Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > Welcome to Trifive > Chit Chat Area, Anything on your mind goes here.
User Name
Password
Mark Forums Read
Chit Chat Area, Anything on your mind goes here. Chit Chat Area, Anything on your mind goes here. Just an area to Shoot the Bull. No Politics Allowed = No Religious Debate allowed, Keep it clean please. Click here to watch help videos for new and current members first please.
Reply
Thread Tools Display Modes
Old 06-05-2011, 07:19 AM   #1
auggie56
Trifive Leaders Club
auggie56's Avatar
Member #3147
Default All American 1943
Feb 1st 1943
A mid-air collision on February 1, 1943 between a B-17 and a German fighter over the Tunis dock area became the subject of one of the most famous photographs of World War II. An enemy fighter attacking a 97th Bomb Group formation went out of control, probably with a wounded pilot then continued its crashing descent into the rear of the fuselage of a Fortress named All American, piloted by Lt. Kendrick R. Bragg, of the 414th Bomb Squadron. When it struck, the fighter broke apart, but left some pieces in the B-17. The left horizontal stabilizer of the Fortress and left elevator were completely torn away.
The two right engines were out and one on the left had a serious oil pump leak. The vertical fin and the rudder had been damaged, the fuselage had been cut almost completely through – connected only at two small parts of the frame and the radios, electrical and oxygen systems were damaged. There was also a hole in the top that was over 16 feet long and 4 feet wide at its widest and the split in the fuselage went all the way to the top gunner’s turret. Although the tail actually bounced and swayed in the wind and twisted when the plane turned and all the control cables were severed, except one single elevator cable still worked, and the aircraft still flew-miraculously!
The tail gunner was trapped because there was no floor connecting the tail to the rest of the plane. The waist and tail gunners used parts of the German fighter and their own parachute harnesses in an attempt to keep the tail from ripping off and the two sides of the fuselage from splitting apart. While the crew was trying to keep the bomber from coming apart, the pilot continued on his bomb run and released his bombs over the target.
When the Bombay doors were opened, the wind turbulence was so great that it blew one of the waist gunners into the broken tail section. It took several minutes and four crew members to pass him ropes from parachutes and haul him back into the forward part of the plane. When they tried to do the same for the tail gunner, the tail began flapping so hard that it began to break off. The weight of the gunner was adding some stability to the tail section, so he went back to his position.
The turn back toward England had to be very slow to keep the tail from twisting off. They actually covered almost 70 miles to make the turn home. The bomber was so badly damaged that it was losing altitude and speed and was soon alone in the sky. For a brief time, two more Me109 German fighters attacked the All American. Despite the extensive damage, all of the machine gunners were able to respond to these attacks and soon drove off the fighters. The two
waist gunners stood up with their heads sticking out through the hole in the top of the fuselage to aim and fire their machine guns. The tail gunner had to shoot in short bursts because the recoil was actually causing the plane to turn.
Allied P51 fighters intercepted the All American as it crossed over the Channel and took one of the pictures shown below. They also radioed to the base describing the empennage was “waving like a fish tail” and that the plane would not make it and to send out boats to rescue the crew when they bailed out. The fighters stayed with the Fortress taking hand signals from the Lt. Bragg and relaying them to the base. Lt. Bragg signaled that 5 parachutes and the spare had been "used" so five of the crew could not bail out.
He made the decision that if they could not bail out safely, then he would stay with the plane and land it. Two and a half hours after being hit, the aircraft made its final turn to line up with the runway while it was still over 40 miles away. It descended into an emergency landing and a normal roll-out on its landing gear. When the ambulance pulled alongside, it was waved off because not a single member of the crew had been injured.
No one could believe that the aircraft could still fly in such a condition. The Fortress sat placidly until the crew all exited through the door in the fuselage and the tail gunner had climbed down a ladder, at which time the entire rear section of the aircraft collapsed onto the ground. The rugged old bird had done its job.
__________________
‎Free Speech Is Dead
"The White Hut" Toledo Ohio, a popular hangout of the car generation of the sixties.
auggie56 is online now   Reply With Quote
Old 06-05-2011, 08:19 AM   #2
Ratpackin
Trifive Calendar Editor
Ratpackin's Avatar
Member #2702
Default
Wow, what a story, thanks for posting this!
__________________
Phil -Hayward California
portfolio and contact: bitoart.com/logoindex.htm
Ratpackin is offline   Reply With Quote
Old 06-05-2011, 08:28 AM   #3
mickeywestsr
mickeywestsr's Avatar
Member #1970
Thumbs up
, Great story, thanks for sharing.
__________________
GO VOLS
COWBOY
mickeywestsr is offline   Reply With Quote
Old 06-05-2011, 08:33 AM   #4
57-Z06
Senior Member 4 Gold Stars
57-Z06's Avatar
Member #1699
Default
That's an amazing story.
Ray
__________________
Ray
"The happiest people don't necessarily have the best of everything, they just make the best of everything they have." (author unknown)
57-Z06 is offline   Reply With Quote
Old 06-05-2011, 09:41 AM   #5
zicoh
Senior Member 1 Blue Star
zicoh's Avatar
Member #14563
Default
Amazing story, glad to hear they all made it back.
zicoh is online now   Reply With Quote
Old 06-05-2011, 09:51 AM   #6
Chrome Lugnut
Chrome Lugnut's Avatar
Member #14896
Default
Great incredible Story
__________________
OLD CARS are REAL AMERICAN FREEDOM
Les
Chrome Lugnut is offline   Reply With Quote
Old 06-05-2011, 10:15 AM   #7
wvporkchop
Senior Member
Member #10349
Default
That story is incredible.And so are those guys.
wvporkchop is offline   Reply With Quote
Old 06-05-2011, 10:26 AM   #8
oldfart
Senior Member 3 Gold Stars
oldfart's Avatar
Member #8009
Default
Man what a story..I bet that if the plane were one of todays plastic planes,the story would have a very different ending..
__________________
I may have Alzheimers, but at least I don't have Alzheimers.
Of all the things I've lost,I miss my mind the most.
When I was 25,I was a Stud Muffin.Now I'm just a Muffin..
Wanted;good looking natural blond lady w/a 55 Nomad.Pls send picture of the Nomad.
oldfart is offline   Reply With Quote
Old 06-05-2011, 10:29 AM   #9
DraginMain
Senior Member 1 Silver Star
Member #15354
Default
Thanks for sharing that B-17 story. My half brother Bill made 54 missions on one and managed to survive. They needed to have 50 missions to return home. With 49 missions under his belt and his plane was down for repairs so he joined another crew and flew 5 more. While he was with the new crew his original plane and crew finally got repaird and made what was to be their last as they were shot down and all lost. Only by the grace of God was my brother spared. He rarely if ever mentioned that he'd been in combat.
Here's a pic of his first plane.
__________________
"Where you girls from? Turlock High"
DraginMain is online now   Reply With Quote
Old 06-05-2011, 10:33 AM   #10
mr 265
mr 265's Avatar
Member #10768
Default
Thanks for the post ---
mr 265 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
