Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
User Name
Password
Mark Forums Read
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Reply
Thread Tools Display Modes
Old 08-10-2010, 05:41 PM   #1
Bob W
Senior Member 1 Blue Star
Bob W's Avatar
Member #5825
Default 56 Chev SS car
I've beeen toying with the idea of a (NHRA)56 Super Stocker with a 265 225hp engine. Any idea of a good starting point for shocks, springs, ladder bar set up. I think I read next year you can run a 4 speed in one of these cars.
__________________
Life is like a roll of toilet paper.....the closer it gets to the end, the faster it goes.
Bob W is offline   Reply With Quote
Old 08-12-2010, 11:14 PM   #2
punisher55
Senior Member
punisher55's Avatar
Member #10773
Default
Quote:
Good starting point would be cal tracs in the rear. Ladder bars would not be necessary. Landrum or cal-trac sells new leaf springs. Some good adjustable shocks front and rear, and some moroso trick springs in the front for weight transfer. Grind those ridges off of the control arm bushings too My car was set up like this for years(except i had traction bars instead of cal-tracs) and went 6.70's in the eighth mile consistently. That sounds like it could be a lot of fun. Go for it
__________________
55 chevy, all motor, 10.5 inch tires, mufflers
5.60's 1/8th mile at 120 mph
punisher55 is offline   Reply With Quote
Old 08-13-2010, 09:01 AM   #3
Old Buzzard
Senior Member 3 Gold Stars
Old Buzzard's Avatar
Member #3388
Send a message via AIM to Old Buzzard
Default
If you have intentions of being "competitive", maybe spend some time w/ others that are trying this combo.
The maintenence cost is astronomical.....
A case in mind: my bud's friends in Neb, are doing the SS thing w/ a 56 wagon...All I can say is, CUBIC DOLLARS!
__________________
Chuck
Injector inspector.
55 210 sedan/ LQ9 tyrfryer..:evilgrin0002:
Hotrodding and dragracing since 1955.:eek:
USAF 1960-1964
Old Buzzard is online now   Reply With Quote
Old 08-13-2010, 10:37 AM   #4
OLKY55
Member
OLKY55's Avatar
Member #11676
Default
I've gotta agree with Buzzard. Those Super Stock guys are serious, dedicated racers.
There are a few tri-five SS'ers around. You would suit yourself well if you could pick their brain some and see if they could maybe give you good ideas/direction for that combination. Some of them are quite secretive, but others would be glad to share all they know.
I'm pretty sure you're gonna need a roll cage to run SS. I'm not sure if you'll have to back-half it, because I don't think those cars run too big of a tire. The guy I knew back in the 80's had his mini-tubbed. I'm not sure if you could still get by with that, but a chassis shop experienced building SS class cars could help you.
I hope I haven't discouraged you, because I still think the SS tri-fives are some of the coolest cars running. Good luck with it.
OLKY55 is online now   Reply With Quote
Old 08-13-2010, 12:30 PM   #5
Jim Cimarolli
Jim Cimarolli's Avatar
Member #13860
Smile
Bob W.
I just retired my '57 Wagon from drag racing, and it was great working car with a 9 inch tire. I was using Tri-City Competition service rear Launcher springs on the rear and Moroso trick front springs. The rear springs are designed to work without any other traction device, just clamps on the front segments. I have both sets of springs that I would like to sell if you think this might work for you. I am an old NHRA racer and I know Randall Klein very well. He is the guy mentioned in an earlier post with the '56 Nomad 265/225 SS/NA. My phone number is 903-885-7736.
Jim Cimarolli is offline   Reply With Quote
Old 08-13-2010, 12:33 PM   #6
punisher55
Senior Member
punisher55's Avatar
Member #10773
Default
You can be very competitive in Super Stock without spending a ton of money. All you have to do is make sure your car will run under the index for your class and dial it in during the race .Even at a National event, the chance of you having to run a car thats in the same class as you would be slim (at that point it would be heads up and fastest car wins). Its like bracket racing UNLESS you are trying to set records in your class then its all about the $$$$$$
__________________
Old 08-13-2010, 10:03 PM   #7
Jr.Fuel
Member
Jr.Fuel's Avatar
Member #13213
Default
Quote:
The maintenance cost is astronomical..... A case in mind: my bud's friends in Neb, are doing the SS thing w/ a 56 wagon...All I can say is, CUBIC DOLLARS!
Super Stock is not a game for those unfamiliar with these Cars &/or Classes.
And it takes a huge commitment of both time and money to be competitive (I speak from experience of racing nhra stock eliminator for over 30 years).
Here's a couple of guys that are still running the '56 Chevys as SS cars (and both have been at this, with these same vehicles for over 30+ years each)....
Rick Pike & Sheldon Erfle ( both are Canadians too )....
Rick is from BC; and Sheldon is from Assinaboia / Saskatoon, Sask).
Maybe you should consider wetting your feet with 'Class Racing' by building an IHRA 'Stocker' out of your '56, like this '55 of Shelby Hurley out of MD....
It's plenty cute, and it runs under the indexes as well!!
While Stock is a bit less expensive than a SS car, it is still just as much of a challenge and takes as much commitment to be competitive.
Good Luck, and keep us all informed of what you are planning or where you might end up!!
(just found another photo - John Angelo's '56 SS/NA )
__________________
Jr.
Jr.Fuel is offline   Reply With Quote
Old 08-14-2010, 01:57 PM   #8
56owner
56owner's Avatar
Member #14020
Default S/S car
I had a friend (now retired) who ran in S/S . He found a different glass manufacuturer who made glass .005 thinner than what was in his car so all the glass in his car had to be replaced right away.
56owner is offline   Reply With Quote
Old 08-18-2010, 12:23 PM   #9
punisher55
Senior Member
punisher55's Avatar
Member #10773
Default
Quote:
Yes, those super stockers have a lot of neat "tricks". When you can take a factory rated 295 horsepower 350 and run 9's in the quarter, in a 3100 pound car, you are getting everything possible out of it. We are talking flat top pistons, stock 041 casting gm heads, quadrajet carb,etc....:eek: very impressive
__________________
Old 08-18-2010, 07:45 PM   #10
henrys57wagon
Senior Member 1 Gold Star
henrys57wagon's Avatar
Member #2131
Default
I helped when Rick Jone's (stoney) built his 55 SS and we built an front angled carb spacer. I think it was either SS/O or P, good day.
__________________
57 wagon 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 51/53 HenryJ Corsair's, 07 2500HD with 26.5 Prowler 5th wheel travel trailer, 09 Impala LT, CDN coordinator for ChevyTalk.org,
http://www.picturetrail.com/gallery/...wagon&x=14&y=6
henrys57wagon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
