Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Metal Fabrication & Repair Questions > Metal Fabrication and Repair Questions
User Name
Password
Metal Fabrication and Repair Questions Ask all your Metal Fabrication and Repair Questions.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 01-27-2009, 06:53 PM   #11
busterwivell
Senior Member 1 Gold Star
busterwivell's Avatar
Member #2674
Default
Huh.......I wouldn't have thought to do it that way, but NICE JOB! I've got my 47 2 door sedan on a rotissorie now. The floors are solid, but the trunk floor is swiss cheese. I believe I'll be able to R & R a trunk floor on the rotissorie fine, then, like you, be able to paint the u nderside on it. Thanks for provoking thought!
busterwivell is offline   Reply With Quote
Old 01-27-2009, 07:02 PM   #12
auggie56
Trifive Leaders Club
auggie56's Avatar
Member #3147
Default
Matt. Thank you for this post. You have given me finaly an idea I can use, without ending up with a fiasco.
__________________
auggie56 is offline   Reply With Quote
Old 02-01-2009, 04:05 AM   #13
Mikeh57
Member
Member #5821
Default
How long did this take you ????
Mikeh57 is offline   Reply With Quote
Old 02-01-2009, 10:42 AM   #14
55PaulyT
Member
Member #3524
Default
Matt,
Great illustrations!
I have two questions: 1) Along the front edge of the floor pans where and what type of weld are you using here, is is along the top, or is it underneath using some form of spot weld? 2) Along the back edge of the floor, is this all drilled out for plug welds?
I am debating a full floor replacement and am gathering as much info on this to help make a decision.
55PaulyT is offline   Reply With Quote
Old 02-05-2009, 01:32 PM   #15
matt0283
Member
matt0283's Avatar
Member #6197
Default
Sorry I didnít answer everyoneís questions earlier. I havenít been on the forum in a few days.
Mikeh57,
I did the complete floor in about 5 days. This included cleaning and welding new patch panels on the floor braces. My center brace was in good shape. I had to weld ends on the long curved brace under the rear seat. Then I welded the 2 floor sections to the floor braces that were bolted to the frame.
The actual installation of the completed floor/frame to the body took about 1.5 hrs. I did everything myself. If you have an extra set of hands, it might take less time. I was very careful about measurements while I built the floor on the frame. It might take longer to reattach the full floor to the body if you make mistakes during this process.
55PaulyT,
Along the front edge of the floor pan near the toe boards I will use a rosette weld, butt weld, or plug weld. For now I attached the floor to the body using sheet metal screws. Along the back I drilled holes for another series of plug welds. I used a 5/16 inch drill bit about 2 inches apart.
I really liked installing the floor this way. Iíve done it both ways now, inside the car and like this example as a one piece assembly. Most of my braces were in good shape so I was able to save a few dollars. Buying a one piece floor does save time but they usually cost more. If youíre worried about alignment then the one piece floor might be worth the price for simplicity.
Iím in the process of replacing my exterior sheet metal. Iím working on the driverís side rocker/a pillar area. Iíll weld the rockers to the floor once Iím satisfied with my door gap and have my quarter panel section in place. Iím not going to make the mistake that I made on the tail pan. I need to grind a few welds to realign the tail pan with the trunk lid for a more consistent gap along the bottom of the trunk lid.
Matt
matt0283 is offline   Reply With Quote
Old 02-05-2009, 06:45 PM   #16
J&Jhotrods
J&Jhotrods's Avatar
Member #4118
Default Certainly more than one way...
....to skin a cat. Nice work Matt! My biggest fear of doing it that way is discovering unseen structural damage half way through the job. But you got it done and it looks good.
Jay
J&Jhotrods is offline   Reply With Quote
Old 02-05-2009, 07:18 PM   #17
oldcarnut56
Senior Member 1 Silver Star
oldcarnut56's Avatar
Member #7077
Send a message via MSN to oldcarnut56
Default
Great job. thanks for the pics too. Can't wait to start doing the same to my 56.
__________________
Bobby
4 drs 4 more fun!! 56 Belair, 56 210, 56 4dr wagon
oldcarnut56 is offline   Reply With Quote
Old 04-19-2009, 11:19 PM   #18
Intel55
Member
Member #8541
Default
Incredible work for doing this by yourself!
I have one question about the full floor pan. Where did you purchase it?
I see the one from Danchuck @ $1300.00 versus the CARS on@ $2700.00 or so. I assume that the CARS is made USA and the Danchuck is China. I am not content with buying the China version. Any advice on quality floor pans/braces, etc would be great.
My '55 has lost inner and out rockers as well as all the outboard braces. I really only need about the floor area from the A pillar area to front of the rear wheel well and 8" (well to where the seat mount, which is gone) into the floor. I have to get the car acid dipped before I make a final decision.
Intel55 is offline   Reply With Quote
Old 04-20-2009, 10:52 AM   #19
StarCityGene
Senior Member 1 Blue Star
StarCityGene's Avatar
Member #304
Default
I have sold many of the Taiwan complete floors here on TriFive with no complaints. The one that CARS list you must buy the inner rockers $65.00 each and they have a seam down the middle. It has been reported that they are also too short at the inner wheel well area where the floor mets the trunk. Check our listing in "Classified", we have them listed for $879.95 plus shipping.
__________________
StarCityGene
www.starcityclassicparts.net
www.picturetrail.com/starcitygene
Have you thanked a Veteran for your freedom today?
StarCityGene is offline   Reply With Quote
Old 04-20-2009, 10:59 AM   #20
Ari
Ari's Avatar
Member #5728
Default
Quote:
Gene,
Are your floors different from Danchuck? Are the Danchuck floors short?
Thanks,
Ari is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
