Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
User Name
Password
Mark Forums Read
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Reply
Thread Tools Display Modes
Old 07-27-2007, 08:12 PM   #1
Pro Fleetline
Senior Member 1 Blue Star
Pro Fleetline's Avatar
Member #2477
Default ? about what master cylinder to run.......
Looking to update my single master cylinder to a nice dual peice with out the huge booster i have seen some that are a nice bolt in replacement. Any idea what peice would work on my 56 2-10 still has drum brakes just looking for a nice upgrade nothing to exotic. is there a GM peice that will work or an aftermarket? Thanks for any input
Pro Fleetline is offline   Reply With Quote
Old 07-27-2007, 09:26 PM   #2
Rick_L
Trifive Leaders Club
Member #2256
Default
Go to the auto supply and get a master cylinder for a 67-68 Camaro, Nova, or Chevelle with manual drum brakes. It will bolt to the lower pair of bolt holes that your original used. Then all you need to do is connect your old brake line to the front port on the m/c (or a replacement line). At the tee at the right front brake, disconnect the line to the rear brakes and plug the tee where you disconnected. Now run a new line from the rear port on your new m/c to the rear brake line that you disconnected. You should be able to get all you need at the auto supply, but it might be nice to cut and flare the new line so it fits nice and looks good. Now would be a good time to get new hoses if they are aged.
Rick_L is online now   Reply With Quote
Old 07-28-2007, 10:51 AM   #3
Pro Fleetline
Member #2477
Default
Thanks sounds just like what im looking for thanks again
Old 07-28-2007, 08:37 PM   #4
henrys57wagon
Senior Member 1 Gold Star
henrys57wagon's Avatar
Member #2131
Default
You could use a 71 Nova drum brake M/C also. Good day, Henry.
__________________
57 wagon 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 51/53 HenryJ Corsair's, 07 2500HD with 26.5 Prowler 5th wheel travel trailer, 09 Impala LT, CDN coordinator for ChevyTalk.org,
http://www.picturetrail.com/gallery/...wagon&x=14&y=6
henrys57wagon is offline   Reply With Quote
Old 07-29-2007, 12:19 PM   #5
JLS
Photo Editor
JLS's Avatar
Member #1326
Default
Does anybody know what the piston diameter is on the manual drum brake Camaro M/C? Are they small diameter like manual disc M/C's? I know they have Vette manual disc brake M/C's that are 1" bores but were Camaros available with manual discs? What is the bolt spacing of those M/C's that fit on the firewall?.......wow that's a lot of questions...I need a nap!
Joe
JLS is offline   Reply With Quote
Old 07-29-2007, 12:30 PM   #6
Rick_L
Member #2256
Default
1" bore is the answer to all your questions. There were manual discs available on Corvettes, I have no idea about Camaros.
The only functional difference between a disc brake master cylinder and a drum brake master cylinder is the possible presence of residual pressure valves on the drum brake models on 67-70 model cars. These can be removed if present.
The other difference in master cylinders is that drum/drum units usually had 2 small reservoirs, disc/drum units had a large reservoir and a small reservoir, and disc/disc (Corvette) had 2 large reservoirs. While the large reservoirs are nice, you can run a small reservoir master cylinder with discs - you just need to check the fluid level more often.
Old 07-29-2007, 05:41 PM   #7
henrys57wagon
Member #2131
Default
Again on our disc/drum 71 Nova we have a manual M/C off same application. Good day, Henry.
__________________
Old 07-30-2007, 07:45 AM   #8
Black 55
Senior Member 1 Silver Star
Black 55's Avatar
Member #1876
Default
Where are these residual pressure valves located on the master cyl? Thanks, jim
__________________
55 Chevy 2 dr post
540 ci with 871 Blower
67 Nova
496 ci/ 250 nos. 2450#
55 build use slideshow
http://s116.photobucket.com/albums/o31/Black-55/
www.associatedornamental.com
www.texasoutsiders.com
Black 55 is offline   Reply With Quote
Old 07-30-2007, 08:12 AM   #9
Rick_L
Member #2256
Default
They are a rubber "duck bill" type valve located under the brass flare seat cone. You can insert the blank end of a drill bit in there to see if you feel a rubber part.
You don't want them in there if the line is connected to a disc brake, as it will cause the pad to drag on the rotor.
You can remove them by tapping the cone for a 6-32 thread. Then put a 6-32 screw about 1" long in the hole, and pull the cone out with a claw hammer. The residual valve just sits in there, remove it with your fingers. Clean everything, remove the burrs from the cone, and replace it.
In the past I've found new cones at the auto supply, but I haven't been able to recently.
I've also purchased rebuilt master cylinders recently that should have had them, but did not (A-1 Cardone brand).
Old 07-30-2007, 08:25 AM   #10
bigbopper
bigbopper's Avatar
Member #2079
Default Mastercylnder and residual pressure valve
Hello,
Late 60's master cylnders are the way to go like several others have stated. That was the beginning of the disc brake option on GM cars, so there was some nice 1" bore MC's with the drum/drum avaiable. There was also disc/drum non power assisted options available clear up to the early 70's. My favorite MC for disc/disc setups is the 1968 Corvette non power assisted. What I suggest is you go to your favorite jobber and tell them you would like a MC for ????? late 60's GM car with the set-up you have disc/drum for example and let GM engineers figure out the design you need.
If you have your brake lines off and look into the port where your lines attach. Your drum brake port will have a thin brass cover hiding the port opening and behind it is a rubber wafer and this is what GM used for a residual pressure valve. It is always a good idea to check this prior to installation and make sure it fits your application. If you later want to add disc brakes, all you have to do is remove this "check valve". I just use a thin srew driver and work it out.
I hope this helps
bigbopper is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
