Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Transmission and DriveLine Questions
User Name
Password
Mark Forums Read
Transmission and DriveLine Questions Ask all your Transmission and DriveLine Questions. Tranmission, Drives shaft, Rear End, Gears, etc
Reply
Thread Tools Display Modes
Old 05-21-2010, 09:51 PM   #1
joeelutz
Official Trifive Sponsor
joeelutz's Avatar
Member #6896
Default Tremec TKO 500 Clutch Hydraulic or mechanical ?
I'm going to be installing a Tremec 5 speed behind an LS1 in a 57 and I'm trying to decide whether to go with a hydraulic setup or not. Can a stock 57 clutch linkage be used with the Tremec transmission? Does anyone make a hydraulic conversion kit for the 57? How about a Tremec installation kit for a Tri-five? I would like to just get a complete kit and bolt it all in if possible.
joeelutz is offline   Reply With Quote
Old 05-21-2010, 10:06 PM   #2
Rick_L
Trifive Leaders Club
Member #2256
Default
"Can a stock 57 clutch linkage be used with the Tremec transmission?"
Yes it should work fine. The transmission really has nothing to do with this.
"Does anyone make a hydraulic conversion kit for the 57?"
Depends on what you want. Do you want to hide the clutch master cylinder or mount it on the firewall?
"How about a Tremec installation kit for a Tri-five?"
There are only three things that are 55-57 specific. Clutch linkage, which location you want the shifter, and the crossmember.
The shifter location is something you spec when you buy the trans. Most any crossmember will work but you have to locate it correctly, fore/aft as well as vertically.
"bolt it all in if possible"
That's asking a lot, probably too much. Stick with the stock clutch linkage if that's a goal. You're going to have to cut a hole for the shifter and weld/drill the brackets for the crossmember.
I didn't address the driveshaft, that's another discussion that relates to engine mounting location, and the axle you use.
Rick_L is online now   Reply With Quote
Old 05-21-2010, 10:23 PM   #3
Chevy Chase
Senior Member 1 Silver Star
Chevy Chase's Avatar
Member #5860
Default TKO otions
joeelutz, I installed a TKO 600 in my "56 two-ten. Used the original BH and existing clutch package. Ordered from Keisler Engineering with otional mid-shifter location to easily clear bench seat. Keisler also has a hydraulic clutch system. Supported the rear of the TKO with a crossmember. Look at my album in User CP for pix.
__________________
It's only a big deal if you make a big deal out of it.
Chevy Chase is offline   Reply With Quote
Old 05-22-2010, 06:17 AM   #4
CJS57
Senior Member 1 Gold Star
CJS57's Avatar
Member #289
Default
I used a "complete" kit from Classic Chevy. I think they changed their name to Hurst Systems or something like that now. Lots of customer support back then. Main problem is that the top of tranny hits the tunnel floor. So you have to lower the back of the engine like I did or bash the floor for clearance.
The trannsmission won't just install like a new Muncie! You have to center the bellhousing to .005. Also the clutch disc splines are different. The worst part is that you have to lower the engine way down just to get the trannsmission to go into the bellhousing. The transmission is just to big to get a straight shot into the trans. It is tight all around. But well worth it.
__________________
1957 Belair 2Dr Hdtp, 58,000 original miles, original never rebuilt 283 engine, 245hp, Dual Fours, Tremec TKO 600 5-speed, 3.70 gears, AACA Senior in 1985
previous trifives:
1955 Belair Convt
1956 210 2dr Sdn
CJS57 is offline   Reply With Quote
Old 05-22-2010, 08:34 AM   #5
henrys57wagon
henrys57wagon's Avatar
Member #2131
Default
I also bought the complete setup from Classic Chevy before the name change and the support was great. I used mechanical linkage for the clutch system. The tranny slid in with no interference anywhere. Have fun shifting gears, good day.
__________________
57 wagon 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 51/53 HenryJ Corsair's, 07 2500HD with 26.5 Prowler 5th wheel travel trailer, 09 Impala LT, CDN coordinator for ChevyTalk.org,
http://www.picturetrail.com/gallery/...wagon&x=14&y=6
henrys57wagon is offline   Reply With Quote
Old 05-22-2010, 02:45 PM   #6
Chevy Chase
Member #5860
Default
TKO Floor panel.jpgjoeelutz, It seems not all humps in the floor tunnel are the same. The previous tranny in my '56 was a muncie which left a long hole in the side of the tunnel. I mig welded a piece of sheet metal in to close the hole up and then cut a hole for the TKO. The TKO can be installed and later removed without removing the engine mounts. Ecklers Classic Chevy sells a 55-57 tunnel panel part # 31-350. I fastened it in place with nut-certs.
__________________
Old 06-18-2010, 10:44 PM   #7
joeelutz
joeelutz's Avatar
Member #6896
Default
Quote:
Originally Posted by Chevy Chase View Post
Attachment 23843joeelutz, It seems not all humps in the floor tunnel are the same. The previous tranny in my '56 was a muncie which left a long hole in the side of the tunnel. I mig welded a piece of sheet metal in to close the hole up and then cut a hole for the TKO. The TKO can be installed and later removed without removing the engine mounts. Ecklers Classic Chevy sells a 55-57 tunnel panel part # 31-350. I fastened it in place with nut-certs.
Nice Hump! I decided to go with a hydraulic setup. Thanks for all the help.
Joe
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
