Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Cooling Systems, Radiators, Fans / A/C
User Name
Password
Mark Forums Read
Cooling Systems, Radiators, Fans / A/C Engine Cooling Systems, Radiators, Fans / Shrouds, water pumps, anything cooling related. Air conditioning etc.
Grand Opening of our New Truck Forum, Click here to win 100.00 Cash
Reply
Thread Tools Display Modes
Old 04-17-2011, 10:05 PM   #1
Charlie55
Member
Member #15502
Default radiator-cooling question
I bought this 55 back in the winter, now that we are in the spring I'm concerned about over heating. I do not know a lot about the history of the car. It's a 327 4 speed car, appears to be a strong engine, runs great!
Just around town stop/go it runs about 190 degrees, when I cruise on the highway it heats up to about 210 degrees. It has a flex fan, no shroud. The radiator appears to be an original type. (I thought a shroud helped in stop and go traffic). While cruising on the highway it turns up 2800 rpm @ 65mph. Any thoughts?? I'm not a mechanic however I would expect the opposite hot in stop/go and cooler @ highway speeds. I have added a few pictures of the set-up.
Charlie55 is offline   Reply With Quote
Old 04-17-2011, 10:25 PM   #2
topdog
Senior Member 1 Silver Star
topdog's Avatar
Member #15087
Default cooling issue
Could be that the coolant is running to fast thru the radiator . Does it have a thermostat . I am running a modified 327 4 speed with flex fan and no shroud and engine runs cool.
topdog is offline   Reply With Quote
Old 04-17-2011, 10:38 PM   #3
55
Senior Member 1 Gold Star
55's Avatar
Member #14050
Default
Put a 185/195 theromstat in there and maybe try a smaller trans cooler. It should be ok with that pusher fan up there to assist things but I'm sure that trans cooler is blocking a lot of air. You could also try a better flex fan in there such as one of the good aluminum ones if there's enough room.
The fact that it heats up on the highway almost tells me the coolant is free flowing and that it might not have a thermostat. That's the first thing to check. Mine ran 195-200 in town and 185-190 on the highway or at speed but I also had a 3 row core in a V8 position.
__________________
Double Nickel 55 Chevrolet
Big Block 565 with Tremec 6-Speed
713 Horsepower @ 727 Foot Pounds
See the frame off restoration of my 55 Chev in the project section here on TriFive, or visit my website www.fiftyfivechev.com for all the details!
Old 04-17-2011, 10:39 PM   #4
topdog
topdog's Avatar
Member #15087
nothing stock about your set up. looks like a non stock cross flow radiator with aux FAN. one fan pushes air and one pulls air. still think coolant may be moving so fast at high speed it doesnt cool. Is the pusher fan ( one in front of radiator) running all the time or it controled with a temp. switch.
Old 04-17-2011, 10:50 PM   #5
Charlie55
Member
Member #15502
Default
the pusher fan is on the ac condenser, 5 inches or so infront of the radiator, I replaced the thermostat with 160 degree, should I go higher and slow down the flow???
Old 04-17-2011, 11:52 PM   #6
trifive
trifive's Avatar
Member #1
Default
When you replace the thermostat, don't get the cheap ones, ask for the best they have , trust me they are really made differant , that is all it took to cure a heating problem on my truck.
Otis
trifive is online now   Reply With Quote
Old 04-18-2011, 02:36 PM   #7
Chevynut
member
Chevynut's Avatar
Member #1769
Default
Quote:
Oh jeezus.
Chevynut is offline   Reply With Quote
Old 04-18-2011, 02:42 PM   #8
Chevynut
member
Chevynut's Avatar
Member #1769
Default
Quote:
A higher temp thermostat won't slow down the flow. In fact, a thermostat's job is to keep the engine hot, not to cool it. So putting in a cooler temperature thermostat will do nothing to help an overheating situation..it's already fully open no matter the temperature rating.
If you slow the flow down, you will cause it to run hotter. That's a physical fact.
It's possible that your flow is restricted now by a partially clogged radiator, or by the radiator outlet hose collapsing at higher pump flow rates. Make sure there is a wire coil inside the hose. Also your pusher fan could be causing a problem by blocking air through the radiator at higher speeds, when the engine is making more power. I would consider removing the pusher fan and see if that makes a difference. Puller fans are a lot better.
Old 04-18-2011, 03:08 PM   #9
wraplock
Senior Member 2 Gold Stars
wraplock's Avatar
Member #1500
Default
a shroud would help but be sure your fan blades are between 1/2 to 3/4 of the way into the shroud for it to work properly. As Chevynut suggested check to see if you have a coil spring in the lower hose to insure against collapse. I don't like the aluminum flex fans. They are meant to flatten out at higher speeds and then they draw less air. Seems to me you need more air flow at higher speeds not less. The ac condenser looks like it's blocking a lot of air flow so I would run a fan that pulls more air and use a shroud. A good steel fan with 5 or more steel blades and a shroud is what I use, and I do not use a clutch fan.
Don
wraplock is offline   Reply With Quote
Old 04-18-2011, 03:46 PM   #10
Rick_L
Trifive Leaders Club
Member #2256
Default
You probably have either a clogged radiator or a thermostat that doesn't open all the way.
Both are examples of how a restriction (or restrictor) causes overheating rather than preventing it.
Rick_L is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
