Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
User Name
Password
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Parts on Ebay
Closed Thread
Thread Tools Display Modes
Old 10-04-2006, 07:13 PM   #1
trifive
trifive has made a donation to the forum!
trifive's Avatar
Member #1
Default Tire Size Specs
Here is some info on tire sizes for the Trifives
http://www.trifive.com/tire_size_chart.htm
Hope this helps
Otis / Trifive
trifive is offline
Old 10-30-2007, 09:28 PM   #2
55redshoebox
Senior Member 1 Blue Star
55redshoebox's Avatar
3D Tetris Champion!
Member #4030
Cool tire and wheel combo
just to add another tire size and wheel combo,my 55 has stock rear suspension lowered 2" in rear,stock wheelwell housings,stock inner lip and i run a 275/60R15 on a torque thrust II custom 15 X 8 with a 4 1/4" back space.no rubbing at all even on high speed corners.to take off or change the tire is quite a process,jack the body all the way up, put lincoln 10 ton stands under rear frame, unbolt the bottom of the shocks,drop the rearend all the way down, let the air out of the tires and carefully remove wheel,push bottom in and guide top past lower wheelwell.sometimes i wonder if it's worth it,but it looks really cool,in my opinion.hope this helps.
55redshoebox is offline
Old 11-21-2007, 09:55 PM   #3
Barry Sims
Member
Member #4193
Default
I just bought a 55 Bel Air and want to put new tires and wheels on it. It was a 1/4 mile car and I am going to tone it down. Am looking at smoothies. Currently it has Billet Specialty 15" on the front and 16" on the back. Am hoping to go 16" front and back but am not sure what wheel width to get, offset, and tire size. I am brand new to this stuff. Hopefully I can figure out your chart and use it. Thanks. Barry
Barry Sims is offline
Old 11-21-2007, 11:24 PM   #4
56-210sedan
Senior Member 4 Gold Stars
56-210sedan's Avatar
Member #2444
Default
Hi Barry, and welcome to trifive.com here is a spreadsheet you can use to help you with your fit http://www.trifive.com/forums/showthread.php?t=5165
__________________
55 Belair 2dr Sedan 350/350 loving every minute of it.
56-210 2dr Sedan c4 front/rear suspension, and not sure when the ride will roll.
Marty
56-210sedan
saccc567.com
56-210sedan is offline
Old 05-14-2008, 09:20 PM   #5
tjn
tjn has made a donation to the forum!
tjn's Avatar
Member #4268
Default
Marty, I came across your email about tire sizing for trifives from April of last year and for some reason, I can't open it. Could you email it to me? nolans@insightbb.com Many thanks, TJN 56 Nomad. PS has disks all around 2" drop in front. Had to use (temporarily) 7"X15" rallys w. 4" offset to clear rear discs.
tjn is offline
Old 05-14-2008, 10:32 PM   #6
chevman57
Sr. Administrator
Trifive Leaders Club
chevman57 has made a donation to the forum!
chevman57's Avatar
Member #264
Default
I got a pair of 295/50-15s under the back end of my 57 using aftermarket rally wheels with 4 1/2" backspacing. Of course i had rolled the fender lip up years ago. I can get a finger between the fender lip and tire and also a finger between the tire and leaf spring.
__________________
http://s1181.photobucket.com/albums/x437/chevman57/
http://www.cardomain.com/id/chevman57
http://www.trifive.com/forums/album.php?albumid=1177
1957 2dr sedan Bel Air, owned since 1978
1972 Chevelle Malibu, awaiting rebuild,owned since 1979
chevman57 is online now
Old 04-13-2009, 10:35 PM   #7
nomad57
Member
Member #6693
Default
Got a set of 295/50/15 on 15x10 rally wheels with a 6" back spacing under our 57 nomad the leaf springs have been moved into the frame. Dad had a 57 belair with n-50 on a set of 15x12 rally wheels the leaf springs were moved to the inside of the frame.
nomad57 is offline
Old 04-14-2010, 09:24 PM   #8
rodman29
Member
Member #12892
Default Thanks 4 the Chart
Thanks for posting this. Just getting started on my '57 2dr. sedan so need all the info I can find. I'm going to install a Ford 9" rearend. Would you stick with the stock width?
rodman29 is offline
Old 04-15-2010, 08:56 AM   #9
carls 56
carls 56's Avatar
Smile
Quote:
hi barry and welcome. good to have you here.
thanks otis.
__________________
"DRIVE AND ENJOY THEM WHILE YOU WORK ON THEM, LIFES TO SHORT"
my toy: 56 4dr 210
ARMY NAM VET (so proud)
carls 56 is offline
Old 09-07-2010, 11:34 AM   #10
twincc55
Senior Member
twincc55's Avatar
Member #3905
Default Tire Size Conversion
I am currently looking at replacing the rear tires on my 55. The car has a mini-tub setup and is currently running Micky Thompson "N50 x 15" on 10" Weld wheels on the back. I would like to go to a little smaller tire but keep the 10" wheels. I don't know what size the current "N50"s" are and what would anyone recomend for replacement. Thanks for any help I can get!
__________________
Mike
twincc55 is offline
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
