Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Power Steering - Rack & Pinion - 605
User Name
Password
Mark Forums Read
Trifive Power Steering - Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Reply
Thread Tools Display Modes
Old 11-26-2011, 07:54 PM   #1
bret loibl
Member
Member #880
Default What pitman arm for a delphi 600 box?
I have a new delphi 600 box and the pitman arm off of the old manual box will not fit (splines on 600 box are bigger than the arm i have)....The arm i have maybe a power steering arm as it has no ball on it.....The 600 box is what the guy that owns the car has so its up to me to make it work..If the manual arm fits the splines does he remove the ball and drill the arm or what??? It looks as if the drag link is a power unit as it unbolted from the pitman arm.....What did i get myself into????? thanks for any help
bret loibl is offline   Reply With Quote
Old 11-26-2011, 08:10 PM   #2
557B210
557B210's Avatar
Member #5571
Default
Bret....Sounds like you do have a P/S pitman arm.....However, it should still bolt up without a problem.....The original steering box was the same between both the standard and power steering applications.....Therefore, the splined end of the pitman arms were the same.
Beyond that: if its an original standard steering car, everything should bolt right up .....If origally it had power steering, they have an adaptor.....See link:http://www.classicchevy.com/chevy-po...1955-1957.html made for this issue.
__________________
_______________________________
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Old 11-26-2011, 08:12 PM   #3
acardon
Trifive Leaders Club
acardon's Avatar
Member #1888
Default
The power steering pitman arm has the same splines as the manual steering arm. The same steering box is used for both.
You can get a adapter for the power steering center link to fit the manual pitman arm, but if the power arm won't fit, neither will the manual. .... http://www.classicchevy.com/chevy-po...1955-1957.html
The pitman arm is keyed so it will only go on the box when it is center and the arm pointing straight ahead.
__________________
Don
acardon is online now   Reply With Quote
Old 11-26-2011, 09:35 PM   #4
Rick_L
Member #2256
Default
A stock 670 box has a bigger shaft for the pitman arm than stock boxes. The 670 boxes from Concept One are supposed to come with a custom pitman arm to overcome this situaion. I don't know whether Borgeson does the same thing with theirs or has a custom sector shaft. The guy on Ebay that sells rebuilt 670 boxes with the adapter plates tells you what pitman arm to use.
As acardon said, 55-57 manual and p/s steering boxes are the same.
So..., what I'd recommend is to contact whoever the box was purchased from to find out what you need - or have the customer look for his custom pitman arm.
Rick_L is online now   Reply With Quote
Old 11-29-2011, 11:13 PM   #5
gnason
Member
Member #5885
Default
I have the Borgeson power steering box on my 55 and the stock manual steering pitman arm fits perfectly. The only issue I have is that it is a pitman arm from a 6 cylinder car and it interferes with the headers so I need to get the V8 pitman arm which should have the same splines.
Cheers Geoff
gnason is online now   Reply With Quote
Old 11-29-2011, 11:19 PM   #6
557B210
557B210's Avatar
Member #5571
Default
Geoff....Although I've heard that there were two different types for standard steering, this is the first time that I've heard there was a difference between the V8 and 6cyl pitman arms.
__________________
Old 11-29-2011, 11:31 PM   #7
Rick_L
Member #2256
Default
There is not a difference in manual steering pitman arms between 6 and V8 cars. Nor by years, assembly plants, or anything else. They simply had two interchangeable pitman arms, probably from two different suppliers.
The pitman arm that has the part number ending in 487 is the one you want. The less desireable one has the last 3 digits 877.
Old 11-30-2011, 01:51 AM   #8
classic gary
Senior Member 2 Gold Stars
classic gary's Avatar
Member #5707
Default
the pitman arm to use with the "new" 500, 600, delphi, or what ever anyone wants to call it, is from a JEEP Wagoneer I,think, 1998 and newer. they are in wrecking yards by the ton ! YES the splines on the new box are larger, the splines on the 5-6-7 box is smaller and THE SAME for POWER AND MANUAL steering. Afterall the power steering on a 5-6-7 was with a push/pull cylinder, the steering box was the same.
and, there are TWO (2) pitman arms for 5-6-7 chevys. The manual steering, ID'd with a ball on the end, and the power steering pitman arm, ID'd with a BOLT in ball. Muttonhollow, and everyone else has the arm and the ball. ALSO, the power steering arm is LONGER than the manual one, and needs to be used with a power steering idler arm which is ALSO LONGER. The power steering parts move the center link AWAY FROM THE OIL PAN, and closer to the crossmember, Big block anyone? One side effect of the longer pitman arm is "quicker" steering, but you'll need stronger arms also...
__________________
remember:
bolt-on, doesn't
universal, isn't
reproduction, made where?
classic gary is online now   Reply With Quote
Old 11-30-2011, 12:47 PM   #9
gnason
Member
Member #5885
Default
Rick - You are correct I need the pitman arm with part # ending in 487. I had also read that the two manual steering pitman arms were put on randomly like you said. When looking at the web site for Dougs headers they mentioned that the 487 was used only on cars with a V8. Doesn't really mater tho, as I need to get the 487 pitman.
Cheers Geoff
Old 12-01-2011, 12:47 AM   #10
Jalapeno
Senior Member 1 Gold Star
Member #4149
Default
Gary, you sure know your way around the OEM power steering, which tells me you've been around these TriFives a while LOL.
That said, a minor correction about the 500 gear: it has the same splines on the sector shaft as the OEM gear, so the stock pitman arm fits fine. I do not have enough experience with the other PS gears you mentioned to comment on those splines.
__________________
Jalapeno
Jalapeno is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
