Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
User Name
Password
Mark Forums Read
Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Reply
Thread Tools Display Modes
Old 12-02-2008, 08:52 PM   #1
jclobue57
Member
Member #7142
Default to sub frame or not to subframe -advise anyone
My 57 rode like a tank, and I want to do something about it! I could p urchase all the bells and whistles,air bags disk brakes , rack and pinion, etc. but , Lord , I don't have that kind of money layn around, I just thought it would be less exspensive to put a sub frame on it, which leads me to the question, Does any body out there know what year make or model car I need to be looking for to get the sub frame from? what will fit the best? I would really love some input on the subject, thanks Chad
jclobue57 is offline   Reply With Quote
Old 12-02-2008, 09:34 PM   #2
tjsdelivery
Trifive Leaders Club
tjsdelivery's Avatar
Member #3887
Default
Not sure if the time and money of a subframe is gonna get you any farther ahead than some of the basic improvements you can make with what you have?
If it rides as you say, rebuild the frontend (new control arm bushings, shocks, disc brake kit, poormans powersteering,sway bar), new rear springs and shocks, sway bar and it should make quite the improvement
__________________
TJ
tjsdelivery is offline   Reply With Quote
Old 12-02-2008, 09:45 PM   #3
old school 55
Senior Member 1 Blue Star
Member #1571
Send a message via Yahoo to old school 55
Default alot of work.
it's alot of work either way you go. but the camaro sub frame or a nova sub frame seem to be the best candidates. mine is in the process of camaro sub frame from a 76 vintage seems to fit pretty well. others have used different years. im sure youll catch some flack for even thinking of it. good luck though
old school 55 is offline   Reply With Quote
Old 12-02-2008, 09:48 PM   #4
D.S.
Senior Member 3 Gold Stars
D.S.'s Avatar
Member #42
Send a message via ICQ to D.S. Send a message via MSN to D.S. Send a message via Yahoo to D.S.
Default
That's a lot of fabrication and headaches....
But here is some info http://www.hotrod.com/howto/42838/ The article doesn't get into all the work attaching the front sheet metal back on to the subframe...
Also you will most likely have to rebuild the subframe unless you can find one with new bushings and other hardware already installed...
__________________
Dave...
Some Days Its not Even Worth Chewing Through The Restraints....
D.S. is offline   Reply With Quote
Old 12-02-2008, 10:03 PM   #5
NickP
NickP's Avatar
Member #2134
Default
Chad! Certainly, your time is worth something.................................. I see these routes taken by folks, and few if any give the end result that was perceived in the beginning. Certainly, your time is worth something………………………………………………… Oh, did I say that already? If you are going to expend time, energy, and most importantly………………………………………………………MONEY, then do something to the car that will benefit you and give a positive ending. Chad take the money you might have budgeted and rebuild the suspension, front an rear, new shocks, bushings, springs and an anti roll bar (sway bar) will improve the ride.
If your just bound up and want a new front clip, there are plenty of offerings from folks like Jimmy Myers, AME, Progressive or several others. At least they are engineered specific to the task and the effort will get the results quicker.
Just my 2¢
__________________
NickP is offline   Reply With Quote
Old 12-02-2008, 10:03 PM   #6
henrys57wagon
Senior Member 1 Gold Star
henrys57wagon's Avatar
Member #2131
Default
The suspension components are basically the same so you are not going to gain any better ride bu replacing the subframe. Adding disc brakes to your frame will not be any more expensive than replacing all the used brake components of a used frame. You may still have to buy a replacement MC, brake lines, hoses. I built my own air bag over leaf rear suspension at no real cost to me. I also built my own R&P system, the Camaro/ Nova is still a steering box. I also bought used Chev, not tri five, headers and modified them to fit the BB clutch linkage. Anyway enough of this, just trying to say changing something is not always better and with a bit of ingenuity you can have a good driving car. PS you do not have to do all the mods at once, get the car drivable and enjoy it and work at your own pace/ money, good day, Henry.
__________________
57 wagon 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 51/53 HenryJ Corsair's, 07 2500HD with 26.5 Prowler 5th wheel travel trailer, 09 Impala LT, CDN coordinator for ChevyTalk.org,
http://www.picturetrail.com/gallery/...wagon&x=14&y=6
henrys57wagon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
