Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
User Name
Password
Mark Forums Read
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Reply
Thread Tools Display Modes
Old 02-07-2009, 12:14 AM   #1
mfmtb01
Member
Member #7043
Question rearend question
Hey guys,
posted this on the drive line forum but didn't get much help. Maybe someone one can help me. I am trying to find out the differences between 55 & 57 rear ends. What I know is the 57 has a larger outside diameter axel bearing so I suspect the housings are not interchangable. Are the axels the same without the bearings. I also know the 57 has a provision for a drain plug whereas the 55 does not. Someone on the other forum said the 57 had a wider ring gear. Is the 57 rear end stronger than the 55? I have access to a 57 pontiac rearend. I understand they bolt right in. Is this a good choice for a 55 rear end? I am running 300+hp 327 with muncie M-20. Any help/advice would be appreciated.
mfmtb01 is offline   Reply With Quote
Old 02-07-2009, 01:51 AM   #2
a55togo
Senior Member 1 Silver Star
a55togo's Avatar
GateGears Deluxe Champion!
Member #1881
Default
not sure if the pontiac is any stronger, but i have heard the olds is. Not to sure if it is a dirrect bolt in as far as changing housings
Ed
a55togo is offline   Reply With Quote
Old 02-07-2009, 05:45 AM   #3
Bob W
Senior Member 1 Blue Star
Bob W's Avatar
Member #5825
Default
I think the 57 Poncho rear is almost a bolt in. It's stronger but you will have to move the bracket that holds the brake flex line to the housing from the left side to the right side.
Pontiac parts are getting hard to find, if I was going to swap rearends I would look at going to a Ford 9 inch.
Bob
__________________
Life is like a roll of toilet paper.....the closer it gets to the end, the faster it goes.
Bob W is offline   Reply With Quote
Old 02-07-2009, 08:54 AM   #4
The Shocker
Senior Member
The Shocker's Avatar
Member #7340
Default
I think the Olds/ Poncho rears of 58 -64 are stronger and a bit bigger.My friend had one in his 55 Chevy with a posi and 5.57 gears .In my opinion they look better than a 9 inch Ford ,but as was pointed out earlier, the parts are not as easy to get.I do know that the axle bearings on 58 -64 Olds/Pontiac and big bearing 9 inch Ford are the same part.The gears set for the Olds/Poncho are hard to find and expensive ,and the posi units are nearly impossible to find and very expensive.The only downfall that i have heard of on the Olds/Poncho rear is that the housings are weak .I think the earlier 55-57 rears were used in dragsters back in the day.Until the later style came out.I'd try to find a 31 spline 9 inch Ford to install if i was going to upgrade.Good luck ...
The Shocker is offline   Reply With Quote
Old 02-07-2009, 09:31 AM   #5
chevender
RIP: 12-31-2011
chevender's Avatar
Member #4395
Default
Quote:
I'm told the axles on a 57 are a different length than 55 56. When you use 55 56 axles with a posi you have to cut some of the splined area off whereas 57 axles work with no modification. Other than that I believe they are the same.
Rick
__________________
Ain't nothin to it, a baby can do it!
57 210 gasser
57 210 wagon
chevender is offline   Reply With Quote
Old 02-07-2009, 11:55 AM   #6
thehazmatguy
thehazmatguy's Avatar
Member #223
Send a message via Yahoo to thehazmatguy
Default
If you are running a clutch car, I wouldln't spend any time or effort on the stock chevy rear end.
Also, if you have access to the Poncho rear end --> jump on it! If you don't, then please pass it along to me! You'll have less ratio choices because most of the pontiac/olds rear ends saw drag duty, so I *think* ratios start at 4.11 and go into the 5's. I'm not sure if you can get a 3.55 or 3.73 type ratio. I wouldn't be surprised if that's changed though. There's been a lot of new interest in that rear end.
Actually... There's a crazy amount of good info here:
http://www.jalopyjournal.com/forum/s...d.php?t=129676
__________________
Check out my vBGarage for some pics of my car:
http://www.trifive.com/forums/vbgara...do=view&id=223
Or go here:
http://www.myrideisme.com/Garage/thehazmatguy
thehazmatguy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
