| Trifive Power Steering - Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions |
#1 |
Member
I am installing a 670 (500 series) p/s kit from CCI. The kit includes a pump bracket for a short water pump. Well, I have a long water pump which I would like to keep. You see, my alu rad is in the 6 cyl position with a shroud and fan clutch. I would like to keep this cooling setup for the 383 motor. CCI doesn't have a bracket solution.
What have you guys done bracket-wize. I assume the whole issue is about pulley alignment and maybe clearance issues. Krull57 |
#2 |
Sr. Administrator
Trifive Leaders Club ![]() |
You might look on Alan Groves site and see what he has. http://www.alangrovecomponents.com/
__________________
http://s1181.photobucket.com/albums/x437/chevman57/ http://www.trifive.com/forums/album.php?albumid=1177 1957 2dr sedan Bel Air, owned since 1978 1972 Chevelle Malibu, awaiting rebuild,owned since 1979 |
#3 |
Krull57 does March have anything ?
#4 |
Bill's Hot Rod has similar products to Alan Grove, you might have a look there too.
I guess part of this depends on the rest of your accessory drive setup. If you have a stock Chevy long water pump setup, the stock bracket for the setup you have should work too. You should be able to get a stock bracket from a Camaro/Chevelle supplier (look at 69 up parts), or look at 73 up pickup parts. |
#5 |
Krull.....What you need is the bracketry set-up for a 70-72 Camaro....CCI carries all the parts: http://www.rickscamaros.com/camaro-p...1970-1972.html
__________________
___________________ ____________________david aka POPS & sherry ![]() __________________55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan |
#6 |
Member
Thanks guys. I looked out at Alan Groves and they have a bracket and some good info about dimensions and pulley order. I will call them Monday.
#7 |
Senior Member 1 Gold Star
Krull, I assume you have side engine mounts, not stock front mounts.
__________________
Jalapeno |
| Thread Tools | |
| Display Modes | |
