Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Transmission and DriveLine Questions
User Name
Password
Mark Forums Read
Transmission and DriveLine Questions Ask all your Transmission and DriveLine Questions. Tranmission, Drives shaft, Rear End, Gears, etc
Reply
Thread Tools Display Modes
Old 08-27-2007, 12:52 PM   #1
cameo58
Member
Member #3601
Default 3 spd overdrive ?s
I have a saginaw 3 spd w/overdrive in my 58 cameo. Having trouble finding sources for the seals for the OD solenoid, OD control shaft, speedo gear and shift shafts. Any help here? I have a spare unit I'm practicing on. The manual says to remove the solenoid turn it 1/4 turn and remove. I did that ok, but it doesn't seem to want to go back in the same way. Any tricks to putting it back in? I havn't removed the control shaft yet, any advice for that? Thanks , Jack
cameo58 is offline   Reply With Quote
Old 08-29-2007, 08:58 AM   #2
WSSmolick
Member
Member #3606
Default
The shift shaft seals are available, but I believe the solenoid seal and lockout shaft seal are discontined. Actually, the lockout shaft seal may be a simple O ring, but the solenoid seal was like one of those lip types with a spring. You may get lucky and find a gasket set somewhere, like on EBay, but be sure you get these particular seals with it. I think OD gasket sets are still be reproed, for the original earlier type anyway, but without the solenoid seal.
The solenoid should go in the same way it came out. The idea is to get that ball at the end of the solenoid shaft into the slot of the lockout pawl and then twist the solenoid so that the ball stays engaged. The lockout pawl slot is either horizontal or vertical (either parallel or perpendicular to the centerline of the trans); I can't remember off the top of my head, but you'll want to be sure the flat sides of the solenoid shaft ball are oriented the same way before going into the solenoid mount. When the solenoid's all the way in, twist to the proper position and bolt on.
The control (lockout) shaft is held in by a pin. Drive the pin out and the shaft should come right out. The shaft goes back in just as easy.
WSSmolick is offline   Reply With Quote
Old 08-29-2007, 11:48 AM   #3
cameo58
Member
Member #3601
Default
Thanks for the info. I did find the solenoid seal at www.fifthaveinternetgarage.com for 7 bucks. Lockout shaft came out easy. Bad news is the seal is very much like the solenoid seal, metal ring with seal attatched only larger. I havn't found any kits that have the seals. only gasgets. Where do you find the shift shaft seals? Jack
Old 08-30-2007, 01:50 PM   #4
WSSmolick
Member
Member #3606
Default
I have yet to reassemble my Saginaw. It's still in the disassembly stage (about 3 years now), so I don't know what kind of seal the shift shafts take. I know the original '55-57 trannies used O rings for shifter shaft seals.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
