Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Stock Chevy Discussion 55-56-57
User Name
Password
Mark Forums Read
Stock Chevy Discussion 55-56-57 Stock Chevy Discussion, 55-56-57 Ask your Questions or help others with answers. Or any general Talk about stock Chevy's
Reply
Thread Tools Display Modes
Old 12-08-2009, 06:51 PM   #1
HUD
Member
Member #10198
Default RER WHEEL BEARINGS
I've seen some posts on this but need to clarify some things. The rear end grease in my 57 ls leaking onto the backing plates and rear shoes. I understand that the gasket associated with the backing plate is for "dust prevention only". Thus are the bearings worn and allowing the grease to seep past or what?
HUD is offline   Reply With Quote
Old 12-08-2009, 07:03 PM   #2
BUD 1
Member
BUD 1's Avatar
Member #5031
Default
I MIGHT BE WRONG BUT I THINK THERE IS A RUBBER O RING THAT KEEP THE GREASE IN, WHEN YOU PULL THE AXLE YOU WILL SEE IT
BUD 1
BUD 1 is offline   Reply With Quote
Old 12-08-2009, 07:15 PM   #3
Rick_L
Trifive Leaders Club
Member #2256
Default
Well the o-ring might make for a small leak, but if the bearing is original and it's never been removed, it's not likely.
Most likely is the bearing or at least the main bearing seal is worn out as you described.
Rick_L is online now   Reply With Quote
Old 12-08-2009, 08:36 PM   #4
mickeywestsr
mickeywestsr's Avatar
Member #1970
Default
Rick L is most likely right. Gotta change mine out this spring.
__________________
GO VOLS
COWBOY
mickeywestsr is online now   Reply With Quote
Old 12-12-2009, 10:35 AM   #5
my55ragtop
Member
my55ragtop's Avatar
Member #11266
Default
Quote:
You need to make sure the inside of the axle housing where the bearing race fits is not worn. If someone ran a bad bearing to long it would wear this surface. Only fix I know for this is a new axle housing along with new bearings. good luck
my55ragtop is offline   Reply With Quote
Old 12-12-2009, 02:20 PM   #6
Old Buzzard
Senior Member 3 Gold Stars
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
Default
Vent plugged up??
__________________
Chuck
Injector inspector.
55 210 sedan/ LQ9 tyrfryer..:evilgrin0002:
Hotrodding and dragracing since 1955.:eek:
USAF 1960-1964
Old Buzzard is online now   Reply With Quote
Old 12-13-2009, 02:17 PM   #7
Watchdog
Senior Member 1 Gold Star
Watchdog's Avatar
Jumpin Joe Champion! Super Splash Champion! Havana Club 2 Champion!
Location: Darlington, SC Home of "The Track Too Tough To Tame"
Member #5274
Default
Correct, dust cover only. The rubber is built into the seal itself so its either getting around or through the seal. Potential serious situation if that gets on your brakes.
__________________
55 Bel Air
Watchdog is offline   Reply With Quote
Old 12-13-2009, 02:57 PM   #8
Buggrn56
Senior Member
Buggrn56's Avatar
Member #3146
Default
I replaced the bearings on my 56 about a year ago. There is an O-ring on the bearing itself. I would have to agree that if "gear oil" is getting on the backing plates it has to be getting past the O-ring. My 56 has a 57 rear axle so we have the same bearings. They are 3" OD and 55/56 are 2 3/4" OD I believe, so watch that when you purchase the new bearings. At least that is what I found when getting mine. The bearings can be difficult to remove if you don't have access to a press of some kind but it's not impossible to do. Don't ask how I know that. Good luck with the repairs and keep us updated.
Rog
Buggrn56 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
