Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Cooling Systems, Radiators, Fans / A/C
User Name
Password
Mark Forums Read
Cooling Systems, Radiators, Fans / A/C Engine Cooling Systems, Radiators, Fans / Shrouds, water pumps, anything cooling related. Air conditioning etc.
Reply
Thread Tools Display Modes
Old 04-14-2011, 02:11 PM   #1
roger1
Trifive Leaders Club
roger1's Avatar
Member #5484
Default Vintage Air heater hose valve observation
I hooked mine up directly to the battery today just so I could start the engine and make sure all of the air is out of my cooling system and I wanted to have circulation through the heater core. (I don't have the VA harness hooked up yet. But I know from the schematic that it hooks up to a standard relay so there isn't a reduced voltage or duty cycle sent to this valve.)
Before starting my cool engine, I hooked up the wires and left it for a minute.
This solenoid gets hot! Too hot to keep a finger on it.
It really surprises me that this solenoid would draw that much current to do that. It doesn't seem right to me.
Comments?
__________________
'55 Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd
'57 3200 Pickup - 235 6 cylinder / 3 on the tree (Soon to be 305 TPI / 700R4)
Photo Albums:
http://www.hotrodders.com/gallery/sh...0/ppuser/17782
roger1 is offline   Reply With Quote
Old 04-14-2011, 03:38 PM   #2
acardon
acardon's Avatar
Member #1888
Default
Roger, the relay is controlled by the microprocessor, so it may only stay picked for a second. If it is a solenoid, it won't take long to open or close.
__________________
Don
acardon is offline   Reply With Quote
Old 04-14-2011, 04:02 PM   #3
roger1
roger1's Avatar
Member #5484
Default
Quote:
Don, I believe this valve is an "all on" or "all off" design and the heat control on the dash controls a servo on the unit that moves a door to regulate heat.
So, if the heater is turned on, the relay is fired.
__________________
Photo Albums:
Old 04-14-2011, 04:35 PM   #4
acardon
acardon's Avatar
Member #1888
Default
If the solenoid is heating up from electrical current after a minute, I don't see how it could last long, either. It's not heating from the water?
__________________
Don
Old 04-14-2011, 05:42 PM   #5
roger1
roger1's Avatar
Member #5484
Default
I hadn't even started the engine yet. So, no. But, like I said, in about a minute of being fired, it's too hot to keep your fingers on it. I tried it again reversing the polarity. But, it didn't make any difference.
I was going to hook up my little meter on it but it will only measure up to 200 mA.
So, I did a little trial and error with some fuses. With a 2 amp fuse, the fuse gets real hot but didn't blow it. A 5 amp fuse didn't seem to get hot. So, I'd say it's probably a 3 - 4 amp draw.
__________________
Photo Albums:
Old 08-16-2011, 01:18 PM   #6
cruzer55
Member
Member #6986
Default heater control valve
I installed a Vintage Air Gen IV Sure-fit system in my '55 this summer. The water control valve also gets too hot to touch. Is this a common problem with this valve? Has anyone requested info about this from V. A. tech assistance? If I removed the valve and replaced it with a manual ball valve would it cause any problems with the electrical circuits in the system?
cruzer55 is offline   Reply With Quote
Old 08-16-2011, 01:38 PM   #7
acardon
acardon's Avatar
Member #1888
Default
Quote:
No, it won't hurt anything to disconnect it. Like Roger said, it it powered through a relay and is either on or off. The electronics control the relay. But, I would call Vintage about it. It doesn't draw much current, so it shouldn't get too hot. ???
__________________
Don
Old 08-16-2011, 01:59 PM   #8
roger1
roger1's Avatar
Member #5484
Default
Agree. I can't see how it could hurt anything to not use the electric valve and go manual.
I'm now guessing that my observation is no fluke and this is just they way the valves are designed.
I got a run around trying to get info from VA tech support about the cut-in/out pressures on the Trinary switch. I assumed I would be wasting my time on this issue as well.
I really don't see this issue causing problems. It just seems inefficient for it to draw that high of a current for it's purpose. Like I said earlier, after my crude test, I'm estimating that it draws 3 or 4 amps. That's about as much current as one low beam headlight.
It this valve doesn't last, I'll probably put in a ball valve and operate it manually.
__________________
Photo Albums:
Old 08-16-2011, 07:35 PM   #9
Jim Cimarolli
Senior Member 1 Blue Star
Jim Cimarolli's Avatar
Member #13860
Wink
I had the same apprehension about that valve when I installed my VA system. They assured me it would be OK, and I have never had an issue with it. Put 5000 miles on the car since I installed the system.
Jim Cimarolli is offline   Reply With Quote
Old 08-17-2011, 11:10 PM   #10
roger1
roger1's Avatar
Member #5484
Default
Quote:
Originally Posted by Old Buzzard View Post
If it's hooked up, and the key is on, it gets hot.
Not unless the heater is turned on. The valve is normally closed.
__________________
Photo Albums:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
