Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
User Name
Password
Mark Forums Read
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Reply
Thread Tools Display Modes
Old 12-28-2008, 11:49 PM   #1
57CW
Senior Member 1 Silver Star
57CW's Avatar
Member #7108
Default POWER STEERING CONTROL VALVE REMOVAL
Power steering system leaks down below, rebuilt the power cylinder and it's perfect now, new hoses. The "control valve" is the problem, leaking from behind the dust cover. I tried to follow the steps in the 1957 Chevrolet Shop manual, but it's kinda vauge to me in the removal process. Here's where I am: system drained - check!, loosen the relay rod control valve clamp - check!, small hoses removed - check!, cotter key and retaining nut removed from the ball stud - check!. Next, the manual says to disconnect the the control valve from the pitman arm. What do I need to do now to remove it without breaking the control valve, it's really on there and it doesn't seem like there is any way to get the control valve ball stud off the pitman arm. Do I need to remove the left tire rod or anything else first to make upward play? I do know you need a pickle fork in removing tire rod ends, is this the same case in removing the CV from the pitman arm. Once I get the CV off the pitman arm, I can move it to the right and unscrew the CV from the relay rod. If any of you sharp mechanics have any tricks up your sleeves and can help, I'd sure appreciate it. Thanks in advance.
__________________
Rock Around the Clock Tonight,
Jack-57CW
ELECTRIC MISTRESS - '57 EM
1957 Chevrolet 210 Townsman wagon
57CW is offline   Reply With Quote
Old 12-29-2008, 09:56 AM   #2
65 - 396
Member
Member #6406
Default
Yes, use your pickle fork on the ball stud that goes to the pitman arm. Then unscrew the valve assembly from the rod.
65 - 396 is offline   Reply With Quote
Old 12-29-2008, 10:29 AM   #3
finallyhavea57
Trifive Leaders Club
finallyhavea57's Avatar
Member #4062
Default
Autozone will loan you a pitman arm removal tool for free. Then you use it along with a big hammer. Mine took some heavy banging to get it off.
Jalapeno should be on line soon to give you more info. He is the real expert on the subject.
Don
__________________
finallyhavea57 is online now   Reply With Quote
Old 12-29-2008, 11:40 AM   #4
57viper
Tech Articles Historian
57viper's Avatar
Member #12
Default
Morning Jack: Check your mailbox I sent an article your way on rebuilding the control valve, hope it helps.
Bob
__________________
http://www.trifive.com/webs/57viper/
'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others.
57viper is offline   Reply With Quote
Old 12-29-2008, 12:20 PM   #5
57CW
57CW's Avatar
Member #7108
Default
Thanks guys for the responses and Bob for the rebuilding CV article. I'm going to the parts store to get a pitman arm puller. Now, if I can figure out what size socket I need to take the CV apart, they look like star bolts.
The CV article is very, very helpful. The diagram shows regular style bolts and the instructions say to use a 12 point 7/16 box wrench to remove them. Ok, I'll try that on them, if not the star socket would be the way to go.
__________________
Jack-57CW
Old 12-31-2008, 11:06 PM   #6
57CW
57CW's Avatar
Member #7108
Default
Thanks again guys for all the help. Rebuilt the Control Valve and hooked it back up to the system, filled up the power steering and ran the car for about 10 min, turned steering left and right to get out any air and No leaks. Lowered her back down off the jacks and went for a drive, came back and checked for leaks, none...yeah! She's driving like she should.
Have a great New Years in 2009,
Jack
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
