Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Welcome to Trifive > Chit Chat Area, Anything on your mind goes here.
User Name
Password
Mark Forums Read
Chit Chat Area, Anything on your mind goes here. Chit Chat Area, Anything on your mind goes here. Just an area to Shoot the Bull. No Politics Allowed = No Religious Debate allowed, Keep it clean please. Click here to watch help videos for new and current members first please.
Reply
Thread Tools Display Modes
Old 08-10-2009, 10:51 AM   #1
56EDDIE
Member
56EDDIE's Avatar
Member #9666
Unhappy TRANS FLUID LEAK
LOOKING FOR HELP WITH MY 350 TRANS STILL LEAKING OIL, TWO PAN GASKETS, ONE NEW STEELE PAN, NEW COOLER LINES, STILL DRIP, DRIP, DRIP. LEAK APPEARS IN THE RIGHT FRONT CORNER. DOES SOMEONE MAKE A DIFFERENT GASKET TYPE?, OR HAVE A "FLOOR FIX"?, THANKS YALL, ET
56EDDIE is offline   Reply With Quote
Old 08-10-2009, 11:14 AM   #2
USA1
Senior Member 4 Gold Stars
Member #6974
Default
I used to chase a lot of leaks in that area on th350s. It may not be the pan, does it still have a TCS solinoid Just below the cooling lines. Many leaks in this area are the dipstick O ring. I have also seen the O ring on the kick-down cable leak.
USA1 is offline   Reply With Quote
Old 08-10-2009, 11:17 AM   #3
TheHotrodHandyman
Senior Member 3 Gold Stars
TheHotrodHandyman's Avatar
Member #8438
Default
As USA1 said above. I would look very close at the "O" rings on the filler tube as well as the kick down cable. That is more than likely where your drips are coming from.
TheHotrodHandyman is online now   Reply With Quote
Old 08-10-2009, 12:20 PM   #4
ProjX57
Senior Member 2 Gold Stars
ProjX57's Avatar
Member #7050
Default
While your checking all the area's already mentioned, might as well throw in checking where the speedo hook's up while your crawling around down there.....My .02, and
__________________
Ed............aka Speed
57 Chevy 210 2dr sdn
" I've Done So Much, For So Long, With So Little, That I Am Now Qualified To Do Anything With Nothing".
ProjX57 is offline   Reply With Quote
Old 08-10-2009, 12:25 PM   #5
r66ss
Trifive Leaders Club
r66ss's Avatar
Member #2133
Default
Quote:
Sounds like u got lots of things to check
First Id clean all parts of tranny, UNDER NEATH , start car , then shut off, and put clean piece of card board under her, let her sit , then start looking for leaks, you should be able to take flash light and look where its comming from
__________________
Randy
www.picturetrails.com/mrchevelle
r66ss is offline   Reply With Quote
Old 08-10-2009, 12:51 PM   #6
roughneck424
Senior Member 1 Silver Star
roughneck424's Avatar
Member #7127
Send a message via Yahoo to roughneck424
Default
Another trick is after clean and dry , spray the trans with underarm deorderant!! Yep, it drys white and the tranny fluid will look like blood running down the tranny!!
__________________
Mom was right....
I am going Blind!!
roughneck424 is offline   Reply With Quote
Old 08-10-2009, 01:12 PM   #7
r66ss
r66ss's Avatar
Member #2133
Default
Quote:
I LIKE THAT IDEA FORGOT ABOUT THAT TRICK ,WAY TO GO roughneck 424
__________________
Randy
Old 08-10-2009, 02:12 PM   #8
1RARE57
Senior Member
1RARE57's Avatar
Default
Just because we've been dealing with the tranny leak for awhile, we were always thinking it was the old pan. Got a new chrome pan, still leaked. Took the car back to the shop where we got the 350 tranny installed and it was the gasket where the shifter comes out of the tranny. Might want to check there. Just a suggestion!
Good Luck!
__________________
~Tina, Dan and Melina ~
1RARE57
See the USA in your Chevrolet
1957 Chevy 150 Utility Sedan
2009 Chevy HHR
1RARE57 is offline   Reply With Quote
Old 08-10-2009, 07:58 PM   #9
roughneck424
Member #7127
Default
Thanks... I learned that somewhere ? working on Harleys
__________________
Mom was right....
I am going Blind!!
Old 08-22-2009, 06:17 PM   #10
Ron Holz
Senior Member
Ron Holz's Avatar
Member #3922
Default Leaky 350
Make sure its not over full, check well hot,should be below full mark a tad bit.
Ron
__________________
Ron Holz is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
