Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Hi Performance & Racing > Engine Building, Hi Performance
User Name
Password
Mark Forums Read
Engine Building, Hi Performance Please tell us about your engine builds. What component combos and horsepower output. Let's help each other build better faster engines. Ask or answer questions.
Reply
Thread Tools Display Modes
Old 10-08-2009, 09:58 AM   #1
210 Sport Coupe
Senior Member 1 Silver Star
210 Sport Coupe's Avatar
Member #3596
Default What cam to run in 327?
Hey guys,
Been looking to do a cam swap this winter but got lost in the maze of sbc cams available.Need help.
Here is what I'm working with:
327 block #3782870 std., 2 bolt main, stock piston #3795704 (flat top w/4valve reliefs), camel hump 64cc #3782461 heads (don't know if 1.94 or 2.02 valves), (8.7-9.75 compression?),heads still on engine, Edelbrock Performer EPS (Idle to 5500 RPM) intake, Holley 650 dp., Patriot 1-5/8" tube headers, 2-1/2" Flowmaster duals to the rear, 200-4r trans w/2000 TCI stall, 3.89 gears. 27.5" tall rear tires. Hope I didn't leave anything out.
I wanted something like the Thumpr series cams, but..... any feedback?
Primarly street driven, the odd burnout.
Will also have manual 4wdb so I don't think vacuum is a concern.
Appreciate any help or tested combinations.
__________________
Nothing screams "poor workmanship" like wrinkles in the duct tape.
210 Sport Coupe is offline   Reply With Quote
Old 10-08-2009, 10:23 AM   #2
ProjX57
Senior Member 2 Gold Stars
ProjX57's Avatar
Member #7050
Default
Give Comp Cam's a call and give them all your info, and what you want to do in the long run with the ride, and they can tell you what would be the best setup cam wise to use.......
__________________
Ed............aka Speed
57 Chevy 210 2dr sdn
" I've Done So Much, For So Long, With So Little, That I Am Now Qualified To Do Anything With Nothing".
ProjX57 is offline   Reply With Quote
Old 10-08-2009, 01:04 PM   #3
55150
Member
55150's Avatar
Member #4918
Default
I like the Comp Cams 280 magnum in my 327 second 327 I have run this cam in
the only thing I would recomend is a higher stahl converter than stock and long slot or roller rockers
Great cam great sound
I have pretty much the same set up you have and it runs very well and sounds great
I am running a muncie 4speed
just make sure what if you put in a flat tappet cam to follow the cam manufacturers recomendation especially with the zinc being reduced in the oils of today
comp cams recomends 15/40 shell rotella t and a bottle of their #159
broke in two cams that way this year with great success
__________________
Club
S.H.R.A.
Syracuse Hot Rod Association
Cars:
Prostreet Blown
Studebaker Coupe
1955 Chevy Sedan
327 Muncie 4 Speed
55150 is offline   Reply With Quote
Old 10-10-2009, 07:45 PM   #4
210 Sport Coupe
Member #3596
Default
Anyone have any feedback on the Edelbrock topend kit?
Was looking at:
http://www.jegs.com/i/Edelbrock/350/2099/10002/-1
http://www.jegs.com/i/Edelbrock/350/2098/10002/-1
__________________
Old 10-10-2009, 09:22 PM   #5
fiftyfivegasser
fiftyfivegasser's Avatar
Member #2560
Default
If you go to the Comp Cam site, they have a cam selection program that you can download. You put in all your engine particulars, select the type cam (hydraulic, mechanical, etc) and it chooses the best cams for the application, gives the specs for each and rates each for performance. Also allows you to see the expected HP for each selection. Makes choosing easy even if you choose another brand with the same specs. Good luck.
__________________
Mike
fiftyfivegasser is offline   Reply With Quote
Old 10-10-2009, 09:26 PM   #6
r66ss
Trifive Leaders Club
r66ss's Avatar
Member #2133
Default
Give HOWARDS CAMS a look, exce
llent cam shafts, also ELGIN CAM SHAFTS.
__________________
Randy
www.picturetrails.com/mrchevelle
r66ss is offline   Reply With Quote
Old 10-11-2009, 11:29 AM   #7
56-210sedan
Senior Member 4 Gold Stars
56-210sedan's Avatar
Member #2444
Default
Here is one i always liked to run, http://www.jegs.com/p/Comp-Cams/Comp...46650/10002/-1 I used jegs just for reference so you may do better price wise some where else. If you just type in 12-211-2 at google it will bring up information.
__________________
55 Belair 2dr Sedan 350/350 loving every minute of it.
56-210 2dr Sedan c4 front/rear suspension, and not sure when the ride will roll.
Marty
56-210sedan
saccc567.com
56-210sedan is offline   Reply With Quote
Old 10-11-2009, 12:03 PM   #8
bones57delivery
Member
Member #3346
Default
I ran this in my 327. It was great. Had that thump sound. Made great power (without headers). I have not tried the new thumper cams though.
bones57delivery is offline   Reply With Quote
Old 10-11-2009, 06:45 PM   #9
210 Sport Coupe
Member #3596
Default
Thanks everyone for your help!
I've got some great tips to research this cam swap thing. Really good help.
This place is great!!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
