Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
User Name
Password
Mark Forums Read
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Reply
Thread Tools Display Modes
Old 11-28-2006, 11:35 PM   #1
Hafrod
Senior Member 3 Gold Stars
Hafrod's Avatar
Member #1291
Default Will HEI work with front mounts-SMALL BLOCK 55
Stock front mounts on 350 going in 55. Will HEI fit?
Hafrod is online now   Reply With Quote
Old 11-28-2006, 11:51 PM   #2
PaPa Mike
Super Moderator
PaPa Mike's Avatar
Member #1257
Default
I think there are clearance issues between the dist. and the firewall, some of the other guys can probably give you more insight, but you may need to use engine sidemounts and trans. crossmember and move forward 3/4 inch. I have seen sledge hammer used on firewall to make room. Not my first choice.
__________________
PaPa Mike
I'd rather walk a mile wearing a BowTie----:p
http://www.trifive.com/webs/papamike/
PaPa Mike is offline   Reply With Quote
Old 11-28-2006, 11:58 PM   #3
chevman57
Sr. Administrator
Trifive Leaders Club
chevman57's Avatar
Member #264
Default
It will depend. I`ve seen some use them with no problem and others don`t have enough room, so each car varies by the body mounts evidently. With tolerances some may be bolted a little more forward and others may be bolted a little mor towards the back. So the only way to tell would be to try it, and the ones that have fit had about 1/4 inch between the dist. and firewall.
__________________
http://s1181.photobucket.com/albums/x437/chevman57/
http://www.cardomain.com/id/chevman57
http://www.trifive.com/forums/album.php?albumid=1177
1957 2dr sedan Bel Air, owned since 1978
1972 Chevelle Malibu, awaiting rebuild,owned since 1979
chevman57 is online now   Reply With Quote
Old 11-29-2006, 12:29 AM   #4
BELLA57
Senior Member 1 Silver Star
BELLA57's Avatar
Member #868
Default
Yes, it seems to work, at least on my 57. I have a '57 hardtop, with a 350 and old style (large cap) HEI. It was all in when I bought the car. The car had front mounts, and it all fit. The HEI was very close to the firewall, I'd say between 1/4" and 3/8" at the widest part of the cap. I've never had to try and remove the distributer, but the distributer can be rotated. I have since switched to side mounts, but left the engine exactly where it had been with the front mounts. I don't think any mods were made to my firewall. From inside the car, it look all original. Oddly, my firewall has a skin across it to make it smooth, so that probalby cuts my clearance even more than you. John
BELLA57 is offline   Reply With Quote
Old 11-29-2006, 08:12 AM   #5
byrdman
Member
byrdman's Avatar
Member #1004
Default
It will work on some and will not work on others. It wouldn't fit my 57 back when I had stock mounts. If you install HEI and clearance is super tight at the firewall, make sure the motor doesn't rock too much when you romp it. If regular HEI won't fit, there are small body HEI and in-cap conversions to make a points distributor electronic.
__________________
-"byrdman"
'57 2 door sedan
byrdman is offline   Reply With Quote
Old 11-29-2006, 12:19 PM   #6
Dan57
Dan57's Avatar
Member #1352
Default
Mine seems to fit ok on my '57 with HEI and side mounts. Wish it didn't fit in a way, then i'd have an excuse to update that ugly thing, hehe
__________________
Dan
'57 210 4 door sedan
http://www.trifive.com/forums/album.php?albumid=353
http://www.trifive.com/forums/image.php?type=sigpic&userid=1352&dateline=1224780  380
Dan57 is offline   Reply With Quote
Old 11-29-2006, 11:32 PM   #7
Twin Blown 57
Senior Member
Twin Blown 57's Avatar
Member #1466
Default HEI yes
I have an HEI in my 57 that I could turn but not pull out so I built some custom side motor mounts and trans crossmember that moved my engine forward 3/4 inch to clear the firewall, I also raised the engine for other reasons to clear the steering linkage and allow for an extremely low front end without dragging the 7 quart Moroso oil pan.
If you move the engine forward though you may have to go with a 6 cyl radiator that mounts in front of the core support, I think it's a better radiator anyways.
Hope I helped more that hurt,
Sincerely,
Dave Twin Blown 57
Twin Blown 57 is offline   Reply With Quote
Old 11-30-2006, 04:54 PM   #8
55fazzi
Senior Member 1 Gold Star
55fazzi's Avatar
Member #1331
Default
I have the 3/4" foreward Earl Williams side mounts. GM full size HEI dist. on an '84 350 . It clears.....but not by much! My guess is if the front mounts retain the original motor location....the full size HEI will NOT fit.
Tom
55fazzi is offline   Reply With Quote
Old 11-30-2006, 07:40 PM   #9
fiftee6
fiftee6's Avatar
Member #1478
Default
I would not. I had it on my 283. While it does seem you can slip a credit card in the back, the 90 degree plug boots on the back two terminals do hit under torque. I have changed timing from rubbing, I even lightly greased the firewall. This was one of the reasons for my recent pulling of the motor. Maybe with brand new fresh rubber mounts or urethane you would be ok, but I would not. Phil...
fiftee6 is offline   Reply With Quote
Old 12-02-2006, 10:20 AM   #10
41willys
Member
41willys's Avatar
Member #1385
Default '55 with original front motor mounts!!!
I've got a '55 210 sedan with a '77-79 (casting date on block) 350 CI Chevy engine and a HEI distributor. My car is experiencing performance problems in that the engine will start but seems like it's not hitting on all 8 cylinders. The HEI is pressed extremely tight against the firewall and I think the distributor cap is out-of-round. Plans are to install a MSD ignition system - small body distributor and side engine mounts that move the engine forward 3/4". Funny thing is the car ran fine up until about 5 months ago then I started having the problem with the engine not running as it should.
41willys is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
