Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Transmission and DriveLine Questions
User Name
Password
Transmission and DriveLine Questions Ask all your Transmission and DriveLine Questions. Tranmission, Drives shaft, Rear End, Gears, etc
Parts on Ebay
Reply
Thread Tools Display Modes
Old 05-10-2010, 07:35 PM   #1
hddude
Senior Member 3 Gold Stars
hddude's Avatar
Member #10516
Default DRIVE-SHAFT LOOP
well, after seeing mine, fly across the road sat. nite, when my rear broke loose, "What`s the best way, and where should this go?" i was told, bolt it to the floor. i don`t think so. i bought a universal one from summit. thanx.
hddude is online now   Reply With Quote
Old 05-10-2010, 10:09 PM   #2
speedy55
Senior Member 1 Silver Star
speedy55's Avatar
Member #7609
Default
well you can either bolt it in or WELD IT in! I made mine and it bolts to the floor brace behind the tranny into some "pre existing " holes. I think they were for emergency brake but i dont have all that stuff so...........................
__________________
9.98 @ 137.20 MPH
speedy55 is offline   Reply With Quote
Old 05-10-2010, 11:57 PM   #3
Chevy Chase
Chevy Chase's Avatar
Member #5860
Default
Quote:
hhdude, That's how my buddies did it in the 70's. If it is good enough for NHRA, what the hey. An alternative would be to install a cross member with drive shaft loop.
__________________
It's only a big deal if you make a big deal out of it.
Chevy Chase is offline   Reply With Quote
Old 05-11-2010, 05:35 AM   #4
airmentbob
Senior Member 1 Gold Star
airmentbob's Avatar
Member #3340
Default
i ended up making a cross member with the drive shaft loop welded to it. i figured you couldn't go wrong with a little more structural integrity in the stock frame. especially since technically the stock frames only connect at the very rear of the car and underneith the front of the motor.
airmentbob is offline   Reply With Quote
Old 05-11-2010, 07:50 AM   #5
hddude
hddude's Avatar
Member #10516
Default
N.H.R.A. has a spec for a distance behind the front u-joint? and bolt to the floor is ok with them?
Old 05-11-2010, 08:52 AM   #6
USA1
Trifive Leaders Club
Member #6974
Default
I never bolt them to the floor, it makes their removal too difficult. I have one on my 55 that bolts to angle iron welded to inside of frame. The loop bolts to the short peices of angle iron. I have 3 Camaros with similar arrangements with angle iron tabs welded to the sub-frame connectors. On the Camaro it is easier to remove trans crossmember without loop in the way. If bolted to floor the bolts will be covered by seats & carpet.
USA1 is offline   Reply With Quote
Old 05-11-2010, 06:23 PM   #7
Hal_396
Hal_396's Avatar
Member #6920
Default
I have a NHRA 2010 rule book at home. I remember it saying it has to be within 6 inches of the u-joint. Don't recall any spec about where it needed to be attached at but I'll check later on when I get home.
A note here. Just because it says so in the NHRA rule book doesn't mean it's the best or smartest way to do things. It's just there way. Case in point, they say the battery positive should have a quick disconenct switch. Anyone that knows electricity would put it on the Neg. side.:stupido3:
__________________
HAL
Hal_396 is offline   Reply With Quote
Old 05-11-2010, 07:14 PM   #8
Chevy Chase
Member #5860
Default Drive shaft NHRA rules
HHdude, "All RWD cars running 13.99 or quicker with slicks and 11.49 or quicker with street tires must have a retainer loop 360 degrees of enclosure, 1/4" minimum thickness and 2" wide, securely mounted and located within 6" of the front universal joint for support of the driveshaft in the event of universal joint failure....." NHRA Rule Book
__________________
Old 05-11-2010, 07:29 PM   #9
hddude
hddude's Avatar
Member #10516
Exclamation
i thought i saw something like that. thanx!
Old 05-11-2010, 07:57 PM   #10
the4x4pig
the4x4pig's Avatar
Member #2059
Default
I bent up some 1.5" .120 wall round tube and made a loop for mine. Called NHRA and they said it would work.
Many of the type that bolt to the floor allow you to just remove the bottom loop. Should not be a reason to unbolt it from the floor. They are very easy to use and work fine.
__________________
It works in practice, but does it work in theory?
Remember, the government cannot give anything to anyone -- that they have not first taken away from someone else.
Molon labe
http://www.cardomain.com/ride/2916357
the4x4pig is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
