Mark Forums Read
Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Reply
Thread Tools Display Modes
Old 10-02-2008, 08:05 PM   #1
Black56
Senior Member
Black56's Avatar
Member #5192
Send a message via Yahoo to Black56
Default Need info on wheels size. Please
Going to be doing my 2" suspension drop in a couple weeks. Im planning on putting some Intro 17" wheels on the 56. Except for the 2" drop all else is stock. I read 1 post that said 17x7 with a 4.5" BS.and a 225 tire is a good fit for the front. Is this correct? 2nd what is the max tire size for the rear and what should the backspace for the wheel be? Could I use a 17x8" for the rear? I do not want rubbing to be an issue. Thanks guys!
__________________
56 2 door post. 265 200r4.
" A stupid question is better than a stupid mistake."
Black56 is offline   Reply With Quote
Old 10-02-2008, 08:31 PM   #2
Rick_L
Trifive Leaders Club
Member #2256
Default
If you have dropped spindles the 4.5" backspace on the 17x7 is good. If you have stock drum brakes 4" backspace will work. If you have stock spindles and a disc conversion then a 17x7 probably won't work at all. The 225 tire is a good choice.
On the back you can fit a 275 tire if you do the backspacing exactly right, and your car's body and frame are aligned correctly, etc. A 255 tire is a more conservative choice.
Rick_L is offline   Reply With Quote
Old 10-02-2008, 08:42 PM   #3
Black56
Senior Member
Black56's Avatar
Member #5192
Default
Thanks for the info Rick. The fronts are Heidts 2" drop spindles. I dont think they set the wheels out more than 3/8" So I assuming an 8" rim with 4.5" bs is the norm on the rear as well?
__________________
Old 10-02-2008, 08:43 PM   #4
56Mark
Senior Member 1 Silver Star
56Mark's Avatar
Member #5675
Default
Rick,
Why won't a 17 x 7 work with stock spindles and disc brakes? Just curious because that is what I have and I haven't decided on what wheels I want to run.
__________________
56-210 2 dr sedan
Mark
56Mark is offline   Reply With Quote
Old 10-02-2008, 08:49 PM   #5
Black56
Senior Member
Black56's Avatar
Member #5192
Default
Quote:
Originally Posted by 56Mark View Post
Rick,
I think maybe because stock spindels with rotors set the wheels out about an inch per side. I think anyways. Thats what I have now is stock spindels with disks. I really dislike the way it set my wheels out and hurt my turning radius. So Im changing the spindels. Ive always wanted to lower mine. After seeing some of the lowerd car pics here with billet wheels Im sold I love the way they look.
__________________
Old 10-02-2008, 09:42 PM   #6
Rick_L
Member #2256
Default
56mark, black56 summed it up pretty well. Your tires are going to rub with that setup, even worse if the car is lowered, for the reasons he stated. They don't make wheels with enough backspace to fix it.
Old 10-02-2008, 10:41 PM   #7
56Mark
56Mark's Avatar
Member #5675
Default
I haven't put the disc brakes on yet and I think they are only supposed to set the wheels out about 3/8". So, if they do set out more than that, what you are saying is that the dropped spindles will get it back to little or no offset? Will the disc brake parts transfer to the dropped spindles? They are basically the same set up as the stock spindle set up from CPP with the large GM calipers. http://www.classicperform.com/Store/...s/5564WBKS.htm I'm glad I saw this thread since I haven't put them on yet and I don't want the wheels set out. I think I can live with 3/8", but if it works out to be 1", I will use the dropped spindles or a different set up.
Thanks again!
__________________
56-210 2 dr sedan
Mark
Old 10-02-2008, 10:47 PM   #8
Tom$lick
Senior Member
Tom$lick's Avatar
Member #3074
Default
I have a 57, disc brake conversion from CPP, 2in drop spindles AND 1.5in drop springs in front. I'm running a 17x8 with a 5.25 backspace, 235/45 tire. I haven't trimmed the fender lip at all and I rarely scrub even at full lock. I still have the factory stops on the front too. Out back, stock wheel wells. 1in drop leafs, 2in blocks. 17x9 with a 5.25 backspace, 255/45 tire. It's tight but there's a little wiggle room. Wheels are FOOSE Legends.
Tom
Tom$lick is offline   Reply With Quote
Old 10-02-2008, 10:48 PM   #9
Black56
Senior Member
Black56's Avatar
Member #5192
Default
I did a little research on this and Im pretty sure that if you use a stock spindel the only rotor that you can use is the old Chevelle rotors. When you put those rotors on the stock spindel it will always move the wheels out the same for you, me or anyone that does it. I know mine moved the wheels out almost 1" per side, and killed my turning radius. The brakes work fine. But for me personally im not satisfied with that. I could have this all wrong but I think im correct.
__________________
Old 10-02-2008, 10:50 PM   #10
Black56
Senior Member
Black56's Avatar
Member #5192
Default
Quote:
Tom
Wow Tom I bet that baby is on the ground! Do you have any pictures? Does it scrub on everything being that low? Thanks
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
