Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Fuel Systems, Fuel Injection, Carburation, Supercharging
User Name
Password
Mark Forums Read
Fuel Systems, Fuel Injection, Carburation, Supercharging Fuel Systems, Fuel Injection, Carburation, Supercharging, Questions and answers.
Reply
Thread Tools Display Modes
Old 10-11-2006, 09:45 AM   #1
Doug Harrell
Member
Member #557
Default Fuel Gauge reads 1/2 when full
Hi everyone, My gas gauge is only reading half full when the tank is full. I tested the gauge by leaving the sender wire hang free and the gauge goes to empty and when I ground it to the frame it goes to above full. I installed a new sender in the tank and added a extra ground wire from the sender to the frame. I also replaced the wire from the tank to the gauge. I replaced the power wire to the gauge, I have a good 12 volt connection. Have I missed anything that I could checked before I start bending the float arm on my new sender or is there another way to check the gauge.
Thanks Doug Harrell
Doug Harrell is offline   Reply With Quote
Old 10-11-2006, 11:01 AM   #2
MikeKy55
MikeKy55's Avatar
Member #10
Default
Actually I think you will be straightening the float arm rather than bending it. Given everything you posted, the float arm would just about have to be bent.
__________________
''Thank a police officer for being the one who runs to a report of 'Shots Fired' while others run away.''
http://www.youtube.com/watch?v=8QuJeYqNzew
MikeKy55 is offline   Reply With Quote
Old 10-11-2006, 06:11 PM   #3
dseale4888
Senior Member 4 Gold Stars
dseale4888's Avatar
Member #228
Default
Mikes got it right as far as I'm concerned. The arm must be bent up from where it should be.
Dave
dseale4888 is offline   Reply With Quote
Old 10-12-2006, 07:24 AM   #4
Doug Harrell
Member
Member #557
Default Gas gage reads half full
Thanks for the reply that was going to be my next move unless someone had another idea. Doug Harrell
Old 10-12-2006, 07:06 PM   #5
dseale4888
dseale4888's Avatar
Member #228
Default
If you take the sending unit out plug it in and try moving the arm from one extreme to the other while watching the gauge move. That would narrow the problem down. If you move the sender to where it should be full and the gauge doesn't read correctly you know that it most likely would be the gauge then.
Dave
Old 10-14-2006, 07:55 AM   #6
Doug Harrell
Member
Member #557
Default
Thank's Dave ,I should of done that first when I got the new unit but I will try it when I pull it out again.
Doug
Old 10-18-2006, 12:52 AM   #7
crashbodyman
Member
crashbodyman's Avatar
Member #993
Default gage reads half full
If you reused your old brass float with your new sending unit the old brass floats sometimes develop holes and allow gas to seep inside which displaces the air in the float. The float never comes all the way up to the top.
crashbodyman is offline   Reply With Quote
Old 12-29-2006, 06:26 PM   #8
radtechandnurse
Member
Member #1496
Default
need to make sure sending unit has a good ground... check out ol 55 east coast chevy site they have tips on it there!
radtechandnurse is offline   Reply With Quote
Old 02-17-2007, 09:25 PM   #9
edcat57
Member
Member #2018
Default
Sounds like you did a great job setting it up. Check for full travel of the float arm. I had a brand new unit from Classic Chevy International that would stick about half way down. It made for some serious speculation on long trips. You can also check the sending unit with an OHM meter. Connect the positive lead of the meter to the stud for the gauge wire, and the negative lead to the mounting plate. Moving the arm one way should give you a reading of 0 Ohms, and movine it the other way should give you about 30 Ohms. If everything checks out, bend the arm.
edcat57 is offline   Reply With Quote
Old 02-19-2007, 10:44 AM   #10
rrs57
Senior Member 1 Blue Star
rrs57's Avatar
Member #1382
Default gas gauge
my 57 does the same thing i put in new sending unit from c.c.i. when i built that car 12 years ago it shows 1/2 tank when full i keep it around a 1/4 of a tank if it ever happens to get down to empty your just rolling the dice as to when you run out. i also think it is a bent float arm i should fix mine but i have more cars and projects than i have life but maybe some day i will get to it at least i have a gauge that works so many cars never get theirs working. the gas gauge for my backhoe is a yardstick gets to 2 inchs time to refuel cant measure car tanks like that would be a lousy system anyway rob
rrs57 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
