Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
User Name
Password
Mark Forums Read
Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Reply
Thread Tools Display Modes
Old 12-03-2008, 07:05 PM   #1
55chevy292
Member
Member #4169
Default Tubular a-arm and offset shaft questions
I bought a set of tubular a-arms for my 55 and assembled them with my stock cross shafts and new bushings. Once i got ready to assemble the front end, the upper control arm hit near the front of where you put it on. Where i got them from recommended grinding the area. There is no way to grind it enough for them to clear.
I have now purchased a set of offset a-arm shaft to use with my stock control arms because i am running the 500 steering box. (I understood that they correct the tracking issues)
Would the offset shaft correct the issue of the tubular control arms???
55chevy292 is offline   Reply With Quote
Old 12-03-2008, 07:19 PM   #2
acardon
Trifive Leaders Club
acardon's Avatar
Member #1888
Default
I hope someone corrects me if I'm wrong. I thought the upper cross shaft helped camber by moving the ball joint out and the control arm helped caster by moving the ball joint to the rear. http://www.trifive.com/garage/57%20C...Manual/3-3.gif
__________________
Don
acardon is online now   Reply With Quote
Old 12-03-2008, 07:22 PM   #3
Rick_L
Member #2256
Default
Probably not. Whose arms do you have? Any photos?
Rick_L is online now   Reply With Quote
Old 12-03-2008, 07:28 PM   #4
55chevy292
Member
Member #4169
Default
I dont know exactly who makes the a-arms. I bought them from Lee Cape who owns Double Nickle out of Whitehall,Ga. He exclusively sells tri-five stuff. Everything i buy for my 55 comes from him and this is the first time i have ever had problems with anything.
I dont have pics of the a-arm on the car. Sorry
On the 2nd picture it would hit near the bushing on the front side(left).
Old 12-03-2008, 07:50 PM   #5
Rick_L
Member #2256
Default
acardon, you are correct about the way the shafts and arms are made. But if you have the ability to get more camber, you can get more caster too.
292, does the tube on the control arm hit the bracket that the control arm shaft bolts too, or is it something else? If it's hitting that bracket, I understand not grinding on it until there's a hole in it. But what about giving the interfering part of the bracket a serious thump with a BFH? Or even heating it up and then hammering on the interfering area?
The control arms I have are similar to yours but not the same. They have the ends of the tubes pinched into an oval shape where they weld to the bushing sleeves. They have lots of clearance everywhere.
I woudn't recommend grinding on the tube part of the control arm, but cutting it for clearance and then welding a flat piece in the hole (making that area a D shape) might also be an option.
Old 12-03-2008, 07:54 PM   #6
jpblues
Senior Member 1 Blue Star
jpblues's Avatar
Member #2842
Default
what are you gonna do with your original a frames now?
__________________
James
jpblues is offline   Reply With Quote
Old 12-03-2008, 07:59 PM   #7
55chevy292
Member
Member #4169
Default
I am thinking about taking and running offset shafts in my stock control arms since i am running a 500 series box.
and then taking my tubular control arms and getting my money back
Old 12-03-2008, 08:34 PM   #8
JasonR
Senior Member
JasonR's Avatar
Member #5089
Default
Quote:
I'm not going to re-use my stock uppers...you need them?
I had the same issue on my passenger side with Heidt's uppers, the driver side fit fine. I think when they pressed the bushings in they bent the a-arm. Do both of yours rub or just one? I sent the one back and waiting on the new one. Mine wouldnt even bolt up it was hitting so bad.
__________________
57 Bel Air 2 door HT under construction
www.picturetrail.com/JasonR1957
JasonR is offline   Reply With Quote
Old 12-04-2008, 09:55 AM   #9
Old Buzzard
Senior Member 3 Gold Stars
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
Question Hmn..
I don't think the offset shafts will do anything concerning the use of a 500 box. What is it you are trying to do??
As for the return at Cape's place ??
BTW, my Fatman a arms clear the mounts, just fine. They are the design that moves out, and back, for more + caster.
I don't like the location of the bump stop pad, so I'll be "modifying" that.
__________________
Chuck
Injector inspector.
55 210 sedan/ LQ9 tyrfryer..:evilgrin0002:
Hotrodding and dragracing since 1955.:eek:
USAF 1960-1964
Old Buzzard is online now   Reply With Quote
Old 12-04-2008, 10:25 AM   #10
557B210
557B210's Avatar
Member #5571
Default
292....This statement caught my attention in your last post:
"I am thinking about taking and running offset shafts in my stock control arms since i am running a 500 series box."
I have installed the 500 box as well....Do I need to put in offset shafts in my control arms? If so, for what reason?
__________________
_______________________________
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
