Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Engine Building, Hi Performance
User Name
Password
Mark Forums Read
Engine Building, Hi Performance Please tell us about your engine builds. What component combos and horsepower output. Let's help each other build better faster engines. Ask or answer questions.
Reply
Thread Tools Display Modes
Old 07-11-2009, 06:58 PM   #1
5619
Member
Member #1574
Default valve lash
I got about 300 miles on my new cam (solid lifter) and was going to set them again --- there surposed to be set at 18 hot , if I wanted to do them cold set them at 20? --- whats the best sequence to ajust? Ive been doing them on tdc for each piston -- Thanks 5619
5619 is offline   Reply With Quote
Old 07-11-2009, 07:29 PM   #2
gconnsr
Guest
Posts: n/a
Member #
Default
I thought the cam card gave hot and cold specs?
Old 07-11-2009, 09:09 PM   #3
nhramike57
Senior Member 3 Gold Stars
nhramike57's Avatar
Member #6523
Default
Quote:
You should probably warm up the car then shut it off and pull the valvecovers and set them hot..theres just too many variables in how much parts are expanding to get a accurate cold lash. The correct way to lash valves is to watch the exhaust rocker go down to its bottom travel..as soon as it moves and starts to comeback up ..set the lash for the intake of that cylinder..same for exhaust..intake bottom of travel ..starts to move back up..set the exhaust lash for that cylinder. your always setting the lash on the lobe base circle..this is known as the EO-IC procedure.TDC is a hit and miss method depending on camshaft overlap. Does your cam card say 18 thou hot..that seems tight for a solid lifter...usually there around 22 thou. if you open the lash a couple of thou you increase bottom end power..tighting it increases top high rpm power.
nhramike57 is offline   Reply With Quote
Old 07-11-2009, 09:23 PM   #4
557B210
557B210's Avatar
Member #5571
Default
5619...I believe there's a little error in your thinking....I don't have the procedures available to me, because I'm not at home....However, when a cyl is at a TDC, the intake and exhaust valves are then set on a different cylinder....Maybe someone will chime in....In the meantime, I'll do some research online.
__________________
_______________________________
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Old 07-11-2009, 09:52 PM   #5
5619
Member
Member #1574
Default valve lash
I'm running the comp cam 256 x-treme energy --- the card did say 18 thou -- that did sound tight to me also going from my 30/30 I used to run --- tdc on the power stroke I thought was the way to do it -- I'll try the other way too
Old 07-12-2009, 11:44 AM   #6
557B210
557B210's Avatar
Member #5571
Default
Found this on the net....Should be of help
http://www.chevyhiperformance.com/te...nfo/index.html
__________________
Old 07-12-2009, 11:46 AM   #7
brian55lvr
Senior Member 1 Blue Star
brian55lvr's Avatar
Member #7744
Default
i run mine at .022-hot
__________________
http://www.trifive.com/forums/image.php?u=7744&type=sigpic&dateline=1235519743
Remember a 55 in the hand is worth a ton in the bush.
http://user.streetfire.net/profile/brian55lvr.htm
http://www.youtube.com/user/brian55lvr
please leave comments if you like my stuff-----thx
brian55lvr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
