Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Transmission and DriveLine Questions
User Name
Password
Ask all your Transmission and DriveLine Questions. Tranmission, Drives shaft, Rear End, Gears, etc
Sponsored By: QuickPerformance.com
Parts on Ebay
Reply
Thread Tools Display Modes
Old 03-18-2009, 03:57 PM   #11
55ChevDelray
Senior Member 1 Gold Star
55ChevDelray's Avatar
Member #4108
Default
Quote:
Originally Posted by BO185 View Post
I think the 6l90 only has one pan. Its different from the 6l80. The 6l90 is bigger (longer) because of thicker gears.
Might look at just using 6l80 and use a different pan, one form a holden, CTS-V or G8 Pontiac. It should handle you motor listed.
With either you would have to mod the trans tunnel I bet.
You should be fine with the 3.07 and the smaller tires (vs a trucks) and it will pull hard like it had 3.73 or 4.10's! I have test driven a 6speed truck and its nasty in first with 3.42's!
Good read on the 6l80/90
Another thing is it can be shifted manually with a tap shifter out of a G8 or CTS-V
Cool. I read somewhere about the different pans, but didn't notice that it applied to the 6L80. I will probably be doing some more work to the motor after I get it. Not near as impressive as the 502, but.... I can get the 6L90 for the same price as the 6L80, so I figure I'll go for the monster.. Still need to do some studying before I finally decide, but the 6L80 may be adequate.
I'll mount the motor a bit higher so I can get more clearance for the pan ( motor and trans).
3.42 !!! :eek: I wouldn't be able to not spin the wheels... The .667 final overdrive gear will be excellent for Power Touring!!
I read that thread before, I was hoping to get the 6L90E trans that RileyrideZ had for sale for $1500.
__________________
Brian
1955 210 Delray, work in progress.C4 suspension, LS376/480, 6L90
See some of the work here: http://www.picturetrail.com/gallery/...=13&Submit.y=8
2013 GMC Sierra crew cab
2010 Camaro SS LS3/M6
2007 Thunder Mountain Firestone Chopper
55ChevDelray is offline   Reply With Quote
Old 03-18-2009, 06:19 PM   #12
BO185
LS Tech and Moderator
BO185's Avatar
Member #1955
Default
That's the problem with the truck guys, they are all use to the 4l60 and swapping to 4.10's. Now with the speed if you have anything more than 3.42 1st gear will be useless!
You won't brake the 6l90, good choice!
I am jealous! Haha
__________________
Four Seasons Metalworks
-CnC Metal art
-Custom Signs
-Custom metal parts
-Powder Coating Services
Gen III/IV "LS" swap info
TECH: LS motor to Early Auto Transmission
Email or PM me your LS questions if you need help
bo185@yahoo.com
-55 210 delray 235/3sp
-73 IH 1210 Travelette SV392, 5sp, 4x4, 4.10's
-73 IH Scout II Vortec 6.0L 4L65e np241
-01 VW Beetle TDI 50+MPG!
BO185 is offline   Reply With Quote
Old 03-19-2009, 02:23 PM   #13
BO185
BO185's Avatar
Member #1955
Default
Quote:
Originally Posted by mcff157 View Post
You proably already know this, but I didn't, TCI has an ad for a 6 speed automatic in the May 09 Car Craft. Low gear is only a 2.97 and OD is .75. It doesn't look as large as the factory 6 spd and it is rated to 850HP. Check their web site www.tciauto.com, they have the package priced at $6064.35 with paddle shifters, transmission control unit, cooler, and harness. Very interesting
Chuck
Its a 4l80 that they turned into a 6 speed. That's not really worth it for those gears ratios. The 700r is better than that.
TCI 6sp 2.97, 2.31, 1.57, 1.18, 1.00, 0.75
But for $6k dang!:eek: The 6l80/90 new are around $2k. And figure another $1k for any special shifter, mounts, etc...
6L80E Stock:
Maximum engine torque: 439 lb-ft
Maximum gearbox torque: 664 lb-ft
6L90E
Max Eng Tq = 531 ft lbs,
Max Eng Pwr = 452 hp,
Max Gearbox Tq = 885 ft lbs
The 6L80-E is a clutch-to-clutch transmission. That means that the gear it's in, no matter what, will feel like engine braking if you lift the throttle quickly because there are no freewheeling mechanisms. Despite having 2 more gears, the 6L80-E is more mechanically simple than the 4L80-E.
If you have ever driven a 5 or 6 speed Allison 1000 you know how shifty those are under certain driving conditions. The Allison is clutch-to-clutch also. The 6L80-E takes some getting used to just as the Allison does.
__________________
-CnC Metal art
-Custom Signs
-Custom metal parts
bo185@yahoo.com
Old 03-19-2009, 02:42 PM   #14
55ChevDelray
Member #4108
Default
I found that the dealer will sell remanufactured 6L90E for $2300. Have you found them somewhere else for less? I want to get the best price I can..
__________________
Brian
Old 03-19-2009, 04:24 PM   #15
BO185
BO185's Avatar
Member #1955
Default
Around $2000k is what I have seen for new.
Might give these guys a call http://www.gmpartsdirect.com/
NOTE: They may have a lower price but watch their shipping fees carefully!!!:eek:
I have seen a few used ones with low miles go for $1k on E-bay.
__________________
-CnC Metal art
-Custom Signs
-Custom metal parts
bo185@yahoo.com
Old 08-18-2009, 12:53 PM   #16
BO185
BO185's Avatar
Member #1955
Default
Any updates Brian?
__________________
-CnC Metal art
-Custom Signs
-Custom metal parts
bo185@yahoo.com
Old 08-18-2009, 01:08 PM   #17
55ChevDelray
Member #4108
Default
Any updates Brian?
Nothing at this point. Still doin research. I'm thinking that the new Cadillac CTS-V is my best option. At some point I'm going to see if I can get a hold of a schematic for it. I'm a long ways off from being able to drive the car anyway; although I'm starting to put the chassis back together. I'll be buying my fuel tank soon. I'll be posting some new pictures soon showing my chassis at it's current stage. Started bolting the suspension back on after painting the frame.
As a last resort John Spear's harness will work, but he wants $1600. It's just a matter of time and someone will offer a cheaper solution to get this retrofit option to work. There certainly is a LOT of interest in getting the 6L90 into older cars. If I'm not able to get it to work by the time I'm ready to transfer the body over to my new chassis, I'll look into a 4A to put behind it temporarily.
__________________
Brian
Old 08-18-2009, 01:13 PM   #18
55ChevDelray
Member #4108
Default
Any updates Brian?
PS. I've got the motor and tranny already. Picked up the 6L90 from a salvage yard with 1300 miles ($1800). Have my LS376/480.
__________________
Brian
Old 08-18-2009, 01:38 PM   #19
BO185
BO185's Avatar
Member #1955
Default
That's weird on the price.
So LS3 and 6l90. What controller for the motor do you have E38 or E67? With out looking a a wiring print. You could just mod a truck harness to work with the LS3 and 6l90.
I would contact Jim's performance as well about the harness and tunning. I stand behind his work and advice! http://www.jimsperformance.com/
I am not 100% on the Gen IV stuff but they have seperate TCM for the transmissions now. You could wire it for a 4l80 and pick up a TCM for it out of a 07 up truck.
__________________
-CnC Metal art
-Custom Signs
-Custom metal parts
bo185@yahoo.com
Old 08-18-2009, 02:36 PM   #20
mrferrisjr
Senior Member 1 Silver Star
mrferrisjr's Avatar
Default
Times are sure changing on tranmissions. That 6 spd auto sure sounds like one to consider. Besides being fun to drive, the overdrive is a big plus. I have a lot of reading to do on this "newfangled stuff".:stoned:
__________________
____________________________________________
Mike
Nothing better than a classic Chevy and a big cubic inch small block.[/B]
mrferrisjr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
