| Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc |
#1 |
Senior Member 1 Silver Star
I have put on new tail pipes, new trunk gasket, no exhaust manifold leaks and I still keep smelling exhaust fumes inside the car. How are the exhaust fumes getting in the car? We went to a car show today and the wife is not happy...!!! Needless to say it could be dangerous anyway with the carbon monoxide inside as well. An ideas or suggestions????I'll try anything at this point before she closes the check book due to the bad smell....George
__________________
George |
#2 |
Senior Member 3 Gold Stars
tail pipes extend past the bumper??
__________________
Chuck Injector inspector. 55 210 sedan/ LQ9 tyrfryer..:evilgrin0002: Hotrodding and dragracing since 1955.:eek: USAF 1960-1964 |
#3 |
George....Have an idea....Sent you a PM.
__________________
___________________ ____________________david aka POPS & sherry ![]() __________________55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan |
#4 |
Yes...matter of fact the the old tail pipes were turned down at the rear axle housing and that is what I thought was the problem. But I was wrong the smell is still strong. In 15 miles with the windows up you can't stand it without fresh air. Do you think the exhaust is coming thru the trunk gasket, you know the exhaust is twirling around behind the car going down the road. At least when it is cold outside you can see it.
__________________
George |
#5 |
George....Decided to post this to see what others might think....Here's my red neck idea:If you have access to a lift, you could squirt a little oil in the carburetor with the engine running....Then raise the car and block the exhaust at the ends with a potato or something.....You should then be able to readily see where the exhaust leaks might be.
Just thinking out loud....Getting close to Easter....No crusifications please. ![]()
__________________
#6 |
Member
You sure it is exhaust and not a rich condition at the engine? Years ago I too had a problem with "she who must be obeyed" and smells in the 56. I found that my ignition was not up to par and was running too rich. Electronic ignition, better coil and an O2 sensor fixed the problem.
#7 | |
Quote:
__________________
George |
#8 |
Ever thought about checking every thing in/on the firewall?
#9 |
Senior Member 1 Blue Star
![]() Join Date: Sep 2008
Location: N. of Los Angeles, far enough away thank heavens.
Member # |
Tell her with the high cost of gas, it is an added feature they put in so you can smell your money burning up as well as just driving in the car.
#10 |
Everything I can possible seal and plug.
__________________
George |
| Thread Tools | |
| Display Modes | |
