Help - engine coolant sensor - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Welcome to Trifive > Chit Chat Area, Anything on your mind goes here.
User Name
Password
Mark Forums Read
Chit Chat Area, Anything on your mind goes here. Chit Chat Area, Anything on your mind goes here. Just an area to Shoot the Bull. No Politics Allowed = No Religious Debate allowed, Keep it clean please. Click here to watch help videos for new and current members first please.
Reply
Thread Tools Display Modes
Old 03-26-2011, 06:30 PM   #1
hhpmike
Member
Member #14399
Default Help - engine coolant sensor
Help - I am installing a new vintage air system and need to use the port in my intake manifold for a heater hose. But that port currently has a coolant sensor in it - and I need to find a way to measure the engine coolant temp. Any ideas?
Thanks, Mike
hhpmike is offline   Reply With Quote
Old 03-26-2011, 06:50 PM   #2
mitch hennings
Senior Member 1 Silver Star
mitch hennings's Avatar
Member #13775
Default
Use the one on right cylinder head . It has a pipe plug in it now you can use a3/8 extension get it out and put the sender there.
mitch hennings is online now   Reply With Quote
Old 03-26-2011, 06:53 PM   #3
57-Z06
Senior Member 4 Gold Stars
57-Z06's Avatar
Member #1699
Default
Mike,
I assume that you're running a V8. That being the case, there are plugs in both cylinder heads (front and rear) that will work well for a temperature sending unit. If you're using a "manual" sending unit, the cylinder head opening may not be deep enough to facilitate that.
Ray
__________________
Ray
"The happiest people don't necessarily have the best of everything, they just make the best of everything they have." (author unknown)
57-Z06 is offline   Reply With Quote
Old 03-26-2011, 07:25 PM   #4
557B210
557B210's Avatar
Member #5571
Default
What year is your engine? They didn't start putting plugs for temp sensons, until late 60's yearly 70's....If that's the case there are other options....Such as a thermostat housing with a temp senson bung....Just gotta know.
__________________
_______________________________
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Old 03-27-2011, 05:53 PM   #5
hhpmike
Member
Member #14399
Default
The engine is a 1966, 327. There are no other plugs in the cylinder heads. I like the idea of the thermostat housing with a temperature sensor bung - do you know where I might find one?
Thanks, Mike
Old 03-27-2011, 07:03 PM   #6
hhpmike
Member
Member #14399
Default
Thanks, I found a thermostat housing spacer with several ports.
Mike
Old 03-27-2011, 07:16 PM   #7
557B210
557B210's Avatar
Member #5571
Default
Quote:
Originally Posted by hhpmike View Post
Thanks, I found a thermostat housing spacer with several ports.....Mike
Mike....Please provide a link to the sensor or tell us where you got it.....So otheres with the same problem following the thread will know as well.
__________________
Old 03-28-2011, 07:54 AM   #8
hhpmike
Member
Member #14399
Default
I found a 1" spacer with two extra 1/2 npt ports at Street Rod Stuff and a temperature sensor at Summit Racing. Later I found a 1.5" spacer with one extra port at Vintage Air.
Although this isn't the greatest fix to my issue (I'm taking the coolant temp on the other side of the thermostat), It will have to do. Thanks for the help.
Mike
Old 03-28-2011, 08:57 AM   #9
557B210
557B210's Avatar
Member #5571
Default THANKS Mike!
Description:
This 1" aluminum spacer mounts below the thermostat housing & gives you an additional pair of 3/8" N.P.T. female ports. These can be used for quick and easy connections for a temperature gauge, fan switch, or various sending units.
Both the top & bottom surfaces feature an o-ring design for optimum sealing to prevent leakage while providing a universal fit.
•Fits Small & Big Block Chevrolet V-8 engines.
•DOES NOT FIT '92-97 LT1 & LS1, LS6 based Chevy engines
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
