Go Back   TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice > 55-56-57 Chevy Forum > Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
User Name
Password
Mark Forums Read
Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc Suspension Questions Chassis, Brakes, Springs, Shocks, Swaybars, Tire, Rims Etc
Reply
Thread Tools Display Modes
Old 02-12-2012, 12:42 PM   #1
topdog
Senior Member 1 Silver Star
topdog's Avatar
Member #15087
Default Rear tire removal 55 210 series
to remove my fat rear tires on crager rims and a spacer, i must jack up the vehicle, disconnect the shocks, remove the spring U bolts and lowering blocks.
Tire clearance is about 1/2 inch with a rolled lip. So far this is the only way I can remove the wheels.
I was thinking that it might be easier to disconnect the rear shackles. Has anyone tried this?
topdog is offline   Reply With Quote
Old 02-12-2012, 01:17 PM   #2
mickeywestsr
Trifive Leaders Club
mickeywestsr's Avatar
Member #1970
Thumbs up
I guess I'm just too lazy....too much problem.
__________________
GO VOLS
COWBOY
mickeywestsr is online now   Reply With Quote
Old 02-12-2012, 01:59 PM   #3
557B210
557B210's Avatar
Member #5571
Default
TD....Have you tried pushing in at the top, as you pull the tire down? Also, I've found that letting the air out will help a lot.
__________________
_______________________________
____________________david aka POPS & sherry__________________
55 Belair Sportscoupe/55 Belair 4 door sedan/55 B210 2 door sedan/57 B210 2 door sedan
557B210 is online now   Reply With Quote
Old 02-12-2012, 02:44 PM   #4
Surestart Engine Service
Senior Member
Surestart Engine Service's Avatar
Member #4024
Default
Hi Topdog, yeah , fat tires in a stock 55 fenderwell with a stock width rearend is a real pain!
It would probably be a little easier to drop the spring at the rear shackle as you suggest, but still not a fun job.
My suggestion to you would be to get a slightly narrower rear end,(not yours, the cars). Sometimes all it takes is a1/2 to 3/4 on each side to make a world of difference.
I know from my own experience that the s 10 ZR 4wheel disc rear end fits great and gives an extra 1/2 or so on each side. Same with the Furd Exploder 8.8 rear.
Might be a good opportunity to upgrade your brakes? If you dont want discs in the rear there are any number of stock width chevy 10 and 12 bolt rears to use. You want a rear width of 58 to 59 inches ,mounting face to face.
If more room is needed you may have to move your springs inline with the frame with a "pocket" kit. This may sound like a lot of work but in the end , not having to dismantle your car every time you want to remove a rear tire will be worth it.
my 2 cents worth.....Good luck . John
Surestart Engine Service is offline   Reply With Quote
Old 02-12-2012, 03:32 PM   #5
angs1957
Super Moderator
angs1957's Avatar
Member #2237
Default
I had a hard time with a stock tyre let alone a wider one cause I was jacking it up from the diff.
I changed tack & jacked up the frame rail on the side I wanted to change, piece of cake
angs1957 is offline   Reply With Quote
Old 02-12-2012, 04:27 PM   #6
57buddy
Member
Member #18972
Default tire
if only need a little clearence take a little hyd jack make a bracket to hold it on axle and frame jack them apart
57buddy is offline   Reply With Quote
Old 02-12-2012, 07:21 PM   #7
topdog
topdog's Avatar
Member #15087
Default
Running a 10 bolt rear axle with 9 inch rear brakes. Tried deflating the tires and tipping the wheel and tire. I only need a little bit more clearance. I am thinking the hydraulic jack might be enough to get the tire out.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Privacy Policy
www.trifive.com/privacy.htm
Websites
Powered by vBulletin
1957 CHEVROLET BEL AIR Information, 1957 CHEVROLET BEL AIR Specifications, 1957 CHEVROLET BEL AIR Resources, 1957 CHEVROLET BEL AIR Pictures, 1957 CHEVROLET 55 chevy 56 chevy 57 chevy 1955 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy pictures 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy pictures 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy photos 55 chevy parts 55 chevy truck 55 chevy pickup 55 chevy nomad 55 chevy gasser 55 chevy pro street 56 chevy photos 56 chevy parts 56 chevy truck 56 chevy pickup 56 chevy nomad 56 chevy gasser 56 chevy pro street 57 chevy photos 57 chevy parts 57 chevy truck 57 chevy pickup 57 chevy nomad 57 chevy gasser 57 chevy pro street 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad belair Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 belair chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy belair 1956 Chevybelair 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy belair 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five belair Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy belair 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five Tri5 55 chevy 56 chevy 57 chevy 1955 Chevy 1956 Chevy 1957 Chevy Bel Air 210 150 and Nomad Tri-5 Tri-five 55chevy 55 chevy pictures 55 chevy parts 55 chevy truck 55 chevy pickup 57 chevy 55 chevy nomad 55 chevy gasser 55 chevy pro street Searches related to 57chevy 57 chevy pictures 57 chevy 57 chevy truck 57 chevy parts 57 chevy pickup 57 chevy nomad 1957 chevy Tri5
