Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Metal Fabrication & Repair Questions > Welder advice, Hand tool Advice Shop Tool.
User Name
Password
Mark Forums Read
Welder advice, Hand tool Advice Shop Tool. This is a section to ask for help/advice on all your tool questions. What welders work best and what shop tools work best, How to use a welder, and any other tools. Remember if you have tools for sale they should be put in the classifieds.
Reply
Thread Tools Display Modes
Old 12-23-2008, 03:25 PM   #1
bfr57
Senior Member 1 Blue Star
Member #7029
Default Solvent for solvent tank
Anybody recommend a cleaning solvent for a solvent tank, perferably non-flamable?
bfr57 is offline   Reply With Quote
Old 12-23-2008, 03:59 PM   #2
JasonR
Senior Member
JasonR's Avatar
Member #5089
Default
I know you said non-flamable but they just dont seem to work as well. I use mineral spirits in my parts washer. To be on the safe side I don't leave it plugged in unless I'm using it.
__________________
57 Bel Air 2 door HT under construction
www.picturetrail.com/JasonR1957
JasonR is offline   Reply With Quote
Old 12-23-2008, 04:37 PM   #3
r66ss
Trifive Leaders Club
r66ss's Avatar
Member #2133
Default
Quote:
me too,
odorless spirits, and keep lid shut, no pump on when not in use either
__________________
Randy
www.picturetrails.com/mrchevelle
r66ss is offline   Reply With Quote
Old 12-23-2008, 05:49 PM   #4
Rick_L
Member #2256
Default
I use either odorless mineral spirits or kerosene. Too convenient, and cheap.
There are some good water based solvents out there though. Maybe we'll get some new suggestions.
Rick_L is online now   Reply With Quote
Old 12-23-2008, 06:29 PM   #5
56belairconvert
Member
Member #5183
Default
Your local Carquest auto store would have it, it works fine. I would NOT use water based cleaners, it will rust your parts washer over time. Been there done that
56belairconvert is online now   Reply With Quote
Old 12-23-2008, 07:45 PM   #6
jeffs55
Senior Member 4 Gold Stars
jeffs55's Avatar
Member #2154
Default
I've used that purple stuff. I can't remember the name now other than "Purple" was in the name. Fast Purple, Purple Clean? I got it at a local AP store.
Cleans well, but forms a wierd crystalline matrix inside the tank after a while.
I've had the tank piled up with junk on top for....too long...I'm afraid what I'll find when I dig it back out again.
__________________
Jeff
55 Handyman
66 F100 P/U under construction
32 3-Window coupe under construction
96 Silverado Extended cab short bed
""I have 2 Chevys now!"
http://www.picturetrail.com/jefs55
Check out my hotrod coupe build here:
http://www.trifive.com/forums/showthread.php?t=82466
jeffs55 is online now   Reply With Quote
Old 12-23-2008, 08:23 PM   #7
J&Jhotrods
Senior Member 1 Gold Star
J&Jhotrods's Avatar
Member #4118
Default
Enzyme cleaners have come along way in the last few years. When they first came out, we were forced to use them in one particular shop I worked at. I was not a believer.
Our solvent supplier(where I work now) brought out a cleaner for us to try that uses an odorless, non-toxic, solvent-free cleaner and it works like a champ. The guys in the tow truck service shop have it, and believe me-there isn't hardly anything else out there that gets grimier than tow trucks. I brought over some scum covered car parts that needed a solvent bath, and I used the new cleaner. It works great! No fumes, non toxic, no worrying about "did I close the lid and unplug the solvent tank?" If I had the room, I'd have one in my mancave. I'll get some info on it when I get to work tomorrow.
Jay
J&Jhotrods is offline   Reply With Quote
Old 12-23-2008, 10:58 PM   #8
210ratrod
210ratrod's Avatar
Member #4252
Default
A friend of mine is a distributor for this stuff, used to use it when I was doing material handling equipment repair, works great and doesn't smell bad. Much safer than stoddard solvent, not priced too bad either! Check it out.
http://www.oileater.com/
Tim
__________________
Tim
It looks just like a Telefunken U47
210ratrod is offline   Reply With Quote
Old 12-24-2008, 01:36 PM   #9
bfr57
Member #7029
Default
210ratrod- Did they use this stuff in a solvent tank? Like 56belairconvert mentioned, will it rust out the tank being water based?
Old 12-24-2008, 02:23 PM   #10
210ratrod
210ratrod's Avatar
Member #4252
Default
Quote:
I just checked with my friend, and yes, it can rust a steel solvent tank. When I used it, I'd dispense some in a small plasic pail and use a parts cleaning brush or spray it from a spray bottle, we had a separate parts cleaning tank the company rented from Safety-Kleen that they maintained under contract. So yes, 56 BAC is correct.
__________________
Tim
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
