Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Power Steering - Rack & Pinion - 605
User Name
Password
Mark Forums Read
Trifive Power Steering - Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Reply
Thread Tools Display Modes
Old 05-09-2009, 08:13 PM   #1
levi 1983
Senior Member 1 Blue Star
levi 1983's Avatar
Member #8232
Default power assisted steering
I want to put some form of power steering in my 56 townsman wagon but im on a very tight budget.. i was considering a 605 but today at a swap meet a fellow had a complete power assist set up from a 63 impala .. i think with some thoght and fabrication which i can do , i think i can make this work and still retain the stock column and box .. i realize that a 605 would be better and probably a 500 would be best. i can pick this up for 100 .. open to your thoughts.......Fred
__________________
Fred
levi 1983 is offline   Reply With Quote
Old 05-09-2009, 09:30 PM   #2
chevman57
Sr. Administrator
Trifive Leaders Club
chevman57's Avatar
Member #264
Default
Fred the power assist is pretty much what the original tri five power steering was in the beginning.
__________________
http://s1181.photobucket.com/albums/x437/chevman57/
http://www.cardomain.com/id/chevman57
http://www.trifive.com/forums/album.php?albumid=1177
1957 2dr sedan Bel Air, owned since 1978
1972 Chevelle Malibu, awaiting rebuild,owned since 1979
chevman57 is online now   Reply With Quote
Old 05-09-2009, 11:15 PM   #3
557B210
557B210's Avatar
Member #5571
Default
Fred...I believe the ram cyl and cont valve may be the same....However, then you will still need a drag link, pitman arm, idler arm, pump and hoses.
__________________
_______________________________
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Old 05-10-2009, 09:21 PM   #4
chevyman1957
Member
Member #6273
Default
Quote:
I might be mistaken, but I think the 63 control valve has different threads where it attaches to the center link. If you look at the one that the aftermarket (Danchuk, etc.) it looks the same as the 58-up valve, but has been modified to fit the earlier version. A-1 Cardone still rebuilds the later style, so you might want to check with your local parts house and see.
chevyman1957 is offline   Reply With Quote
Old 05-11-2009, 01:02 AM   #5
Jalapeno
Senior Member 1 Gold Star
Member #4149
Default
No, the 58-64 linkage, ram, and valve are all completely different, NONE of the power steering stuff is the same. You cannot directly bolt them in, nor could you even EASILY modify things to fit 55-57.
__________________
Jalapeno
Jalapeno is online now   Reply With Quote
Old 05-11-2009, 01:51 AM   #6
mickeywestsr
mickeywestsr's Avatar
Member #1970
Default
In 1982 I had a friend install a used power assist in my '62 Impalla SS. The cylinder leaked. Then you could still get a rebuild kit. It still leaked a little after the re-build but it still made the steering "much" easier.
__________________
GO VOLS
COWBOY
mickeywestsr is offline   Reply With Quote
Old 05-11-2009, 04:21 PM   #7
levi 1983
levi 1983's Avatar
Member #8232
Thanks for the input guys... ill let you know how i make out if i attempt this project ... thanks again, Fred
__________________
Fred
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
