Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Transmission and DriveLine Questions
User Name
Password
Mark Forums Read
Transmission and DriveLine Questions Ask all your Transmission and DriveLine Questions. Tranmission, Drives shaft, Rear End, Gears, etc
Reply
Thread Tools Display Modes
Old 03-30-2010, 08:29 PM   #1
LONDON55COUPE
Member
LONDON55COUPE's Avatar
Member #6408
Default Pinion Seal on 60's 10-Bolt Rear End.
The rear end on my '55 is from a 60's Camaro or Nova I believe. I haven't actually driven the car with it installed, but I have fitted all the 55-57 brackets and put in new brake wheel cylinders, brake lines and brake shoes. It is a 3.36 ratio and the driveshaft connection is the same as a 55-57 as the driveshaft will bolt straight up to it with no mods. I put the axle lube in about a year ago and have only turned it by hand. While I was putting in a new rear emergency cable at the weekend I noticed that I could see a slight weep of oil around the edge of the pinion nut. It wasn't dripping or anything, but like I have said it has only been turned by hand, so I don't know if this will be bad once the car is on the road. I have heard of some engine and transmission seals drying out through lack of use and leaking, but sealing up again once they have swelled up when back in use. Is this the same with a pinion seal?
Apart from taking off the rear cover to visually look at the gears and calculate the ratio, I have not done anything to the inside of the rear end. Is it a big job to change the pinion seal, or is it just a case of undoing the large pinion nut and accessing a seal from that same side. I have no exploded diagrams of this to see how it all goes together. If it is a major job of pulling axle shafts etc, I might be tempted to leave it until I have tried it on the road first to see if it is worth worrying about. Your advice would be appreciated as would an exploded diagram.
LONDON55COUPE is offline   Reply With Quote
Old 03-31-2010, 08:54 AM   #2
big gear head
Senior Member
big gear head's Avatar
Member #10928
Default
If you noticed the oil around the nut then the seal isn't the problem. The yoke needs to have sealant in the splines to keep oil from seaping through them and out around the nut and washer. Many people install the yoke with no sealant in the splines, and they leak. You can remove the yoke, clean out the splines, smear some sealant into the splines of the yoke (not the pinion shaft) and install the yoke again and your leak will stop. If the seal has never been replaced then this would be the time to do that too. You can pull the seal out from the outside and install a new one. Just be sure that you smear a little sealant around the outside of the seal before you drive it in. Then grease the lip of the seal before installing the yoke. Torque the nut to 150 foot pounds and use red locktite on the threads.
big gear head is offline   Reply With Quote
Old 03-31-2010, 06:50 PM   #3
LONDON55COUPE
Member
Member #6408
Default
Thanks big gear head, that sounds straightforward. I'll have to see if I have a big enough socket to get the nut undone now. Also I might order up a new seal. I am presuming the 60's 10-bolts would all have the same seal?
Old 03-31-2010, 08:48 PM   #4
big gear head
Senior Member
Member #10928
Default
If this is a Chevy 8.2 10 bolt then it will have a 1 1/8 inch pinion nut. The 8.2 uses the same seal for all years from '65 to '72. If this is a BOP 8.2 10 bolt then I can't remember what size the nut is, but it will take a different seal than the Chevy 8.2.
Old 04-01-2010, 05:43 PM   #5
LONDON55COUPE
Member
Member #6408
Default
Managed to get the axle yoke out today. The seal looks fine and clearly wasn't leaking, so it must be coming through the splines. I am going to a car show on Friday so I will get some more threadlock and sealant. I think I will leave the seal alone for now as it is not leaking and I don't want to drain down the axle again. Now that I know how it's done I can change it in the future if it does ever leak.
Old 04-02-2010, 02:26 AM   #6
Belairmark
Senior Member 1 Gold Star
Belairmark's Avatar
Member #1498
Default
See you at Wheels Day!!
__________________
If I wasn't meant to drive that fast, the pedal would only go half way!
www.rebel-v8.com, the forum with no decorum
AVO Member #62. www.amvo.org
Belairmark is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
