Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Metal Fabrication & Repair Questions > Metal Fabrication and Repair Questions
User Name
Password
Mark Forums Read
Metal Fabrication and Repair Questions Ask all your Metal Fabrication and Repair Questions.
Reply
Thread Tools Display Modes
Old 09-04-2010, 06:52 PM   #1
Chevyman for life
Senior Member 1 Silver Star
Chevyman for life's Avatar
Member #4633
Default Quarter panel patch shape
Looking for some experienced thoughts on patch panel shape. I am about to replace the flared rear wheel openings with stock openings on my '55.
As shown in the attached photos, the openings were cut above the normal rear quarter trim strip. I can't afford new quarters so I got two 4 door pieces cut from a solid, rust free '55. There's a lot of bondo at the weld seam but it's stitch welded or spot welded so I'll have to see what shape the fender is in but I can cut above the previous weld.
Other than the dog leg I can cut a large retangle or I can cut up, then at a 45 deg angle, horizontal, down a 45 degrees and then down vertical. My question is whether one method is better than an other as far as less warpage. I'll be using a MIG with Argon mix and spot welding back and forth.
I'd appreciate any experienced ideas.
__________________
Gerry
My nightmare project - a butchered '55 someone gave up on. Now I know why.
Chevyman for life is online now   Reply With Quote
Old 09-04-2010, 07:10 PM   #2
Rick_L
Trifive Leaders Club
Member #2256
Default
The same question was asked in bit of a different context a while back. Since the crown in the quarter is primarily vertical and the quarter is pretty flat horizontally, it's probably easier to see where your warpage is if you keep the cuts either vertical or horizontal. Actually that may be more of a picky thing than needed.
There is a big exception to this. You don't want the cuts and welds to meet at a square corner. Put a pretty big radius on all the corners of your cuts and welds. This part is more important.
Last thing, if possible, make your cuts and welds inside the wheel house if possible. This will let you get behind the panel with a dolly to stretch the shrink out of the weld joints. This is very important. See MP&C's post from a week or two ago on patch panels, stretching to remove weld shrinkage etc.
If the original cut is close to the wheel house, you may want to remove it temporarily.
Rick_L is online now   Reply With Quote
Old 09-07-2010, 01:40 AM   #3
Chevyman for life
Member #4633
Default
Rick,
Thanks for the advice and the other link to Robert. When you say a large radius at the corners how large do you mean? 4" radius or larger? The wheelhouse doesn't look to be a problem.
__________________
Gerry
Old 09-07-2010, 07:34 AM   #4
Rick_L
Member #2256
Default
4" radius would be pretty big. 1-2" would do it. You just want to eliminate the square corner.
Old 09-07-2010, 08:48 AM   #5
pistoncan
Senior Member 2 Gold Stars
pistoncan's Avatar
Member #9995
Send a message via AIM to pistoncan
Default
I think Rick is correct, you can also just nip off the corner to make a 2 inch 45 degree flat. My dad said to make your patch panel, then mark and cut your fender to match your patch panel. Don;t try to make your patch panel fit the hole in yoiur fender. You will run out of patch panel alot sooner than you run out of fender.
Gary
__________________
Gary
How come everything I do is now considered "Old School?"
Nottin beats cubic inches except a TURBO
pistoncan is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
