Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Super Stock / Pro Street and Modified Discussion 55-56-57
User Name
Password
Super Stock / Pro Street and Modified Discussion 55-56-57 Super Stock / Pro Street and Modified Discussion 55-56-57 Talk engines, race tracks , setup's etc
Parts on Ebay
Reply
Thread Tools Display Modes
Old 08-05-2007, 03:11 PM   #1
Hafrod
Senior Member 4 Gold Stars
Hafrod has made a donation to the forum!
Hafrod's Avatar
Member #1291
Default Holley bog
I got my 55 runnin' yesterday. When I hit the throttle in park or driving it bogs pretty bad, then goes. It seems like it's in the primaries if I can get it to do it in PARK. It's a BRAND NEW Holley 750 3310 vac secondary. After the bog, this thing feels pretty strong!! Even driving in my neighborhood it acts like it's surging. I set the needles out 1&1/2 turns, On the vac. gauge I have 16 lb of vac., so I put in an 8.5 power valve. I advanced the timing and retarded the timing but still have the studder. I have a 355 dish, 305 H.O. heads ported, Crane springs matched to a 465-488 cam, dual plane intake, patriot headers, Flowmasters, 350 turbo trans, shift kit, 3500 stall.brand new Mallory HEI and 8mm wires, AC R43TS plugs gapped at 40, 125 shot NOS, stock rear(rebuilt) 370 gears, aluminum radiator with black majic electric fan. I CANNOT REMEMBER IF I PUT THE TIMING CHAIN IN 4 DEGREES ADVANCE OR STRAIGHT UP!!! This bogging-studder thing has me going nuts!!!
Hafrod is offline   Reply With Quote
Old 08-05-2007, 03:28 PM   #2
Hafrod
Hafrod's Avatar
Member #1291
Default
I might also add that my jets are 66's, my float level is set correctly, and the fuel press is 6 1/2
Old 08-05-2007, 05:52 PM   #3
Hafrod
Hafrod's Avatar
Member #1291
Default
I just caught it on fire!!! I put it in drive, punched the throttle and POOF! It died and the carb was on fire! What the heck?????
Old 08-05-2007, 06:02 PM   #4
Rick_L
Trifive Leaders Club
Member #2256
Default
You need more initial timing.
Rick_L is online now   Reply With Quote
Old 08-05-2007, 06:35 PM   #5
Hafrod
Hafrod's Avatar
Member #1291
Default
I just unhooked the vac advance and plugged the port on the jet plate. I then BARELY give it some timing and now it will squeal the tire!!! No more bog BUT just drove it around my block around 25MPH and it acts like its cutting out! It's very light but you can hear it. I had to MAKE the plug wires( universal Mallory Sprints) and I'm beginning to wonder if I just DIDN'T get one together right! Wonder why it runs better off idle without the vac advance?
Old 08-06-2007, 10:10 AM   #6
johns 56
Senior Member
johns 56's Avatar
Member #2188
Default
you might have to much carb. a 600 would most likely do better.
johns 56 is offline   Reply With Quote
Old 08-06-2007, 02:10 PM   #7
solanistec
Senior Member
solanistec's Avatar
Member #3252
Default
Do you have the vac advance on the distributor plugged into a ported vac or vac at idle? If you put vac to the dist at idle as soon as the throtle opens it will retard timming. Try setting base timing at 8 deg. with no vac at idle and see what it will do.
solanistec is offline   Reply With Quote
Old 08-06-2007, 06:13 PM   #8
r66ss
r66ss has made a donation to the forum!
r66ss's Avatar
Member #2133
Default
Quote:
Set your total timming at 38 degrees, doesnt matter where your initial
timming is at. Sounds like your vac is at 16 inches, so I would try a 6.5 power valve, Sounds like per data, you have enough motor for the 750 holley carb, You need to tune carb with vac gauge, so you can set front's at highest vac,Hope fully you installed cam straight up? as cam already has 2 to 4 degrees ground in cam already.you want cam@ straight up.
If still having issues, retune carb, using vac gauge, keep us posted.
__________________
Randy
www.picturetrails.com/mrchevelle
r66ss is offline   Reply With Quote
Old 08-06-2007, 11:53 PM   #9
twolaneblacktop
Senior Member 1 Blue Star
twolaneblacktop's Avatar
Member #594
Default
Have you "read" the plugs to see if it's rich???? Sounds like a lot of carb. for 305 heads and low compression ash trey pistons!!! Just my thoughts....wouldn't be the first time I was wrong!! I would also make sure the cam was installed straight up and not advanced!!!Have never had any luck with advancing one that way!!
twolaneblacktop is offline   Reply With Quote
Old 08-07-2007, 12:03 AM   #10
Hafrod
Hafrod's Avatar
Member #1291
Default
I pulled ALL the plugs and 5 look NEW and 3 look lightly black on ceramic-the strap looks new! WEIRD! If I nail this sucker, it blows the heck out of the right rear tire!!!! Cruising around it misses!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
