Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Trifive Power Steering - Rack & Pinion - 605
User Name
Password
Mark Forums Read
Trifive Power Steering - Rack & Pinion - 605 Trifive Power Steering / Rack & Pinion / Power Conversions / 605 Upgrades / This is the Place to ask all your Steering Questions
Reply
Thread Tools Display Modes
Old 09-04-2007, 09:35 AM   #1
rd57
Senior Member 1 Blue Star
Member #3316
Default A Arm bushings on 57
I am needing to replace the rubber bushings on the A arms of my 57.
This looks like it could be a big job. Are there any easy ways of putting
the new bushings in?
rd57 is offline   Reply With Quote
Old 09-04-2007, 09:39 AM   #2
ETriggs
Trifive Leaders Club
Trifive on Facebook Admin
ETriggs's Avatar
Balloon Park Champion! Othello Champion!
Member #1133
Send a message via AIM to ETriggs
Default
I had asked the same thing a while back, but it seems that either you use an arbor press or take them in. I think I will use an air hammer to get the old ones out, the get the new ones pressed in.
__________________
Eldon's 1957 Bel Air Sport Sedan
ETriggs is offline   Reply With Quote
Old 09-04-2007, 11:06 AM   #3
Shua57
Shua57's Avatar
Alu`s Revenge Champion! Boomerang Mayhem Champion! Castle Defender Champion!
Member #2394
Default
If the sleeves are good then just replace the rubber and leave the sleeve in the A-arms. The energy suspension kit I bought suggested I do that. Of course I did not read the instructions till after I had taken one side of the sleeves out. If you must replace the sleeves then most, including me, have found it is easier to air chisel them out and press them back in with a press. You could try to heat the control arm while the sleeve sits in the freezer. Either way they are not the funnest thing to do.
Shua57 is offline   Reply With Quote
Old 10-05-2007, 05:57 PM   #4
55NEWBIE
Member
Member #2728
Default A Arm Bushings
After just replacing my lower A Arm bushings, I will have to say that it is NOT the most fun I have had while re-building my 55. And I can't even imagine replacing the rubber while the bushings are still in. I'm not sure that it is possible, but I have been wrong before.
55NEWBIE is offline   Reply With Quote
Old 10-05-2007, 10:07 PM   #5
a55togo
Senior Member 1 Silver Star
a55togo's Avatar
GateGears Deluxe Champion!
Member #1881
Default
when i did my last 55, i just replaced the whole sleeve and all, wasn't that bad just a bench vise, big hammer, and a few cus words later and it was done. Just dont forget which lower arm goes where as i does make a difference
Ed
a55togo is offline   Reply With Quote
Old 10-05-2007, 11:01 PM   #6
Rick_L
Member #2256
Default
You might be able to leave the outer sleeve in place with urethane bushings but I don't think it's even possible with rubber bushings.
As far as installing new bushings, a press and some fixtures to keep from distorting the control arms is the way to go. It's all outlined in the shop manual. You can build your own fixtures, emulating the shop manual.
You do have a shop manual don't you? Get one, it's good for many other things on your car.
That said, there's been plenty of bushings installed with a hammer and vise, or with an air hammer. Just pay attention and don't hammer things out of shape.
Rick_L is online now   Reply With Quote
Old 10-08-2007, 04:35 PM   #7
bigbopper
bigbopper's Avatar
Member #2079
Default A-Arm bushings
This is my least favorite job on the whole car. I took my 454 heads to the machine shop last week to have some work done on them before installing them. I was talking to the manager, and said I was going home and start taking A-Arms apart so I could finish front suspension. He said, why don't you bring them in to him and they would press them apart for me. They not only pressed them apart, they also ran everything through their parts cleaner for $25.00, they look brand new. That also includes pressing them back together when I get everthing painted. IMO this the only way to go.
I don't know the prices for your area, but these guys did not think it was that big of deal and do it all the time.
Maybe this will help or at least give you another option.
bigbopper is offline   Reply With Quote
Old 10-09-2007, 07:49 AM   #8
Shua57
Shua57's Avatar
Member #2394
Default
I didn't think they made rubber any more. You are probably right. I should have stated I replaced mine with urethane bushings. They slide right in and are the correct shape. Of course I sandblasted the control arms to clean the existing sleeves. There is always a ton of different ways to get one thing done. Just don't get too frustrated with replacing the bushings.
__________________
They call me tater puddin.....or Josh
DRIVE IT LIKE YOU STOLE IT!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
