Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
User Name
Password
Mark Forums Read
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Reply
Thread Tools Display Modes
Old 08-03-2009, 04:17 PM   #1
Maria
Member
Member #7787
Default I think there is rust in my gas tank......???
Ok, so while I am driving my 56 chevy it starts sputtering out, like it is out of gas. Then it just stops. When this happens there is fuel in the in line filters, my bf checked the bowl in the carb and that was empty. He also hecked the carb and he said it appears fine. Thought maybe it was the gas lines getting to hot
I had put an additional inline fuel filter on before the fuel pump and it does have sediment in it already.
If it is the gas tank and it is full of rust, can it be cleaned and used again or should I just get a new one. And could this be the cause.
Maria is offline   Reply With Quote
Old 08-03-2009, 04:46 PM   #2
bob p
Senior Member 1 Gold Star
bob p's Avatar
Member #2977
Default
this is a common problem for cars that haven't been driven regularly, especially if they are stored for a prolonged period of time without full tank of gas. condensation gets in the tank and condensation above the fuel level causes the parts of the tank above the fuel level to rust.
the in-tank filter won't catch everything, so your inline fitler between the tank and the fuel pump catches a lot of it. you might also want to check the inline paper filter insert at the inlet to your carb.
i recently took my car out of storage. i had to drain the tank (drain plug at the bottom), rinse the tank out, and inspect the tank with a bore scope. the tank looked OK, so we put it back in service and flushed the lines by disconnecting the lines at the inlet to the carb. my mechanic also installed an additional see-through inline filter between the fuel pump and the carb so that we could monitor any potential problems like those you've described.
i had problems with vapor lock in the supplementary fuel filter that was placed near the carb. if you search for vapor lock you'll find a good description of the problem.
as a first step, i would drain the tank, flush it out and inspect it. if it needs repair or replacement, its probably better in the long run to replace the tank if its one that is commonly available. most tanks aren't very expensive, and the cost of repairing one can be pretty high.
__________________
1957 Beauville Wagon
1957 Wagon commercial
bob p is offline   Reply With Quote
Old 08-03-2009, 04:54 PM   #3
carls 56
Trifive Leaders Club
carls 56's Avatar
Smile
hi maria! it sounds like the tank or the lines. i would get a new tank (if its the tank). under $2oo. tank kits ( inludes tank, sendig unit, straps, ect.) $270 at ecklers.
__________________
"DRIVE AND ENJOY THEM WHILE YOU WORK ON THEM, LIFES TO SHORT"
my toys: 56 4dr 210 & 57 4dr belair
ARMY NAM VET (so proud)
carls 56 is offline   Reply With Quote
Old 08-03-2009, 06:09 PM   #4
Maria
Member
Member #7787
Default
This car had been sitting for about 18 years when I bought it. So the tank is probably full of gunk. I put two inline filters on the fuel line, one before fuel pump and one before carb. Could that be a problem also?
Old 08-03-2009, 06:14 PM   #5
Gregs210
Gregs210's Avatar
Member #3994
Default
Sounds like the needle valve in the carb is stuck shut.
Gregs210 is offline   Reply With Quote
Old 08-03-2009, 06:14 PM   #6
bob p
bob p's Avatar
Member #2977
Default
i have had inline fuel filters that have been added near the carb cause vapor locks. here is a link to the vapor lock thread i was talking about:
http://www.trifive.com/forums/showth...ght=vapor+lock
18 years is a long time. mine sat for 10. here's what i did:
1. drop the tank, flush it out and inspect it
2. discard the old fuel
3. flush out all of the fuel lines and replace all of the fuel filters
4. rebuild the carb.
my car was running well after doing that. except for the fact that Bozo the Clown lost some of my carburetor parts when he did the rebuild.
__________________
Old 08-04-2009, 03:44 PM   #7
jerrspud
Senior Member 1 Silver Star
jerrspud's Avatar
Member #8018
Default
there is a filter on the sending unit that is probably blocked as well.
inside tank did look much better.
I had similar problems like you are stating. Drive and die, but had fuel in filter by carb. I had replaced carb and fuel pump, though it could be vapor lock.. drove me crazy.. and it went away when I replaced the lines, sending unit, and tank.
__________________
Jerr
57 BelAir
4-door sedan
283, Powerpack Heads, Edelbrock intake and 600 CFM carb, 2" ramhorn exhaust. 247.24 HP
200-4r Transmission
jerrspud is offline   Reply With Quote
Old 08-04-2009, 04:11 PM   #8
jeffs55
Senior Member 4 Gold Stars
jeffs55's Avatar
Member #2154
Default
I see you have a wagon.
Pics are always a good thing, BTW.
You've gotten the best advice already. Nothing more I can suggest.
__________________
Jeff
55 Handyman
66 F100 P/U under construction
32 3-Window coupe under construction
96 Silverado Extended cab short bed
""I have 2 Chevys now!"
http://www.picturetrail.com/jefs55
Check out my hotrod coupe build here:
http://www.trifive.com/forums/showthread.php?t=82466
jeffs55 is offline   Reply With Quote
Old 08-04-2009, 06:48 PM   #9
craig32
Member #5796
Default
Maria, put a gas can under the fuel pump, disconnect the pump from the tank and put a short hose from the gas can to the fuel pump and try it. I wish I had thought of it. . . even tho I do it on a regular basis on my 'project vehicle' This will bypass all the crud in the tank and the lines.
craig32 is offline   Reply With Quote
Old 08-04-2009, 07:24 PM   #10
r66ss
r66ss's Avatar
Member #2133
Default
Maria
Have you solved this problem yet,
__________________
Randy
www.picturetrails.com/mrchevelle
r66ss is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
