Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Electrical Questions and Answers
User Name
Password
Electrical Questions and Answers This is the place to ask all your question about electrical problems and instalation issues.
Parts on Ebay
Reply
Thread Tools Display Modes
Old 12-28-2011, 04:00 PM   #1
shnomad
Senior Member
shnomad has made a donation to the forum!
shnomad's Avatar
Member #11028
Default 56 bel air ignition switch wiring
While trying to hook up a neutral switch I have disconnected 2 wires. One is red heavy guage and the other is pink to purple in color 18-22 guage. On the back of the ignition switch I now have 2 open male terminals and 2 wires not plugged in. The word SOL seems to be between the 2 open connections. Are there 2 wires for the SOL?- I think the heavy guage wire goes on the outside terminal and the smaller wire the inner towards the center terminal. I disconnected the smaller wire thinking this is the violet wire that goes to the neutral switch-but that is probably wrong-I just don't know at this point Any help will be appreciated
shnomad is offline   Reply With Quote
Old 12-28-2011, 04:19 PM   #2
acardon
acardon's Avatar
Member #1888
Default
The heavy (12 gauge) red wire goes on the double "bat" terminal with the black wire. The heavier (16 gauge) violet wire goes on the "sol" terminal by itself. A smaller pink wire may be on the double "acc" terminal with the larger pink wire. ....http://www.trifive.com/garage/56%20C...anual/12-6.gif
__________________
Don
Sent from my 1981 IBM 5150 PC.
acardon is online now   Reply With Quote
Old 12-28-2011, 05:11 PM   #3
shnomad
Senior Member
shnomad's Avatar
Member #11028
Default
Thanks for your help Don, All I have open is one terminal on the battery side of the switch and 2 terminals on the SOL and 2 wires not connected. My problem is I don't know where the heavy red wire goes since there is already a red wire on the double Batt terminal. (there are no black wires connected to the bat terminal).But a harness with 3 wire plug does contain black, red and green wires and connects to the ignition 1&2. The SOL has a double terminal for 2 wires. so I have 3 open terminals and only 2 wires left to connect.
1 wire is pink and thicker heavier gauge wire than all the other wires
2nd wire is thin and is also kid of pinkish color I think I might be color blind
I'm confused thats why all the questions
Old 12-28-2011, 10:08 PM   #4
acardon
acardon's Avatar
Member #1888
Default
I think the lableing on the switch may be confuseing you. The "bat" and "acc" terminals are the only ones with double terminals and the "acc" terminals may only have only one wire. See picture in link. Do you have an ampmeter installed? Someone may have replaced the heavy black wire with a red wire??? What color is the wire that is on the starter solenoid along with the large battery cable? It was originally a 12 gauge black wire that went to the "bat" terminal of the switch. The large red wire on the "bat" terminal goes to the fuse block.
__________________
Don
Old 12-28-2011, 10:51 PM   #5
Farm Boy
Senior Member 1 Gold Star
Farm Boy's Avatar
Member #3642
Default
__________________
Steve
1956 Bel Air Sport Coupe
1967 Camaro
Farm Boy is offline   Reply With Quote
Old 12-29-2011, 01:38 AM   #6
shnomad
Senior Member
shnomad's Avatar
Member #11028
Default
Yeah the black bat wire is red. I was able to put the wires back where they go -thanks to you. I tried a temporary hook up for the neutral switch the car would start and immediately stall in park. I jumped the violet wire to the top of the neutral switch and a dark blue wire from bottom of neutral switch to the SOL on ignition sw. It got late so I had to quit. During this process I must have disconnected a wire to my alarm system it says faulty door or trigger but still works-just no siren. I'll try to figure that out tomorrow. I'm curious how does the neutral switch know the car is in neutral-I would think the shifter or something mechanical would have to be part of the equation?
Old 12-29-2011, 11:57 AM   #7
acardon
acardon's Avatar
Member #1888
Default
The neutral safety switch is operated by the shift tube inside the column. A tab on the switch moves the contacts in the switch when the shift tube is rotated.
If the engine is dying when you let off the start position, "ign1" wire is not connected corectly or the ballest resistor is bad. I betting that "ign1" wire is in the wrong place.
__________________
Don
Old 12-29-2011, 12:15 PM   #8
shnomad
Senior Member
shnomad's Avatar
Member #11028
Default
The car starts and runs perfectly like it did before I tried to hook up the switch. It is when I had the switch hooked up it would start and die immediately.
Old 12-29-2011, 12:20 PM   #9
acardon
acardon's Avatar
Member #1888
Default
That sounds like you have the switch hooked to "ign1" instead of the "sol" terminal and the switch is adjusted wrong. With your foot on the brake, try starting it in different gears with the switch hooked up.
__________________
Don
Old 12-29-2011, 12:25 PM   #10
557B210
557B210 has made a donation to the forum!
557B210's Avatar
Member #5571
Default
Quote:
Don's advice is spot on.....Be sure the car is headed out of the garage and not into it as well.
__________________
_______________________________
-I have a vast data base of TriFive restoration & upgrade articles for our members' use....Send me a PM with your requirements and I'll strive to provide what you need...Please include your email address and the topic
-Contact me by PM to purchase your PHR's Project X and TriFive Gasser Building CD's
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
