Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > This is a list of our Official Sponsors , Quality 55-56-57 parts Click Here > Classic Performance Products
User Name
Password
Mark Forums Read
Classic Performance Products This is a special area of Trifive for Classic Performance Products
Reply
Thread Tools Display Modes
Old 01-01-2010, 06:36 PM   #1
Typhoontx
Senior Member 1 Gold Star
Typhoontx's Avatar
Angry Old Wizard Champion! The Battle of Helms Deep Champion!
Member #4779
Default Cpp500 box and cpp shortened stock style column kit
Aaron,
I'm installing a powersteering conversion using a cpp500 box, and the cpp shortened non tilt stock column with auto transmission column shift.
When every thing is installed the end of the column butts up against the top of the rag joint and I even cut slots in the firewall bracket plate to clear the screw heads on the end of the column so the column is recessed back as far as possible.
This makes it impossible for the shifter tube to move out the bottom end of the column when you pull back on the shifter handle.
I bought the 500 box a while back when cpp had special sale that included the rag joint.
Is it possible there is a shorter over all length rag joint ? the one supplied is 2.77" overall length
Thanks, Robert
Typhoontx is offline   Reply With Quote
Old 01-01-2010, 06:49 PM   #2
56Mark
Senior Member 1 Silver Star
56Mark's Avatar
Member #5675
Default
I know exactly what you are dealing with. I have been installing mine the past couple of days. The column almost has to be pulled up in the firewall. I pulled mine up about another 1/8" and cut notches in the plate that goes inside the firewall. I ended up notching the plate more than shown in the picture. I made a little box to cover the notches in the plate. I also ground off about 1/16" to 1/8" off of the rag joint. A 1/4" shorter rag joint would sure make it a lot easier. I finally have my column in and shifting well. I can take a pic of it if you want.
__________________
56-210 2 dr sedan
Mark
56Mark is online now   Reply With Quote
Old 01-01-2010, 07:08 PM   #3
56Mark
56Mark's Avatar
Member #5675
Default
You can see where the shift tube rubs the rag joint when it extends out.
__________________
56-210 2 dr sedan
Mark
Old 01-01-2010, 08:13 PM   #4
Typhoontx
Typhoontx's Avatar
Member #4779
Default
Ive notched the plate similar to the way you did yours, I just got another rag joint my brother had laying around from a 80 malibu its nearly 1/4" shorter
and I could probably grind another 1/8" off the nose . the other thing im pondering is to remove the socket from the rag joint and just weld a flat piece to the end of the 3/4 " shaft and drill 2 holes in it and bolt it to the rag joint in place of the part with the socket that you slide the shaft end in to it.
Regards, Robert
Old 01-01-2010, 08:27 PM   #5
Old Buzzard
Senior Member 3 Gold Stars
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
Angry it appears..
that the folks that "design" these items fail to do a real test fit, B4 they start selling them.
I had the same problems w/ the unit I got from Dbl Nickle.
There's NO WAY you can shorten the column, pull the screws nearly inside the opening, then expect a mt installed flush to the floor to clear.
Not only was mine not bent correctly, it was flush to the floor, w/ the top side bolt sticking thru the firewall hole.
The reason for the weld between the holes: The holes weren't even CLOSE to being spaced correctly. [The floor is the original floor]
Here's a pic of what I did to mine.
__________________
Chuck
Injector inspector.
55 210 sedan/ LQ9 tyrfryer..:evilgrin0002:
Hotrodding and dragracing since 1955.:eek:
USAF 1960-1964
Old Buzzard is offline   Reply With Quote
Old 01-01-2010, 09:19 PM   #6
mickeywestsr
Trifive Leaders Club
mickeywestsr's Avatar
Member #1970
Default
Fantastic job Hoss.........
__________________
GO VOLS
COWBOY
mickeywestsr is offline   Reply With Quote
Old 01-01-2010, 11:13 PM   #7
classic gary
Senior Member 2 Gold Stars
classic gary's Avatar
Member #5707
Default
Quote:
Regards, Robert
Speedway Motors makes the "rag" joint you just described, but I don't know if the splines are the same.
__________________
remember:
bolt-on, doesn't
universal, isn't
reproduction, made where?
classic gary is online now   Reply With Quote
Old 01-01-2010, 11:19 PM   #8
classic gary
Member #5707
Default
After all the things i've read about power steering installs, I'm going to just figure nothing fits and whatever parts I use are going to have to be "made to fit".
'Cause, universal / isn't,
custom made for / is not for what YOU are working on,
and bolt on / doesn't.
__________________
remember:
bolt-on, doesn't
universal, isn't
Old 01-03-2010, 12:34 AM   #9
Onemoretime
Senior Member 1 Blue Star
Onemoretime's Avatar
Member #2981
Default
Gary can I ever relate to your comment since I started my project this past week...
Gary wrote:
"After all the things i've read about power steering installs, I'm going to just figure nothing fits and whatever parts I use are going to have to be "made to fit".
and bolt on / doesn't. "
Doug
Onemoretime is offline   Reply With Quote
Old 01-03-2010, 09:09 AM   #10
Old Buzzard
Member #3388
Default That's how..
"the other thing im pondering is to remove the socket from the rag joint and just weld a flat piece to the end of the 3/4 " shaft and drill 2 holes in it and bolt it to the rag joint in place of the part with the socket that you slide the shaft end in to it."
My "kit" came. The "kit" included the shaft w/ the piece that bolts to the rag j, already welded on. I guess the "designer" got that part right, anyway.
Here's a pic or the "kit" as received. Chopping it all off, and using a Borgeson joint, looks better by the minute! [We did that on the 500 install on my bud's 60 Impy.]
__________________
Chuck
Injector inspector.
USAF 1960-1964
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
