Please visit and Support Our Sponsors
Go Back   Welcome to TriFive.com 1955 - 1956 - 1957 Chevy's Bel Air Tri5 210 150 Nomad Forum, Photo Gallery and Classifieds. Here you can Buy, Sell, or Trade. Get or Give Advice, or Just Talk Classic Cars. > 55-56-57 Chevy Forum > Cooling Systems, Radiators, Fans / A/C
User Name
Password
Register FAQ Top Posters Members Search Today's Posts Mark Forums Read
Trifive Store 2010 Newsletter 2010 Calendar 1955-1956-1957 Chevy Parts and Services = Trifive Official Sponsors
Photo Gallery Garage Photos Trifive Classifieds Calendar Arcade Oldies vBRadio
Cooling Systems, Radiators, Fans / A/C Engine Cooling Systems, Radiators, Fans / Shrouds, water pumps, anything cooling related. Air conditioning etc.
Reply
Thread Tools Display Modes
Old 07-04-2010, 03:59 PM   #1
TXRaceFan
Senior Member
TXRaceFan's Avatar
Member #10413
Default Need aftermarket a/c advice
When I bought my 57 it had aftermarket a/c already installed. Best I can tell from the vent style it's a Vintage Air unit.
What I can't figure out is it has some type of switch with a dial on it mounted under the passenger side of the dash out of sight but within adjustment reach. It is definitely an aftermarket type of switch and I believe associated with the a/c.
I'm not sure what it does and couldn't determine from the installation instructions. Had the car out for a cruise today and it wasn't cooling as well as I'd hoped although it feels 150 degrees and humid out. Car ran a steady 190 and has an electric fan in addition to the mechanical fan. It's cool but not icy like I'd expect. I'm assuming the charge is correct as it blew cold during the winter. Now that the system is taxed, I wonder if there is some adjustment.
I did learn that my "interior / exterior" are mismarked and all the handles should be in the top position to maximize cooling. Just wondering if this other switch affects something to allow for the max cool mode. Perhaps it stops flow the the heater core?
Maybe I have an evaporative unit in the car - once I worked up a sweat, the blower felt ok.
Any ideas?
TXRaceFan is online now   Reply With Quote
Old 07-05-2010, 12:46 AM   #2
hotrodg726
Senior Member
hotrodg726's Avatar
Member #12165
Default
typicly that separate knob is the thermostat for the a/c crawl under the dash and check it out . adjusting it will help your a/c if it is the thermostat . good luck
hotrodg726 is offline   Reply With Quote
Old 07-05-2010, 09:37 AM   #3
acardon
Senior Member 4 Gold Stars
acardon's Avatar
Member #1888
Default
I agree, it probably is a thermostat. A thermostat cuts the compressor clutch off when the temperature across the evaporator core gets low enough for it to start freezing up. If the thermostat is set too high, you will notice that the compressor stops running before it gets cold enough. If the compressor is not shutting off, the thermostat is not keeping it from getting cold enough.
Just because it cools good in the winter doesn't mean it's charged sufficiently to cool in the summer when the outside temperature is 30 degrees hotter. A pressure test is the only way to know if it's charged correctly or if there is another problem.
__________________
Don
acardon is online now   Reply With Quote
Old 07-05-2010, 03:31 PM   #4
TXRaceFan
Senior Member
TXRaceFan's Avatar
Member #10413
Default
Quote:
I was afraid of that. Last August it seemed to be ok although the volume of air this thing moves is kind of lame. I guess I'm just used to my pickup freezing your behind off in 10 seconds on high.
I found something in the Troubleshooting section of the Vintage Air site and it suggests you can't have the thermostat set all the way to the right. I'll back it down the recommended 1/8 turn and give it another shot before I look at the pressures.
I have some gauges from the R12 days. Do they make adapters that will let me connect my gauges to the 134 system?
Old 07-05-2010, 04:20 PM   #5
Old Buzzard
Senior Member 2 Gold Stars
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
Default
Electric and mech fan... Is the elect fan on the ft of the a/c condensor?? If so, the motor can be blocking a considerable amt of the core...
__________________
Chuck
Injector inspector.
55 210 sedan/LS power.
Hotrodding and dragracing since 1955.
Old Buzzard is offline   Reply With Quote
Old 07-05-2010, 08:00 PM   #6
Rick_L
Trifive Leaders Club
Member #2256
Default
I don't think VA has changed their instructions - mine say the thermostat should be all the way clockwise unless the unit is freezing up even with a proper charge, then back off only slightly.
A properly installed and charged VA unit will freeze you out just like your pickup.
If you have a mechanical fan, this may not happen unless the car is moving.
Rick_L is online now   Reply With Quote
Old 07-05-2010, 09:28 PM   #7
TXRaceFan
Senior Member
TXRaceFan's Avatar
Member #10413
Default
Quote:
Electric fan is in front of the condensor. Car has run perfectly cool until this afternoon's hour-long cruise. It climbed to about 210 at a couple of stoplights and never returned all the way to 190. Kinda wierd. I may have not gotten it purged of all the air when I had the radiator out recently.
Sounds like I need to have the freon level checked.
Old 07-07-2010, 11:04 PM   #8
TXRaceFan
Senior Member
TXRaceFan's Avatar
Member #10413
Default
Well I found out a couple of things. Thermostat switch on the electric fan is acting up. Has worked perfect until now. The thing ran forever when I got home and ran the battery down on the car. It kicked off when cruising on Monday which is why it got so hot.
Had Jr. take the car in yesterday and it only had .2# of freon in it. While it was in (and I was at work) I found the charging instructions on the VA site and it said the suction pressures were much lower than normal 134a due to it having an expansion valve. Fortunately it also had the precise amount of freon required and I was able to get the info to them before he tried to charge it based on an incorrect suction pressure. Curious as to how it could be so low (assuming properly charged initially) - they said they did a leak test and found nothing. Any ideas on that?
Now to look at the fan. I may jet the thermostat.
Question (for summer driving): 1) wire it to the a/c so it comes on with a/c ? or 2) wire it on when the car is running?
Old 07-07-2010, 11:15 PM   #9
acardon
acardon's Avatar
Member #1888
Default
Do you have a relay in the electric fan circuit? The temperature switches are not designed to carry the load of an electric fan.
__________________
Don
Old 07-08-2010, 09:09 AM   #10
Rick_L
Member #2256
Default
"Question (for summer driving): 1) wire it to the a/c so it comes on with a/c ? or 2) wire it on when the car is running?"
The proper way to wire the fan for a/c use is to use a trinary switch from Vintage Air. It now probably has a binary switch which will cut off the compressor if the pressure is 1) too low or 2) too high. These are for system safety. The trinary switch has a third function which runs the fan when the high side pressure goes over a set point. Usually this means your fan will run when idling or driving at slow speed, and turns off when driving at higher speed. This means your fan won't have to run all the time (and wear out that much sooner). You can wire this into the same relay as the coolant temperature switch.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
www.keithreiter.com www.56belair.com  www.tri-5.com www.tri-fives.com www.trifive.com
www.1956chevys.com www.1957chevy.org www.55chevy.org www.56belairs.com
www.chevy-belairs.com
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
